メインコンテンツにスキップ
iPhone 7 Plusのスピーカーの交換
必要な工具と部品
  1. iPhone 7 Plusのスピーカーの交換, ペンタローブネジ: 手順 1、 1の画像 1
    • 作業を始める前に、iPhoneのバッテリーを25%以下まで消費してください。充電されたリチウムイオンのバッテリーは発火の原因となったり、穴が開いてしまった際は爆発する危険性があります。
    • 解体作業を始める前に必ずiPhoneの電源を切ってください。
    • iPhoneの底面から3.4 mmペンタローブネジを2本外します。
    • iPhoneのディスプレイを開口することにより、ディスプレイの耐水シールが破損します。このステップを進める前に交換用のシールを用意しておくか、耐水シールの交換をしないで再組み立てする場合は液体の浸水に注意してください。
    The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
    pargoff - 返信
    The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
    Jeff Suovanen -
    @jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
    iHelpU.Tech - 返信
    Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
    Vanessa Pinter - 返信
    How do you turn off if the screen isn’t responding to touch?
    adam - 返信
    The replacement battery came with the seal—but how do you put it on???
    lkollar - 返信
    Instructions for replacing the seal are here: iPhoneディスプレイ用接着剤の交換
    bester - 返信
    I just found the instructions on how to install the seals AFTER I was completed and had to figure it out. Maybe, just maybe you should link this somewhere on the guild instead of buried in a comment. Just a thought.
    Charles Meitin - 返信
    Step 1 is: Read through all the steps and comments or the method prior to starting on this Step 1. There's a lot of much needed information and experience that you can learn from which will reduce the chance of struggling, wasting time or even breaking your device.
    My favourites are:
    Use a hot water bottle.
    Label all screws you remove with their size and location on a piece of paper with double sided sticky tape.
    Test the lightning assembly at step 13
    There is a Standoff driver bit in the box, don't use a screwdriver.
    etc...
    Neil Eriksen - 返信
    A tip for looking out for all those little screws. I used an ice block tray, for all the little screws etc. I numbered each with the step number, as in the instructions, but not all steps have bits to look out for. Where two different size screws are used I had a tray for each size and marked step a and step b. For this I coloured each tray sticker with the colour of the screw as shown in the instructions. All this worked a treat with no confusion or using the wrong part.
    Herb
    Herb Adler - 返信
    The screw size for those with a screw set is P2.
    Gareth Flandro - 返信
  2. iPhone 7 Plusのスピーカーの交換, ひび割れた部分にテープを貼る: 手順 2、 3の画像 1 iPhone 7 Plusのスピーカーの交換, ひび割れた部分にテープを貼る: 手順 2、 3の画像 2 iPhone 7 Plusのスピーカーの交換, ひび割れた部分にテープを貼る: 手順 2、 3の画像 3
    • iPhoneの画面が割れてしまった場合、ガラスの表面上にテープを貼っておくと、それ以上広がることがなく、作業中の怪我を防ぐことができます。
    • iPhoneの画面の上に、透明な梱包用テープを重ね合わせます。
    • 修理の際に飛び散るガラスから目を保護するため、安全メガネを着用してください。
    • 次の手順で吸盤がうまく装着しない場合は、強力なテープ(ガムテープなど)を持ち手に折って、代わりにそれでスクリーンを持ち上げてみてください。
    • それでもうまくいかない場合は、吸盤カップに強力接着剤をつけて、画面に装着してください。
  3. iPhone 7 Plusのスピーカーの交換, リバースクランプの使用方法: 手順 3、 3の画像 1 iPhone 7 Plusのスピーカーの交換, リバースクランプの使用方法: 手順 3、 3の画像 2 iPhone 7 Plusのスピーカーの交換, リバースクランプの使用方法: 手順 3、 3の画像 3
    • 次の3つの手順では、デバイスの開講作業を簡単にするために開発されたツール、リバースクランプの使い方を紹介します。リバースクランプを使用しない場合は、この3つの手順をスキップして別の方法をご覧ください。
