メインコンテンツにスキップ
はじめに
正面カメラとセンサーアセンブリを交換するにはこのガイドをご利用ください。
  1. iPhone 6 Plusの正面カメラとセンサーアセンブリ, ペンタロープネジ: 手順 1、 1の画像 1
    • 作業を始める前に、バッテリーの残量を25%以下まで消費してください。充電されたリチウムイオンバッテリーにアクシデントで穴を開けてしまうと、引火や爆発の原因となります。
    • iPhoneの電源を必ず切ってください。
    • Lightningコネクター両側の3.6 mmペンタロープネジ2本を外します。
    I prefer to remove the SIM card as the very first step since it's safer to do so while the phone is fully assembled.
    estebanfallasf - 返信
    I stripped one of the two screws - at a dead stop.
    Margaret Patterson - 返信
    Before you even start: get the iOpener or hairdryer out. You’ll need it
    GPZ - 返信
    If a lightning connector won’t provide a charge or needs to be wiggled carefully to provide a charge, power off the device, then try using precision tweezers to scrape the innermost wall of the lightning jack in a pinching motion to check for lint buildup. Pocket lint or other debris can accumulate inside the jack, compacting each time a cable is inserted. This can prevent a lightning cable from seating fully. Clearing the lint may restore functionality without replacing the part.
    Andrew Dolan - 返信
    A few hints:
    * heating up the phone works great. I used a heating pad that you put in the microwave to heat sports injuries.
    * also, I made a sheet to help you keep track of the screws as you remove them. Print out the page, then place double sided tape below each color-coded listing of screws, and stick the screws to the tape as you disassemble. This helps prevent losing the screws and keeps track of what screws are what for easier reassembly. https://drive.google.com/file/d/1pLSvKvB...
    Paul Faulstich - 返信
    Additional hints, for anyone who needs them:
    * stick the screws to the tape in the same positions as they are shown in the guide. This will make it easier to identify them during reassembly.
    * if the screws get mixed together, the ‘mm’ (millimetre, millimeter) measurements given in the guide can be used to identify them. Compare the lengths of the threaded shafts to each other to determine which screw is which.
    Friendly Advice -
    • 次の2つの手順ではiPhone 6 Plusを安全に開口できる素晴らしいツールiSclackの使い方を紹介します。1回だけの修理に終わらない方には最適の工具です。iSclackをご利用になられない方は次の2つの手順をスキップしてください。
    • プラスチックのデプスゲージが iSclack中央に挟まっている場合は外してください。 iPhone 6 Plusのような大型のデバイスには必要ありません。
    • iSclackのハンドルを閉じ、吸盤カップを開きます。
    • iPhone下部本体を吸盤カップの間に配置します。
    • ディスプレイ側の吸盤カップはホームボタン付近に装着します。
    • ハンドルを開いてiSclackの両カップを閉じます。吸盤カップをiPhoneの両側にしっかりと取り付けます。
    • バックガラスもしくはディスプレイの飛散状況が酷い場合は、透明な梱包用テープで表面を覆ってから吸盤カップを装着してください。iSclackには、このような目的で使用するためのテープが2枚入っています。
  2. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 3、 2の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 3、 2の画像 2
    • iPhoneをしっかりと持ち、 iSclackのハンドルを閉めながら吸盤カップを両側へ開いていきます。背面ケースからフロントパネルが引き上がってきます。
    • iSclackは安全にiPhoneを開口できるよう設計されていますが、ディスプレイケーブルに損傷を与えてしまうことがあります。
    • iPhoneから2つの吸盤カップを外します。
    • 次の3つの手順をスキップして手順7までお進みください。
    It's very difficult if you want to remove a cracked screen. The suction cup and Islack won't work. Does anybody know a better way?
    Herbert - 返信
    I use Scotch Tape, shipping tape. Put a couple of layers over the crack screen. That seals it so you can use the suction cup to remove the front of phone.
    Michael Wallace -
    I used the plastic pry took and the spudger to open it up. I place the pry tool dead center below the home button and was able to put some pressure around the seam and the top popped up enough for me to get the spudger in there to hold it open and then work my way around with the plastic pry tool.
    johnoconna -
    Apply clear packaging tape to screen. Then suction cup to that.
    Tracey -
    Use clear nontextured tape place that over the phone screen. Refer to any guide that addresses replacing a shattered screen
    Abigail Cherry - 返信
    I know it's tough with cracked glass. You just need enough to get in a plstic pry tool or guitar pick. Then you can pry it apart. Just be patient, I cannot stress that enough; the electronics are very, very small and fragile.
