THESE INSTRUCTION / GUIDE IS NOT COMPLETE. I broke my phone and ended up with $250 in repairs at the local cell phone store at this step. You need to detach the display completely instead of prop it up against a box. It is very likely your cables will tear at this step if you don’t completely detach the display
デバイスを再組み立てする際は、このインストラクションを逆の順番に従って作業を進めてください。
75 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
11 件のコメント
I need to buy the 6s replacement battery itself as well as the tools. Do you sell that as well as the display?
i remember i get my battery repair kit and adhesive for less than 25$ from this seller on amazon https://www.amazon.com/dp/B01LKN9AUG
exdany9 -
Please do a video. Lets see how fast you guys can change the 6s battery.
klactwiggy - 返信
What if I didn't get all the adhesive out from under the battery?!
Very nice and helped me a lot. Thank you.
Success. I got one adhesive strip to come out in one piece. The 2nd one snapped in half. I had to do the pry-of-shame, but once I could see the adhesive underneath the battery, I was able to grab it with the angled tweezers, and pull the rest of it out. Wow it’s a lot easier to remove the battery if you get both adhesive strips out in one piece each! I left the screen attached during the battery replacement, so I only removed the batter connector cover. Helps to have a 2nd person hold the screen so you don’t damage the connectors.
ericrose62 - 返信