    • リバースクランプの詳細な使用方法については、 こちらのガイドをご覧ください。
    • 青いハンドルをヒンジ側に引くと、リバースクランのアームを解除します。
    • iPhoneの左/右側の端に向けてアームをスライドします。
    • 吸盤カップをiPhoneの下端付近に装着します。前面と背面に1つずつ取り付けます。
    • 吸盤カップ両側をギュッと締め合わせると、標的の場所にしっかりと装着させることができます。
    • 作業中のデバイス表面が滑りやすく、吸盤がうまく装着できない場合は、梱包用テープを表面に貼ると、よりグリップ力を強めることができます。
  4. iPhone 7 Plusのスピーカーの交換: 手順 4、 3の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 4、 3の画像 2 iPhone 7 Plusのスピーカーの交換: 手順 4、 3の画像 3
    • 青いハンドルを手前に引くと、アームがロックされます。
    • ハンドルを時計回りに360度回転させ、カップが両側をストレッチするまで回し続けます。
    • 吸盤カップの位置が合っていることを確認してください。装着位置がずれ始めてきたら、吸盤を少し緩めてアームを装着し直してください。
  5. iPhone 7 Plusのスピーカーの交換: 手順 5、 2の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 5、 2の画像 2
    • Heat an iOpenerを温めて、リバースクランプのアームの間にこれを通してください。
    • ヘアドライヤーヒートガンもしくはホットプレートでも対応できますが、過剰な熱はディスプレイや内蔵バッテリーを破損する恐れがあります。取り扱いにはご注意ください。
    • iOpenerを折り曲げて、iPhoneの下側端に当たるようにします。
    • 1分ほど待機すると、接着剤が剥がれ始め、デバイスの間に隙間ができます。
    • プラスチックベゼルとスクリーンの間の隙間にオープニングピックを差し込みます。スクリーン自体には差し込まないでください。
    • クランプで十分な隙間が作れない場合は、さらに接着面に熱を当てて、クランプを1/4程度時計回りに回してください。
    • 一回ごとの作業で1/4以上回さないでください。クランプをまわしたら1分間待ってください。リバースクランプの効果を待ってから、作業を続けてください。
    • 次の3つの手順はスキップしてください。
  6. iPhone 7 Plusのスピーカーの交換, ディスプレイを温めます。: 手順 6、 1の画像 1
    • 次の3つの手順では、吸盤カップを使ってスクリーンを乖離させる方法が学べます。
    • iPhoneの下端を加熱すると、ディスプレイを固定している接着剤が柔らかくなり、開きやすくなります。
    • ヘアドライヤーを使用するか、iOpenerを準備し、ディスプレイ裏側の接着剤を柔らかくするために、iPhone下部端に約90秒間あてます。
  7. iPhone 7 Plusのスピーカーの交換, ディスプレイを外します。: 手順 7、 2の画像 1 iPhone 7 Plusのスピーカーの交換, ディスプレイを外します。: 手順 7、 2の画像 2
    • ホームボタンのすぐ上にあるフロントパネルの下半分に吸盤を取り付けます。
    • 吸盤カップをホームボタン上に装着しないでください。吸盤カップをしっかりとフロントガラスに固定するためです。
  8. iPhone 7 Plusのスピーカーの交換: 手順 8、 3の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 8、 3の画像 2 iPhone 7 Plusのスピーカーの交換: 手順 8、 3の画像 3
    • 一定の力で吸盤カップを引き上げて、スクリーンとフレームの間にわずかな隙間を作ります。
    • 隙間に開口ピックを挿入します。
    • スクリーンを所定位置に固定する防水性接着剤は非常に強く、 最初の隙間を作るにはかなりの力を要します。なかなか隙間ができない場合、さらに熱を加えたり、ピックを挿入できるだけの十分な隙間を作るために画面を上下にゆっくり揺り動かして接着剤を弱めます。
  9. iPhone 7 Plusのスピーカーの交換: 手順 9、 3の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 9、 3の画像 2 iPhone 7 Plusのスピーカーの交換: 手順 9、 3の画像 3
    • 開口ピックを左下からiPhoneの音量コントロールボタンとサイレントスイッチの方向にスライドさせて、ディスプレイを固定している接着剤を剥がします。
    • ディスプレイの左上隅付近で停止します。
    • ディスプレイの上端から後部ケースを引き剥がそうとしないでください。固定しているプラスチック製のクリップが破損することがあります。
  10. iPhone 7 Plusのスピーカーの交換, スクリーンの情報: 手順 10、 1の画像 1
    • iPhoneの右側に端に沿って、デリケートなケーブルが装着されています。この部分にピックを差し込まないでください。ケーブルを破損する恐れがあります。
  11. iPhone 7 Plusのスピーカーの交換: 手順 11、 3の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 11、 3の画像 2 iPhone 7 Plusのスピーカーの交換: 手順 11、 3の画像 3
    • iPhoneの右下隅に開口ピックを再度差し込み、角を回ってiPhoneの右上にスライドさせて接着剤を剥がします。
    • ディスプレイケーブルを傷つける恐れがあるので、ピックを3mm以上差し込まないでください。
  12. iPhone 7 Plusのスピーカーの交換: 手順 12、 2の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 12、 2の画像 2
    • ディスプレイの下端を押さえながら、吸盤カップをゆっくりと引き上げます。
    • ディスプレイを15°以上持ち上げないでください。ディスプレイが接続されたリボンケーブルを傷つけたり、破損する恐れがあります。
    • 吸盤カップの小さな持ち手(ノブ)を緩めて、フロントパネルから取り外します。
  13. iPhone 7 Plusのスピーカーの交換: 手順 13、 3の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 13、 3の画像 2 iPhone 7 Plusのスピーカーの交換: 手順 13、 3の画像 3