    Mike - 返信
  3. iPhone 6 Plusの正面カメラとセンサーアセンブリ, フロントパネルアセンブリ: 手順 4、 1の画像 1
    • iSclackをお持ちでない場合、シングルタイプの吸盤カップをつかってフロントパネルを引き上げます。
    • 吸盤カップをホームボタン上のスクリーンに押し当てます。
    • カップがスクリーンにしっかりと固定しているか確認します。
    • ディスプレイの亀裂の程度がひどい場合、吸盤カップがしっかりと装着するために、透明な梱包テープを表面に貼ってください。もしくは吸盤カップの代わりに、強力テープを使用できます。それでも上手くいかない場合は、壊れたスクリーン上に強力ボンドをつけた吸盤カップを付けて固定してください。
    Avec la ventouse, l’ouverture est brutale, tout s’est déclipsé d’un seul coup. Faire attention.
    Paul Briffaut - 返信
    English Please!
    tom mozeleski -
    With the sucker, the opening is brutal, everything was cleared at once. Pay attention. (Paul’s comment translated by Google)
    Steve Schlotter - 返信
    May need to burp the sticker before it sticks. Need to let the air out. Once Idid that, no problem. Except it was still hard to get the cover to start up.
    Patricia Tucker - 返信
    Don’t waste your time with the suction cup - it doesn’t work! insert the blade of a box cutter just below the lower screen edge below the home button and gently pry just enough to start cracking the seal.
    Stephen Smith - 返信
  4. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 5、 1の画像 1
    • 片手で iPhoneを押さえながら、吸盤カップを引き上げて、ゆっくりとリアケースからフロントパネルアセンブリを離します。
    • 時間をかけてゆっくりと、同じ強さ加減で作業を進めます。他のデバイスに比べてより強固に接着されています。
    • プラスチックの開口ツールを使って隙間に差し込み、リアケースからディスプレイアセンブリを丁寧にこじ開け、吸盤カップで持ち上げます。
    • フロントパネルアセンブリをリアケースに固定させているクリップが幾つかあります。吸盤カップとプラスチック製開口ツールの両方を使いながら、フロントパネルアセンブリを外してくださ。
    Be extra careful here. If you don’t take your time, your front panel may jerk back on you, causing you to overextend and break the front camera/mic flex cable; happened to me. Slowly peel back the front panel, opening it no more than 90º.
    Thomas - 返信
    watch out for the left side of the phone the adhesive bunches up around the inner clips, i didn’t realize it and the upper left of my screen cracked pretty bad. But this guide is awesome follow every direction to the letter
    Aaron Fitzpatrick - 返信
    Note: this comment is written for the iPhone 6 Plus, but may also apply to other models of iPhone.
    Disassembly:
    The clips in the rear case attach to small slotted shapes under the edges of the display assembly, and these attachment points alternate from one side to the other. Moving from bottom to top, gently pulling the rear case away at these points will help to separate the two halves without using too much force.
    Reassembly:
    Ensure that the plastic clips along the top edge of the front panel (shown in step 8) are fitted properly inside the rear case, then gently press the display assembly into the rear case at these points, moving from top to bottom. There may be a small click sound as the clips in the rear case engage with the slots on the display assembly, and the rear case should fit flush with the edges of the display assembly.
    Friendly Advice - 返信
    This was challenging. For me, the suction cup could only create a tiny bit of motion and at first, no actual gap at all. You might have to pull the suction cup away from the base a few times just to loosen things up a tiny bit. Eventually, I got my fingernail in, and then after a few minutes got the plastic tool in.
    Also, use the plastic tool to gently pry along the sides of the phone once there’s light there. I was afraid of using too much leverage and breaking the screen as per the other comments, but starting at the bottom and then going around the sides slowly worked for me.
    FixingMyiPhone - 返信
  5. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 6、 2の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 6、 2の画像 2
    • 吸盤カップ中央のグリップを持ち上げて、吸引力を緩めます。
    • 吸盤カップをディスプレイアセンブリから取り外します。
    There is an adhesive strip all along the edge between the top and bottom of the phone. Is that just adhesive or is it wire of some sort?
    Larry Ingerling - 返信
    @lingerling The adhesive strip was introduced on the iPhone 6s and 6s Plus (one model year later than what’s shown on this page). Guides specific to each model can be found here—be sure to use the correct one for your particular phone. And yes, just adhesive, no wires. ;)
    Jeff Suovanen - 返信
  6. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 7、 3の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 7、 3の画像 2 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 7、 3の画像 3
    • 本体上部先端を蝶番にして、背面ケースからフロントパネルアセンブリのホームボタン端を引き上げます。
    • 約90度の角度でディスプレイを開け、後ろに立て掛けて固定できる衝立を置きます。
    • ゴムバンドでディスプレイと衝立を留めて動かないようにします。これはディスプレイケーブルがアクシデントで引き伸ばされるのを防ぐためです。
    • 急ぎの場合は未開封の飲料用缶を使用できます。
    Be careful If we leave the screen connected and set it to 90 degrees, the speaker / sensor flex may break. With an opening of 60 degrees it is convenient to completely disconnect the screen. The headset's flex is short, and if we put it at 90º, it can break. Guiding me from the images of iFixit, I have broken two cables.
