メインコンテンツにスキップ
iPhone X Disassembly
必要な工具と部品
ビデオの概要
  1. iPhone X Disassembly, Turn off the phone and remove SIM Card: 手順 1、 2の画像 1 iPhone X Disassembly, Turn off the phone and remove SIM Card: 手順 1、 2の画像 2
    • Press the wake button and volume down button to turn off the phone.
  2. iPhone X Disassembly, Open the phone: 手順 2、 3の画像 1 iPhone X Disassembly, Open the phone: 手順 2、 3の画像 2 iPhone X Disassembly, Open the phone: 手順 2、 3の画像 3
    • Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened.
  3. iPhone X Disassembly, Remove the iPhone X OLED screen: 手順 3、 3の画像 1 iPhone X Disassembly, Remove the iPhone X OLED screen: 手順 3、 3の画像 2 iPhone X Disassembly, Remove the iPhone X OLED screen: 手順 3、 3の画像 3
    • Undo 5 screws shown in the picture below with a triangle screwdriver
    • Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
  4. iPhone X Disassembly, Remove the ear speaker: 手順 4、 2の画像 1 iPhone X Disassembly, Remove the ear speaker: 手順 4、 2の画像 2
    • Undo 3 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
  5. iPhone X Disassembly, Remove rear-facing cameras.: 手順 5、 1の画像 1
    • Remove 2 screws and remove the metal plate, release the rear cameras connectors.
  6. iPhone X Disassembly, Remove motherboard.: 手順 6、 2の画像 1 iPhone X Disassembly, Remove motherboard.: 手順 6、 2の画像 2
    • Release all connectors on the motherboard with a spudger
    • Undo 3 screws on the mother board then we can take out the mother board.
  7. iPhone X Disassembly, Remove Loudspeaker and Taptic engine: 手順 7、 3の画像 1 iPhone X Disassembly, Remove Loudspeaker and Taptic engine: 手順 7、 3の画像 2 iPhone X Disassembly, Remove Loudspeaker and Taptic engine: 手順 7、 3の画像 3
    • Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine
    • Remove the loud speaker and the taptic engine.
  8. iPhone X Disassembly, Remove battery: 手順 8、 2の画像 1 iPhone X Disassembly, Remove battery: 手順 8、 2の画像 2
    • Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
  9. iPhone X Disassembly, Remove front-facing camera: 手順 9、 2の画像 1 iPhone X Disassembly, Remove front-facing camera: 手順 9、 2の画像 2
    • Heating the front facing camera with a heat gun will make it easily to be removed
  10. iPhone X Disassembly, Remove the charging port and antenna: 手順 10、 3の画像 1 iPhone X Disassembly, Remove the charging port and antenna: 手順 10、 3の画像 2 iPhone X Disassembly, Remove the charging port and antenna: 手順 10、 3の画像 3
    • Release 4 screws on the frame shown in the picture
    • Heating the charging port flex cable then we can remove it easily
  11. iPhone X Disassembly, Remove Wi-Fi antenna: 手順 11、 3の画像 1 iPhone X Disassembly, Remove Wi-Fi antenna: 手順 11、 3の画像 2 iPhone X Disassembly, Remove Wi-Fi antenna: 手順 11、 3の画像 3
    • Release 7 screws on the Wi-Fi flex cable
    • Heating the flex cable with a heat gun make it easier to be removed
  12. iPhone X Disassembly, Remove power button flex cable: 手順 12、 3の画像 1 iPhone X Disassembly, Remove power button flex cable: 手順 12、 3の画像 2 iPhone X Disassembly, Remove power button flex cable: 手順 12、 3の画像 3
    • Release 3 screws on the power button
    • Heating the flex cable with a heat gun then it can be removed easily
終わりに
129 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Mandy
メンバー登録日: 12/05/14
9,518 ポイント
9のガイドは作成済み
25 件のコメント
excellent guide!!!
Andy Lee - 返信
What About the backside ? I heard that when the backside is shattered, it’s almost impossible to repair, because of the glue that holds the backside and parts together ?
Arnoud - 返信
Hi avdk, we don’t tear down the back glass but we will pay attention to this question. If there is a definite answer, I will reply to you .Thank you.
Mandy -
コメントを追加
統計データ:
過去 24時間: 44
過去 7 日: 322
過去 30 日: 1,319
今までの合計 208,357