    • ディスプレイ下の開口ピックを左上の角からiPhoneの上端に沿ってスライドさせて、残りの接着剤を剥がします。
  14. iPhone 7 Plusのスピーカーの交換: 手順 14、 2の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 14、 2の画像 2
    • ディスプレイアセンブリをわずかに下に(iPhoneの上端から離して)スライドさせて、リアケースに固定しているクリップを外します。
  15. iPhone 7 Plusのスピーカーの交換: 手順 15、 3の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 15、 3の画像 2 iPhone 7 Plusのスピーカーの交換: 手順 15、 3の画像 3
    • 本のページをめくるように、ディスプレイの左側を持ち上げてiPhoneを開きます。
    • いくつかの壊れやすいリボンケーブルがまだiPhoneのロジックボードに接続しているので、ディスプレイを完全に外そうとしないでください。
    • 作業がしやすいように、iPhoneを開口をしたままディスプレイの後ろに衝立を置き、立てかけてください。
  16. iPhone 7 Plusのスピーカーの交換, バッテリーの接続の外し方: 手順 16、 1の画像 1
    • ロジックボードに留められたディスプレイケーブルブラケットの下部から次の4本のトライウイングY000ネジを取り外します。
    • 1.2 mmネジー3本
    • 2.6 mmネジー1本
    Is it really safe to lay the device fully open like a book? The cable leading to the LCD gets stretched across the sharp edge of the aluminum edge of the back cover.
    u204863 - 返信
    Generally I'd say no, it's not safe. In reality I've seen a bit of variance in the cable length, and sometimes it'll be fine—but mostly I'd be prepared to prop the display up or hold it in place at a slight angle so it doesn't put too much stress on the cables. On prior iPhones it was easy to rubberband the display to a box or a can of soda, and something like that would probably work well here too. Use your own judgment.
    Jeff Suovanen -
    You could stick the suction cup back on, near the right side of the phone, with the blue hook oriented in such a way that it becomes a stand for the screen. That way it won’t open much more than 90 degrees, and leaves both your hands free.
    Mark -
    The tri wing screws are so hard to remove. What's the trick?
    shannon caldwell - 返信
    At first I think I was being too careful and was getting no where. I got better results by pressing down on the screwdriver with more pressure while turning and those little screws came right out.
    LadyTech - 返信
    I cannot remove one of the corner screws in this step and i have used the tweezers and the y000 tri tip and i am afraid that it is stripping it. is there a work around for this step?
    Katherine Monday - 返信
    @katmonday1 No workaround unfortunately. Make sure the driver tip is in good condition and fits the screw correctly. Seat it in the screw, hold the driver perfectly vertical, press down hard (and maintain it), and turn. It’ll come out. If it’s really stripped you’ll have to get more aggressive—try one or more of the techniques in this guide or get some help. Good luck!
    Jeff Suovanen -
    my screwdriver will only remove the 2.6mm screw and not the others, what shall i do?
    AubreyG1 - 返信
    A tip to remember which screw is which as the differences are pretty tiny: I used different colored sharpie fine-points and made a mark on the top of the screws before removing. I thought about having strips of tape that I stuck similar sizes to, but the coloring seemed to work more easily. I only did this for step 11 and it saved me down the road when trying to differentiate the 1.2 and the 1.3mm screws!