    Español:
    Cuidado. Si dejamos la pantalla conectada y lo ponemos a 90 grados, el flex del altavoz/sensor puede romperse. Con una abertura de 60 grados es conveniente desconectar enteramente la pantalla. El flex del auricular es corto, y si lo ponemos en 90º , se puede romper. Guiándome de las imágenes de iFixit, se me han roto dos cables.
    txaukos - 返信
    At 60º the display will block access to all the screws and the phone would be practically unserviceable, so I’m having trouble making sense of this comment. The cables on a factory original display are pretty tough and designed with enough slack that a 90º angle is no problem. Same with any decent aftermarket display.
    Jeff Suovanen - 返信
    If you look at the enlarged image, you can see how the flex cable from the camera / speaker is in tension. This is my opinion. Sorry for my bad English
    Si usted se fija en la imagen ampliada, puede ver cómo el flex cable de la cámara/altavoz está en tensión. Esta es mi opinión.
    Perdón por mi mal inglés
    txaukos - 返信
    your English isn’t the issue, it’s the proposed 60 degree opening space that doesn’t allow for the removal of the screws of the mounting plate where the connectors connect to the main pcb…
    if can make a recommendation here; it helps if the can is full and not refrigerated, the weight helps in keeping the phone where it should stay without adding additional tension to the ‘flex’ ribbon cable. it’s called flex for a reason people, if your breaking these the phones already been overheated too much, the cables become brittle and should also be replaced. i replaced my battery without disconnecting the screen, at 90 degrees with a rubber band around an empty beer can. pierced the orig. battery and caused sparks. albeit, i wasn’t in a hurry and it took me a good 30+ minutes, removal of the battery and stickers is by far the most challenging, especially when NOT disconnecting the screen…
    it’s not a race, take your time. move slowly but precisely with forethought and persistent force…
    circuitbender 477 - 返信
    Werkt dit ook voor iPhone 7(plus)?
    Christina Pegtel - 返信
    Werkt dit hetzelfde voor iPhone 7 (plus)?
  7. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 8、 2の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 8、 2の画像 2
    • フロントパネル上部に留められた幾つかのクリップを蝶番のようにして、本をめくるようにフロントパネルアセンブリを開きます。
    • 再組み立ての際は、クリップが背面ケース上部端のちょうど真下になるように配置します。それからフロントパネル上部先端と背面ケース上部先端が重なるまで上方にスライドします。
    I would recommend protecting the screen once the display is free and the suction cup has been removed. This will help avoid any possibility of accidental scratching of the display crystal while the remaining steps are being performed. I used an inexpensive screen protector then removed it after reassembling and testing are complete.
    anthonyspampinato - 返信
  8. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 9、 1の画像 1
    • 次のプラスネジをバッテリーコネクターブラケットから外します。
    • 2.3 mm プラスネジ ー1本
    • 3.1 mm プラスネジー1本
    for the iPhone 6 Plus, all screws were Phillips #000
    Michael Adams - 返信
    I had difficulty removing the 3.1mm (iPhone 6 Plus / Phillips #000); had to give it significant downward pressure to get it started.
    Allen Matheson - 返信
    stripped the 2.3mm screw attempting to remove, had to use excessive force to successfully remove
    Matthew Gao - 返信
    The Phillips bits provided in the kit would not engage the Phillips heads enough to loosen them. Luckily I had my own small screwdriver set that worked like a charm.
    David Davis - 返信
    Same issue. Could not remove the screw. Dead in the water.
    Tiffany - 返信
    Agree with above comments regarding the supplied Phillips bit. It is not the correct size.
    Use a Phillips #000.
    bobgottner - 返信
    Phillips #000 is what’s included in the kit. As others mentioned above, firm downward pressure is key. The phone is not that delicate; just press hard and crank it.
    Jeff Suovanen -
    Is this step necessary ?\
    Asianay - 返信
    @asianay0129 Yes, disconnecting the battery is necessary. You can sometimes get away with skipping it, at the risk of destroying something important and potentially bricking your phone. Not a wise gamble for the sake of skipping two screws.
