はじめに
Basic disassembly tutorial for iPhone X.
必要な工具と部品
ビデオの概要
Press the wake button and volume down button to turn off the phone.
Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened.
Undo 5 screws shown in the picture below with a tripoint #Y000 screwdriver
These screws are all different sized so keep track of where they go
Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
Undo 3 Y000 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
Remove the 2 Phillips #PH00 screws and remove the metal plate, release the rear cameras connectors.
These screws are also different sizes
Release all connectors on the motherboard with a spudger
Undo 3 Phillips #PH00 screws on the mother board then we can take out the mother board.
Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine
Remove the loud speaker and the taptic engine.
Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
Heating the front facing camera with a heat gun will make it easily to be removed
Release 4 screws on the frame shown in the picture
Heating the charging port flex cable then we can remove it easily
Release 7 screws on the Wi-Fi flex cable
Heating the flex cable with a heat gun make it easier to be removed
Release 3 screws on the power button
Heating the flex cable with a heat gun then it can be removed easily
129 の人々がこのガイドを完成させました。
25 件のコメント
It's good
The iPhone X assemble video: https://youtu.be/E5jyuxgpE_g
What About the backside ? I heard that when the backside is shattered, it’s almost impossible to repair, because of the glue that holds the backside and parts together ?
Hi avdk, we don’t tear down the back glass but we will pay attention to this question. If there is a definite answer, I will reply to you .Thank you.
Mandy -