    Trey Smith - 返信
    STOP! Before you remove Any screws, be sure to create several bins to hold the various sizes in… or mark them like Trey suggested. I failed to pay attention because I thought they were all the same… they are not. It is very hard to figure out the sizes if you remove them all and store them in a single location.
    John Grant - 返信
    i had a piece of paper with the steps numbered that involved screws. I had double sided tape on the paper and the number of screws and thier position marked. This was so helpful in removing and then finding and installing the tiniest screws on earth. And i have TINY hands. I can’t imagine someone with large paws being able to accomplish any of this.
    Tina Matthews - 返信
    there is one screw thats 1.2 mm but its bigger than the others and will fit in no hole of the entire phone. i got it out bot now i have no idea where it has to go i tried every hole. can somebody help me?
    Lars Göbel - 返信
    what do i do if one of the screws dont want to come off
    Neylley Reynoso - 返信
  17. iPhone 7 Plusのスピーカーの交換: 手順 17、 2の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 17、 2の画像 2
    • ディスプレイケーブルブラケットの下部を外します。
    I am confused, please help. LOL the bracket, the very first one being removed. I see it has three screws the same size and one a different size? I've been trying to fix my daughter's phone and ordered a 0.6 mm Tri Wing screwdriver for iPhone 7 plus /Apple watch. It seems to fit the screws and it seems to be turning them although I can't see that well but they're not coming out. However when I used it on a smaller bracket with two screws they came right out so I'm thinking I don't have the right screwdriver I am at my Wit's End!! I have been working on this phone or attempting to for a while now. I cannot find a list anywhere of the exact size screwdrivers needed to Take apart an iPhone 7 plus. Any help would be greatly appreciated.
    chris west - 返信
    If your tri-wing screwdriver worked for other tri-point screws in the phone, then it should work for the screws you are struggling with! If it feels like the screws are spinning but not coming out, try to use tweezers to pull them out. I often struggle with tri-point screws, and need to apply some downward pressure to remove them. This can be risky though, as you do not want to strip the screw or damage components underneath the bracket. If you continue to struggle, you can give this driver and this bit a try.
    Scott Havard - 返信
    Also be aware that the battery connector might stick to the bottom of the steel bracket. This part had me a bit puzzled at first. lol
    Just gently pry the connector off the steel bracket to release it and be sure the connector isn’t allowed to accidentally reconnect to the board.
    jeffrey griffith - 返信
    I had to use a fingernail to dislodge the bracket. As Jeffrey said, it was apparently stuck to the connector.
    lkollar - 返信
  18. iPhone 7 Plusのスピーカーの交換: 手順 18、 3の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 18、 3の画像 2 iPhone 7 Plusのスピーカーの交換: 手順 18、 3の画像 3
    • スパッジャーの先端を使って、ロジックボード上のソケットからバッテリーコネクターを引き上げます。
    • 引き上げた後、コネクターケーブルをわずかにソケットから反対側に曲げて固定します。ソケットに接触して電話本体に電源が入ることがないように防止することができます。
    You could cover the battery socket with a small piece of tape to make sure that it doesn’t accidentally re-connect. It’s not likely to, but I liked the peace of mind.
    Mark - 返信
    on reassembly, make sure that the connector cable is back in place, along side the battery, and not up, or on top in any way.
    Sarr Sheffer - 返信
    I slipped a small piece of paper under the flap.
    MajorCouillon - 返信
    After this step it is worth jumping to step 36 and disconnecting the lighting connector assembly (indicated with the orange rectangle) and connecting the new cable to test it out. After attaching the new lightning connector assembly, reattach the battery, and try plugging it in to see if the new assembly works correctly. If it does, then power down the phone, disconnect the battery, and disconnect the new lightning connector assembly. Then continue. If it doesn’t work, this check will save you a couple of hours of work.