    Jeff Suovanen - 返信
  9. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 10、 1の画像 1
    • iPhoneからメタル製バッテリーコネクターブラケットを取り出します。
    Was not able to remove the battery connector bracket as one of the cable connectors was glued/stuck to the underside. Instead moved the bracket out of the way to disconnect the battery. Care should be taken not to over bend/stretch the ribbon cable.
    dwtan - 返信
    That may be just the foam connector adhering to the bracket. If you pull up gently and twist slightly it should separate.
    Evan Noronha -
    It was the foam connector, and it did twist free with a gentle pull
    Al Taylor - 返信
  10. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 11、 1の画像 1
    • 爪先もしくは開口ツールの先端を使って、基板上のソケットからバッテリーコネクターの接続を外します。
    • バッテリーコネクターのみにツールを差し込んで持ち上げてください。基板のソケットに接触しないでください。コネクター全体を破損してしまうことがあります。
    you may consider placing a thin non-conductive item between the connector and the socket like a bit of rubber band to prevent any power flowing during this procedure
    Michael Adams - 返信
    It was too close to other parts to pry up with either end of plastic tool. Finally used 1 tine of tweezer to lift edge. Came free easily
    Al Taylor - 返信
    J’ai pris une loupe pour bien observer l’endroit où placer l’outil.
    Paul Briffaut - 返信
    Magnification is key for many tasks and this is certainly one.
    Kenneth Gilbert - 返信
    I couldn’t use the iFixit blue opening tool to pry that battery connector. I used the top of the black spudger near the hole where the 3.1mm screw was in step 9-10 to easily pry it open!
    Alyssa Sayuki - 返信
    The blue plastic board breaker can easily cause damage here. Professionals would recommend using the human fingernail as the ideal tool for this job.
    Jessa Jones - 返信
  11. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 12、 1の画像 1
    • フロントパネルアセンブリーのケーブルブラケットに留められたネジを外します。
    • 1.2 mm ネジー3本
    • 1.5 mm ネジー1本
    • 2.9 mm ネジー1本
    • 絶対に赤い丸印のネジ穴に長いネジを差し込まないでください。基板にダメージを与えてしまいます。
    There's an other panel with one screw in the middle.........
    Herbert - 返信
    Sounds like you have an iPhone 6s Plus, rather than a 6 Plus. Be sure to use the correct guide! And make sure you’ve ordered the correct part, as they’re not cross-compatible.
    Jeff Suovanen -
    I _love_ the color coding of screws. I know this is a little OCD, but it would be incredibly useful if there were an 8.5 X 11 you could print with indicated homes for where to drop items from each step of disassembly. That is, in the box for step 9, little colored circles for where to place each screw type. As long as you don't jostle the paper, it would make it a lot easier to know exactly where you are in reassembly.
    cscarlson47shop - 返信
    I have done the exact same thing. Created a sheet where each screw goes.
    Chris Murphy -
    I used the 000 bit from the ifixit 54 piece kit.
    hhandh - 返信
    Actually you don’t need to do steps 12 to 18 if you attach the display panel to the iPhone box as shown in step 7 and handle your iPhone with care during the replacement. I didn’t disconnect the display panel mainly because the more you work on the interior of your phone the higher is the chance you break something.
    Dany Castillo - 返信
    Since this guide is for DISPLAY replacement, I don’t see how you can skip the steps for disconnecting and removing the DISPLAY.
    Jim Bateman -
    That's what I was thinking.
    The Wizard - 返信
    I skipped this series of steps too. I was very careful when removing the battery and never had an issue with the screen leaning back against the box that this battery shipped in. I even broke half of the third strip of adhesive but used a plastic card to slide under the battery and it slowly lifted out without applying heat.
    mark - 返信
    I'm having trouble with one screw not wanting to come out. Any suggestions to keep from stripping the head and getting it?
    Patric - 返信
    which screws are which sizes cause i ordered new ones and cant figure it out
    MONsterHEIT - 返信
    I also did not see the need to remove the display assembly for this repair. However I did place a can of corn against the vertically positioned display and then secured the display to the can with a rubber band.
    whiteshephard - 返信
    I recommend removing the display assembly, I didn’t and somehow damaged the home button cable. At least remove the cover to ease the tension on the cables.
    I played around with different screwdrivers to get certain screws out. I made sure I wasn’t applying heavy pressure so I wouldn’t strip the head. Apple is crazy for doing this to us lol.
    Anyways invest in a magnetized mat to organize your screws. It was really difficult to keep things organized and still, especially with these tiny screws…
    Jeffrey Robinos - 返信
    what happens if i forgot to put the ribbon cable shield back on? the phone is now working but i forgot to put the shield back on and i am missing 2 screws. can i leave the shield off?
