メインコンテンツにスキップ
はじめに
Prereq-only for detaching the display assembly.
    • Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
    • Remove the bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  1. Use the point of a spudger to pry the battery connector straight up out of its socket. Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Use the point of a spudger to pry the battery connector straight up out of its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  2. Remove the two 1.2 mm Y000 screws securing the display connector bracket. Remove the bracket.
    • Remove the two 1.2 mm Y000 screws securing the display connector bracket.
  3. Use the tip of a spudger to pry up and disconnect the digitizer cable. To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Use the tip of a spudger to pry up and disconnect the digitizer cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  4. Use the tip of a spudger to disconnect the display cable connector. Use the tip of a spudger to disconnect the display cable connector.
    • Use the tip of a spudger to disconnect the display cable connector.
  5. Remove the five screws securing the logic board connector bracket to the rear case: One 1.3 mm Phillips #000 screw
    • Remove the five screws securing the logic board connector bracket to the rear case:
    • One 1.3 mm Phillips #000 screw
    • One 1.5 mm Phillips #000 screw
    • Three 1.2 mm Y000 screws
    • Be careful not to lose the smaller bracket clipped onto the edge. It's secured with a small clip and is easy to accidentally knock off of the larger bracket.
  6. Use the tip of a spudger to pry the front sensor assembly connector up from its socket. Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
    • Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
  7. Remove the display assembly.
終わりに
ある他の人がこのガイドを完成しました。
Adam O'Camb
メンバー登録日: 2015年04月11日
145,746 ポイント
417のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
138 メンバー
16,993のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 14
今までの合計 346