    Evan O - 返信
  19. iPhone 7 Plusのスピーカーの交換, ディスプレイアセンブリ: 手順 19、 3の画像 1 iPhone 7 Plusのスピーカーの交換, ディスプレイアセンブリ: 手順 19、 3の画像 2 iPhone 7 Plusのスピーカーの交換, ディスプレイアセンブリ: 手順 19、 3の画像 3
    • この手順で、ケーブルの接続を外す、もしくは接続する前に、バッテリーの接続を外しているか必ず確認してください。
    • スパッジャーの平面側先端や指の先を使って、ロジックボード上のソケットから2つのディスプレイコネクタをまっすぐ引き上げて接続を外します。
    • コネクタを再装着する際は、コネクタを1つずつ差し込み、カチッと音がしてしっかり装着されてから、もう一方のコネクタを取り付けてください。コネクタの中央を押さえないでください。コネクターが僅かでもずれてしまうと永久的なダメージになります。
    • デバイスを再組み立てした後に、真っ白なスクリーンやディスプレイ上に白い線がある時、または部分的もしくは全体のタッチ応答がない場合は、両方のケーブルの接続を抜いてから、慎重に再接続してください。ケーブルがしっかりと固定されていることを確認してください。
    The note about the danger of pressing on the connector incorrectly is very legitimate. Though I find it more practical to use a wide (1.5 cm) case opener tool to press it down all at once. Minimizes risk of bending the connector.
    Talon - 返信
    What can happen if the battery is not disconnected before the two lower display connectors?
    Alextay - 返信
    Hello, by my expierence and what i have learned iphone repair videos you can ‘blow up’ capacitors which one in logic board, screen is sensetive with voltages and etc….
    Darius Varanavičius -
    what are my options if the display connector broke? can it be replaced or do I need to get a whole new screen?
    matomach - 返信
    When I removed the lower display cable bracket in step 12, the top connector stuck to the bracket and became disconnected.
    Grant Crawford - 返信
    My replacement screen wouldn't sit in the display connector properly, (wouldn't clip in both sides at same time) so I made sure it sat on one and it was lined up and got a thin piece of dense sponge and placed that over the connector, then proceeded to install the connector shield and screen works perfectly fine without a hitch. Very good tutorial just earnt me £25 lol
    Joshua Driscoll - 返信
    have the same issue, sometimes it doesn’t sit on the left side, other time not on the other, the difference is iphone not starting at all or looping with apple logo reboot…
    ibisiki -
    Bent the pins on the connector out of place, worked them very carefully back with fine nose tweezers. This was by far the crux of the repair for me.
    nicO - 返信
  20. iPhone 7 Plusのスピーカーの交換: 手順 20、 3の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 20、 3の画像 2 iPhone 7 Plusのスピーカーの交換: 手順 20、 3の画像 3
    • フロントパネルセンサーアセンブリのコネクターに取り付けられているブラケットからトライポイント Y000ネジを計3本外します。
    • 1.3 mm ネジー1本
    • 1.0 mm ネジー2本
    • ブラケットを取り出します。
    Posted a comment above on the first step. The screwdriver that I ordered Works taking out these two screens shown in the picture. However it does not work on the first bracket that needs to be removed. It seems that all screw sizes are somewhat different but I'm not finding a list showing different screwdriver sizes needed. Does this make sense? Could anybody please give me some advice on this thank you much.
    chris west - 返信
    I know your comment was posted a long time ago but just in case someone else has the same problem, the only difference in the screws are the lengths. The ends are the same.
    mcr4u2 - 返信
    What happens if you break “tear in half” the black tape stuff?
    assweeetasyou - 返信
    Unfortunately if you tear the black cable you will need to replace it !!!
    Wayne Lyell -
    Chris West the screwdriver that probably came with the kit was pentalobe to get the first two screws out to open the case. you need a .6mm Y tip driver for internal. its deceptively Phillips looking but is not it only has three blades in a Y, not 4 in a +
    Jeremiah Kjensmo - 返信
    I called the y tip a triangle tip until I read these comments. Thanks for the correction
    Kayla Tobin -
    Hello is it if I put wrong screw can damage the board?
    alicenine84 - 返信
    Care should be taken while removing the last 1.0mm screw, on the far right in the picture. This screw is screwed into another screw (or standoff) beneath the bracket. This standoff may come unscrewed and upon removing the bracket you may find the screw and standoff are still attached to the bracket. Do not lose this part if you decide to separate them , the standoff is not a normal phillips, and may require a special driver to reinstall. I used the phillips to start it back in, and relied on the screw to tighten it upon reassembly.