    Fred ticoman. - 返信
    @ticoman12 It’ll work without the shield, but the connectors may pop out unexpectedly.
    Jeff Suovanen -
    Just be really careful remembering which screw is which. I drew a quick sketch of the bracket, then put the screws in the relevant places. There’s no way I would have been able to figure them out otherwise - my eyes can’t see the difference between a 1.2 and 1.5mm screw!
    Paul Johnson - 返信
    The most fiddly part of the job.
    Much easier if you put the screwdriver head on the screw and then insert it into the opening. The slight magnetism will hold it in place. Don’t fully tighten a screw until all the screws are in place. Much like installing lug nuts on a car.
    GPZ - 返信
    I also skipped steps 12-18 as Danny had suggested. It made this repair quite easy, so thank you and others for suggesting this. I was also very careful to allow the battery to discharge before starting the process.
    Bruce Platt - 返信
    I question whether Steps 12-18 (separating the display from the case) is actually necessary? The battery can be removed/replaced with the display connected (but standing upright, as displayed in Step 7.
    Leaving the display attached obviates the most difficult steps (re-connecting the various control ribbons — 3/4 of ‘em!
    I followed this manual completely and the repair was successful. But if I had this to do over, I’d leave the display connected.
    Dana Smith - 返信
    I skipped the steps 12-18 as well and thank goodness I did so I won’t have to worry about issues with any of the cables.
    my panel is different from what is pictured anyway ‘cause I have one screw in the middle like what Herbert said on the first comment.
    Maria Filamor-Robinson - 返信
    I realized too late just how handy the magnetic mat is that they have in their shop. So I organized the screws with a piece of clear packing tape. On the smooth side, use a sharpie to draw spacious circles with “R” “O” and “Y” inside each circle to represent the color coded screws and then use the sticky side to keep the screws in place. I found that using the tweezers to take them off the screwdriver helps you stick them head first to the tape better.
    Selena Castillo - 返信
  12. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 13、 1の画像 1
    • 基板からフロントパネルアセンブリのケーブルブラケットを取り外します。
  13. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 14、 2の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 14、 2の画像 2
    • 次の4つの手順ではケーブルコネクターのみこじ開けます。基板上のケーブルコネクター用ソケットには接触しないでください。
    • フロントパネルを固定したまま、爪先もしくは開口ツールの先端を使って、正面カメラとイヤピーススピーカーのコネクタの接続を外します。
    Why does the screen need to come off?
    Sterling Coffey (N0SSC) - 返信
    Because the cables are delicate, and following steps are easier if phone halves are not flopping around together, especially for amateurs.
    Matthew Goheen - 返信
    I don't know if anyone will see this but here it goes: for the life of me I can't get the front-facing camera and earpiece speaker connector to seat. Everything else went back together fine but this one connector will not go in. Sometimes it seems like it's in even though it doesn't really pop in and it'll kinda sit there for a sec and then it pops out.
    Any insight would be greatly appreciated, thank you
    Droopy Caledonia - 返信
    Try starting at one end instead of in the middle. It's to easy to bend a connector and this way, I can get a safe start and go from there.
    Rongwey - 返信
  14. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 15、 2の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 15、 2の画像 2
    • ホームボタンケーブルコネクターの接続を外します。
  15. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 16、 2の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 16、 2の画像 2
    • この手順でケーブルの接続を外したり、再接続する前に、バッテリーの接続が外れているか必ず確認してください。
    • プラスチックの開口ツールを使って、ディスプレイデータのケーブルコネクターの接続を外します。
    • デバイスを再組み立てする際は、本体ディスプレイのデータケーブルがコネクターから飛び出すことがあります。これは電源スイッチを入れた時、黒い画面に白い線が表れる原因となります。この症状が現れた場合は一度ケーブルを再接続して、再起動してください。電話を再起動する一番ベストな方法は、バッテリーコネクターの接続を切ってから再び再接続します。
    The piece of advice about power cycling the phone by disconnecting and reconnecting the battery proved crucial to the success of my repair (camera and lens replacement). At first when charging the phone after closing it, I got a dark, blank screen with an intermittent buzzing noise. After re-opening the phone and making sure all cables had been properly reconnected, I ignored the advice to power cycle the phone. Still all I got was a dark, blank screen (and intermittent buzzing if charging t). Then I opened it a third time (leaving the screen connected and attached at a 90 degree angle) and I only disconnected and reconnected the battery. Voila! When I closed the phone and powered it up, I got the screen to light up!
    Gianni - 返信
    how did you disconnect and reconnect the battery?
    Teresa Trevino - 返信
    If you’ve been following the guide, you already disconnected it in this step. To reconnect it, just line up the connector and press it into place.
