はじめに
更换 iPhone X 显示组件通常不会影响 Face ID。 但是,我们收到客户的投诉,称更换显示屏组件后手机上的 Face ID 出现故障。 我们做了一些研究,我们猜测问题可能是在更换过程中操作不当,导致柔性电缆或其他组件损坏。
ビデオの概要
22 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
7 件のコメント
Why not just buy a new cable? They’re $10-$15 on eBay. Soldering seems like it’s take way more time and possibly even cost more money than just buying a new cable.
Face ID will no longer function if the original flex connectors are damaged or replace with new ones. Even if the flex connectors are properly soldered just as they were originall it will still fail. There is some marker in the cables which the module is checking for and if the cables are changed then the marker (most likely the serial number of the flex) will mismatch and fail to work. The same was true with Touch ID as well
What brian said is correct, if the cable is changed it will not match.This full video looks more detailed(21) Troubleshooting iPhone X Problems of Floodlight Sensor, True Tone, and Face Recognition - YouTube,