    Benji - 返信
    I know this is late bit a trick I use to put the standoffs in (had to do 2 cause someone lost the screws I was replacing) is to take the screw that goes in it srew them together loosely to give it a fake phillips head then gently screw both into the spot the standoff goes in. you can then take the phillips out (may need to put a spudger between the screw and standoff to keep the standoff down then use a tiny flathead to gently tighten the standoff down. its a few steps but makes life easier if you need to replace it quickly.
    Stephen Patterson -
    I was able to remove the first 1.0 mm three tri-point Y000 screw from the bracket but I cannot for the life of me get the other 1.0 mm screw undone or the one 1.3 mm screw undone. Any tips?
    I tried pressing down a bit harder and I even put the first screw back in to see if it helped me loosen the other two but it did not work.
    My screwdriver was doing the job up until this point, and I’m worried I’ll strip the screw if I keep trying.
    Would appreciate any advice!
    jrosegoep - 返信
    Dear IFixit: First, I want You to know I love your repair guides. I consider You to be the absolute best repair manuals available. But, hopefully as your friend I am going to point out once the bracked is removed a 2.0 mm Standoff screw should appear. It’s 1 of 2 screws holding the Antena Flex Cable in place. Rob
    Robert Schmidt - 返信
  21. iPhone 7 Plusのスピーカーの交換: 手順 21、 2の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 21、 2の画像 2
    • フロントパネルセンサーアセンブリのコネクターをロジックボード上のソケットから接続を外します。
    • このプレスコネクターは再装着の際、変形のダメージを防ぐため1回の取り付けで再接続してください。
    Make sure that the orientation of the cable when you attach is correct! See the picture for the correct orientation. If it gets installed 180 degrees out(i.e., the ribbon goes up instead of down, then the earphone, front camera, and Home button will be inoperative. Ask me how I know!?! Worked great when installed correctly!
    Kevin Reilly - 返信
    Thanks Kevin. I would be stuck if I hadn't read your comment!?! Great input.
    Lukas Watts -
    That's save my life!thanks god!
    neg -
    I also made this mistake! Thank goodness it didn’t break anything.
    That Guy - 返信
  22. iPhone 7 Plusのスピーカーの交換: 手順 22、 1の画像 1
    When removing the old adhesive from the edges, duct tape can be useful. Simply use small strips of duct tape and your spudger to press the tape’s adhesive side carefully into the edges of the phone’s display and slowly peel the duct tape away from the display. The duct tape should pick up the remaining adhesive and carry it away from the edges. use the tip of the spudger to gently scrape away any remaining dirt or film from the crease around the edge and repeat the action with a new strip of tape to pick up any dirt, adhesive or grime from the surface. This should save considerable time.
    Benji - 返信
    Thank you for including a link to the iPhone Display Adhesive Replacement guide, this was very helpful!
    Robert O'Brien - 返信
    is it really necessary to remove the display? the screen connectors are delicate and I fear re-assembly errors. I changed the battery and did not remove any screen connectors. no problems.
    jacobra - 返信
    Due to the fact that THIS is the repair guide for replacing the DISPLAY it IS necessary to remove the display connectors. There is another guide for changing the battery -- you might want to follow that one.
    Hannes -
    I did not remove the display and ended up ripping one of the lower display cable ribbons when I turned the phone to remove one of the connectors. Be careful. I had to get a new display and move the Touch ID button.
    Shawn Hime - 返信
    I think that moving the replacement of the seal lower in the chain of events would be more beneficial. I'm replacing the battery, and stretching the adhesive tabs that held the battery in at a low angle kept sticking themselves to the newly-installed adhesive seal.
    In the end, I wound up having to just remove the section of the seal along the bottom of the case :-/
    If I'd been looking at the bigger picture, I'd have wanted to put the seal on right before reattaching the screen cables.
    Rob Russell - 返信
    This guide does not show you the removal process for the top camera assembly. My screen looks like the one pictured but my replacement doesn't have the top connector or any of the front facing camera components and since the ribbon for the connectors looks like its coming out from underneath the display I can't see how to swap it over to the new display.