    Jeff Suovanen -
    After replacing the battery, the phone seems dead. I thought it just needed recharging so I left it charging all night. Still dead in the morning. Now I think it might be because the display data cable is off, and I should open the phone and check it. But the battery might be on full power in that case, and they don’t advice to open the phone when battery if full. What can I do?
    Ila Awasthi - 返信
  16. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 17、 2の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 17、 2の画像 2
    • 最後に、デジタライザーケーブルコネクターの接続を外します。
    • デジタイザーケーブルを再接続する際は、コネクターの中央部分を押さないでください。コネクターの端一方を押してから、もう片方を押し込みます。コネクターの中央を押してしまうと、コンポーネントを曲げてしまい、デジタイザーにダメージを与えてしまうことがあります。
    some images and guidance regarding reassembly would be helpful. You don't need to use the spudger to get them back on: fingers are better because there's a really subtle click you feel when you get them seated properly.
    When you're reassembling, a note that this is the step where you should test for proper screen function would be really useful. First time I reassembled, I didn't seat something properly, got all the screws back together and then realized the screen wasn't functioning properly. Had to disassemble back down to step 14 and then re-reassemble.
    I am having this issues right now! I have unplugged and plugged in these cables at least 20 times and each time I get white lines. I finally have it to where there are only 4 white lines and I am almost willing to live with it. Any suggestions?
    mattmay002 -
    Clean the screen connectors incase they are not making a clean connection
    Karen Jones - 返信
    I'm having nightmares with the digitizer connector. Simply can't get it to work unless I'm applying some pressure on the connectors. Everything seems almost microscopically clean. Any suggestions friends?
    Henry A -
    could it be the replacement screen? test with your old screen and see if you have the same problem.
    Charles - 返信
    To ++mattmay002++  Did you power cycle the phone? Check out the comments on the previous step for a how to.
    Robert Liles - 返信
    I had issues with it too. When connecting this cable, make sure to rock finger side to side after connecting. It’s a wide connector so try to listen for 2 clicks on this one connector. That’s how I fixed mine
    Albert Einstein - 返信
    Re-attaching this cable is the only tricky part to replacing the battery on my 6+. It had a bow on the middle that I had to flatten out before pressing the connector on with finger first on one edge and then on the other. I had white tire tracks on the screen and no touch screen until I connected it correctly. The front has to rest in just the right place on the back while attaching this thing so the cables aren’t strained the front doesn’t fall down. Small fingers would be a plus at this step.
    richard - 返信
    Reseating these connectors on reassembly is definitely the most difficult part of this repair. It took me several attempts before the lowermost connector would seat properly and I did accidentally bend it slightly in the process. Fortunately I was able to get it straight again and get it to click in. The other three went in fine though and no lasting damage seems to have been done.
    Andy Gibbons - 返信
    Another thing - These cables can become overlapped in the wrong way and make you think they are in a different order than they should be. Eg. it’s easy to mix up the ones from step 15 and 17. You can actually unravel the cables and re-layer them on top of each other in any order, so remember this! They look like they’re one solid mass but they’re not.
    domarius - 返信
    I never removed the last digitizer connctor. I removed the first three connectors, left the screen propped at 90 deg tied to a box and removed the battery, there is minimal movement. In fact when I reattached the connectors, only the first and maybe second connector feels taut, so it’s necessary to only remove the first connector if you can be gentle with it. Less headache. And my guess why so many people had issues is that micro dust gets into the connectors and cause connection loss. You be surprised how little dust can cause havoc.
    darrcc - 返信
    And forgot one thing, keep a can of air duster woth you to remove as must dust as you can see. A camera air blower will also do nice.
    darrcc - 返信
    I haven’t removed my screen in past battery replacements, I found it easier. However, this time I followed the instructions because my old battery was very stuck, and I needed the screen gone to get the battery out…
    When I replaced the screen, at first it wouldn’t even boot/start up. (Yes, I inserted my own testing step, as someone here suggested, before final reassembly).
    The screen would just show a fuzzy image, and the board that all the cables attach to would heat up, then it would turn itself off. I tried reconnecting them carefully 3 times, and even made sure to get a little “click”, all to no avail.
    The final try, I used my fingernail to really press down on the back side of the digitizer cable. I heard more clicking, though I thought I might be tearing the cable too. With nothing left to lose, I continued across the back, and heard several more clicking/tearing sounds.
    This worked, and it booted after that. It still had white lines, but those faded away overnight.
    Morgan Giddings - 返信
    About the digitizer connector: its flat cable is so short that the when I attempted to seat the next connector, its flat cable pressed on the digitizer cable, which can pull on the connector and dislodge it. That happened several times for me before success.
    Robert Bernard 27 Nov 19
    Robert H Bernard - 返信
    Nous n’apercevons pas bien les nappes et l’ordre dans lesquelles elles doivent être replacer
    Patrick AZOULAY - 返信
  17. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 18、 1の画像 1
    • リアケースからフロントパネルアセンブリを取り出します。
    Never remove the screen without disconnecting the battery. It's possible the back light can be blown and that's a even more difficult repair. Always, ALWAYS, disconnect battery before repairing items. (Unless it's not possible.)
    Marvin Ballard - 返信
    How do you disconnect the battery from the screen?
    Shamil Bhatti -
    The Step 11 disconnects the battery :)
    jeffxtechs - 返信
    I think you mean Step 8 :)
    Jeff Suovanen -
    I tried it once and
    Brian - 返信
    And what? I tried it once and here’s a million dollars?
    Oh I get it… they got him! :(
    https://www.youtube.com/watch?v=UlznqpBg...
    domarius -
    When disassembling the iphone at this point note the cables, and there placement/orientation.
    GERARD SZAREK - 返信
    Be really careful with the step after this. Do not commence until you have read all the comments. You need to get a good hold of the plastic strips preferably before they double over on themselves. You have to avoid puncturing the battery at all costs. Slowness and caution here will save you a lot of long term pain.
    Laura Houghton - 返信
  18. iPhone 6 Plusの正面カメラとセンサーアセンブリ, イヤピーススピーカー: 手順 19、 1の画像 1
    • コンポーネントブラケット上部に留められている次のネジを外します。
    • 1.5 mm プラスネジー1本
    • 2.3 mm プラスネジー2本
    Nice move, which can stop the bracket from falling down.quite detailed instruction. but you should choice an excellent front facing camera and sensor before the replacement.
    William - 返信
    Attempted this repair and my touch screen completely stopped working. Great walkthrough, but not sure what I did wrong in the repair to cause my issue.
    surfincubus86 - 返信
    Hi I've had exactly the same problem, what was your solution to this? would be very helpful!
    Iona -
    I had the same issue. My screen quit working and I could feel heat coming through my phone at the earpiece. I took the phone apart again and realized that the data cable for the screen had come loose. When I reattached the data cable and starting working steps 12-18 backwards to replace the shield, as noted in the very last step, I see that youhave to keep the screen at an inclinewhen replacing the shield over the cables. Otherwise, you stretch the display data cable and it can come loose. My screen works fine now and there is no heat coming from my earpiece.
    Angela Hall -
    Just completed this repair. My front facing microphone next to the ear piece had gone bad causing siri to not hear me and front facing videos had no sound. Definitely reccomend getting replacement parts from ifixit. Have had good experiences with all their parts unlike many other suppliers on the internet. Hate to admit it (don't want them to raise prices) but even though you pay a little bit more, you save frustration not getting DOA parts from cheaper sources. All of ifixit's parts are top quality and they even pack them in anti-static packaging. That says alot. Thanks ifixit!
    sherwood7 - 返信
    Great instructions save the later steps. The ear speaker piece having to bend 180 degrees for the installation needs more clarification.
    howchewdoin - 返信
    After this repair, my screen quit working and I could feel heat coming through my phone at the earpiece. I took the phone apart again and realized that the data cable for the screen had come loose. When I reattached the data cable and starting working steps 12-18 backwards to replace the shield, as noted in the very last step, I see that you have to keep the screen at an incline when replacing the shield over the cables. Otherwise, you stretch the display data cable and it can come loose. My screen works fine now and there is no heat coming from my earpiece.
    Angela Hall - 返信
    The middle screw, listed as a 2.3mm was actually a 2.9mm in my iPhone 6 Plus
    Matthew Goheen - 返信
  19. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 20、 1の画像 1
    • ディスプレイアセンブリからイヤピースブラケットを取り外します。
  20. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 21、 1の画像 1
    • スパッジャーの平面側先端を使って、正面カメラとディスプレイケーブルをこじ開け、丁寧に邪魔にならない位置へ移動させます。
  21. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 22、 1の画像 1
    • ピンセットの先端を使って、イヤピーススピーカーをしっかりと固定して持ち、ディスプレイアセンブリから取り外します。
  22. iPhone 6 Plusの正面カメラとセンサーアセンブリ, 正面カメラとセンサーアセンブリ: 手順 23、 2の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ, 正面カメラとセンサーアセンブリ: 手順 23、 2の画像 2
    • スパッジャーの先端を使って、ディスプレイアセンブリの角からセンサーケーブルアセンブリを引き上げていきます。
    • ケーブルは適度な接着剤で留められています。
    Use a hair dryer to pre-heat and soften the adhesive. Otherwise, damage to the flex cable can occur.