    Jezagee - 返信
  23. iPhone 7 Plusのスピーカーの交換, スピーカー: 手順 23、 2の画像 1 iPhone 7 Plusのスピーカーの交換, スピーカー: 手順 23、 2の画像 2
    • 薄いこじ開け用ツールもしくはピンセットを使って、身長に上部同軸ケーブルコネクタをロジックボードから引き上げて、外します。
    • 2つの同軸コネクタが近接しています。 バッテリーコネクタに最も近い方を外します。
    • 再組み立ての際は、このコネクタの再接続作業にご注意ください。コネクタをソケットの所定の位置に載せて、スパッジャーの平面側を使って押し下げます。 コネクタが所定の位置に固定されるはずです。
  24. iPhone 7 Plusのスピーカーの交換: 手順 24、 2の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 24、 2の画像 2
    • ロジックボードに同軸ケーブルを固定している小さなメタル製クリップから解放した後、ケーブルを慎重に巻き戻します。
  25. iPhone 7 Plusのスピーカーの交換: 手順 25、 2の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 25、 2の画像 2
    • ピンセットやスパッジャーの先端を使って、スピーカーの片側に同軸ケーブルを固定しているメタルクリップを解放して、ケーブルを持ち上げます。
  26. iPhone 7 Plusのスピーカーの交換: 手順 26、 1の画像 1
    • スピーカーにプラスネジを固定している5本のネジを外します。
    • 1.3 mm ネジー3本
    • 2.3 mmネジ−1本
    • 3.3 mmネジ–1本
  27. iPhone 7 Plusのスピーカーの交換: 手順 27、 1の画像 1
  28. iPhone 7 Plusのスピーカーの交換, Wi-Fiダイバーシティアンテナ: 手順 28、 1の画像 1
    • iOpenerもしくはヘアドライヤー、ヒートガンでアンテナが取り付けられている下側のスピーカー辺りを温めます。熱くなって触れない程度まで当ててください。
    • 熱をあてることで、アンテナを固定している接着剤を柔らかくすることができます。
  29. iPhone 7 Plusのスピーカーの交換: 手順 29、 3の画像 1 iPhone 7 Plusのスピーカーの交換: 手順 29、 3の画像 2 iPhone 7 Plusのスピーカーの交換: 手順 29、 3の画像 3
    • アンテナと右側のスピーカーの間に開口ピックをスライドさせて、その下に付けられた接着剤を丁寧に剥がします。
  30. iPhone 7 Plusのスピーカーの交換: 手順 30、 1の画像 1
    • スピーカーを半回転させて開口ピックを反対側からも差し込みます。
    • アンテナを固定している残りの接着剤を剥がします。
    • 必要に応じて、簡単に外れるまで接着剤を温めてください。
  31. iPhone 7 Plusのスピーカーの交換: 手順 31、 1の画像 1
    • Wi-Fiダイバーシティアンテナをスピーカーから取り出します。
終わりに
交換用のパーツとオリジナルのパーツを見比べてください。残りのコンポーネントを移植する必要があるか、パーツを装着する前に接着剤の裏張りを取る必要があります。
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
e-wasteを処理する場合は、認可済みリサイクルセンターR2を通じて廃棄してください。
修理が上手く進みませんか?トラブルシュートのヘルプには、基本的なトラブルシューティングページを参照するか、このモデルのアンサーコミュニティに尋ねてみましょう。
51 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Jeff Suovanen
メンバー登録日: 08/06/13
427,796 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,718のガイドは作成済み
6 件のコメント
Thanks Jeff, this guide helped me complete the repair, even the fiddly bits with the diversity antennae. Oh the joy of hearing the “by the seaside “ ringtone from a previously mute iPhone. :D
Kola - 返信
Hi, I have completed this but the speaker option is still not available and am not able to record videos, and basically not able to hear anything when placing a call. should i replace the earpiece speaker as well?
bhargava perni - 返信
Thank you Jeff! I followed this guide and everything went smoothly. Used this to fix my friend’s iPhone when her phone went silent. She says everything is working as it should be. Thanks again from her and I.
Maganafixes - 返信
Hallo zusammen, ich habe den Umbau wie oben vorgenommen, jedoch kommt unten kein Ton wenn mich jemand anruft. Woran kann das liegen?
Kann es noch eine andere Ursache geben außer den Lautsprecher zu tauschen?
Freue mich über eine Rückmeldung.
iannarrig - 返信
People still can’t hear me when I call. However, if I switch to loudspeaker they can. Did I miss a connection or do I need another part?
mtderosier - 返信
Can’t make calls with my 7+ unless I use airpod or ear peace only @jeffsu kindly help me
Frimpong - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 108
過去 30 日: 389
今までの合計 72,119