    Rajat Sewal - 返信
  23. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 24、 2の画像 1 iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 24、 2の画像 2
    • ディスプレイアセンブリから正面カメラとセンサーケーブルのマイク部分を取り外します。
    Das Mikrofonkabel ist mit einem Klebeband am Display besfestigt und muss durch anwärmen weich gemacht werden. Sonst besteht die Gefahr, dass beim Abziehen das Flachbandkabel beschädigt wird. Gruß Mike
    Mike - 返信
    Bei meinem iPhone 6 Plus hörte das Kabel direkt vor der Gummiumrandung und nach dem Mikrofon auf. Auch das Ersatzteil ging nur bis dahin. Man musste also den Teil mit der Gummiumrandung nicht ablösen.
    gaby - 返信
  24. iPhone 6 Plusの正面カメラとセンサーアセンブリ: 手順 25、 1の画像 1
    • 正面カメラとセンサーケーブルアセンブリをディスプレイアセンブリから取り出します。
    • 交換用のアセンブリにスピーカー用のメッシュがインストールされている場合があります。(インストールされていない場合もあります。)付いていない場合は、古いアセンブリから取り出して移植してください。ヘアドライヤーを使って温めて、ピンセットで慎重に剥がすかこじ開けて外します。
終わりに
デバイスを元に戻すにはこれらのインストラクションを逆の順番に従って作業を進めてください。
119 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
Walter Galan
676,871 ポイント
1,203のガイドは作成済み
12 件のコメント
My front microphone had completely stopped working exactly a week out of warranty. I replaced the front assembly with a new one from Fixit and afterwards it still did not work. Then I realized the microphone did pick up very soft sound if I shouted directly into it. I eventually repeated the entire disassembly and found a very thin yellow film glued to the microphone grill which had been muffling 97% of the sound. After peeling this off my microphone is working perfectly! I did not notice this on the microphone the first time and assume it was the backing for the self adhesive. Make sure you remove this - it is not obvious to spot!
Anthony Berkow - 返信
ave did wrongSo I replaced my iphone 6 plus screen and after i was done my front camera and my earpiece was no longer working. Any advice on what i might have did wrong ? I have another iphone plus to replace the screen and im a little skeptical now. =\
brian - 返信
Fantastic instructions! fixed my problem first time. Just be patient and try not to touch anything to roughly. Thanks for the tip from a previous comment saying to remove the yellow piece of film over the microphone. This saved me a lot of hassle. Thanks
Glad to have siri, dictation, sound in videos and hansfree calls back :)
lloyd - 返信
hi could i ask one qustion my iphone 6pluse not working after fall i change new sensore bu tnot working how to fix please conect to me
peth - 返信
Is the picture quality the same
QuentaviouS - 返信
I have followed the directions. However, my screen now has vertical lines all through it. Did I ruin a sensor or did I not connect something right. The touch screen doesn't seem to work anymore either.
Thomas Miller - 返信
You should probably start by disconnecting the battery and re-seating all the display cable connectors (disconnect them and then carefully re-connect them, making sure they snap fully into place). Re-connect the battery and try again. If that doesn't do the trick, post your question in our help forum—you'll get much quicker/better responses there!
Jeff Suovanen -
I phone 6 plus This front camera is real? pls inform this mail: visual8697@gmail.com
visual - 返信
Hi everyone, is there any way to disassemble/separate the front facing camera from the sensor (without damaging it)?
Erick Pandjaitan - 返信
Hi everyone. I need help on an iPhone 6 Plus front facing camera not working. But when I take the screen out and put to another iPhone 6 Plus it work. So that mean the not working phone has the logic board problem with front facing camera connector???? I guarantee the facing camera on the screen is worked
Jack nguyen - 返信
Works like a charm. Thanks for the detailed and very clear step-by-step guide. This was my first DIY iPhone repair experience. Took me about 1.5h from start to finish, and I found it essential to have a good lighting.
Step 24 was the trickiest: the microphone portion is strongly glued to the front grill, and one should be careful not to destroy the adhesive, as it will be needed to hold in place the replacement microphone (and, I'm guessing, also to maintain moisture protection after the repair).
@closetedgeek - 返信
I have replaced my iPhone 6 Plus screen done with all steps besides plugging in seems cables aren’t long enough or I did something wrong ??? Any idea what I did wrong ?
Dustin p - 返信
コメントを追加
統計データを表示:
過去 24時間: 4
過去 7 日: 54
過去 30 日: 192
今までの合計 119,306
