メインコンテンツにスキップ
iPhone 6 Plusのリアケースの交換
必要な工具と部品
  1. iPhone 6 Plusのリアケースの交換, ペンタロープネジ: 手順 1、 1の画像 1
    • 作業を始める前に、バッテリーの残量を25%以下まで消費してください。充電されたリチウムイオンバッテリーにアクシデントで穴を開けてしまうと、引火や爆発の原因となります。
    • iPhoneの電源を必ず切ってください。
    • Lightningコネクター両側の3.6 mmペンタロープネジ2本を外します。
    I prefer to remove the SIM card as the very first step since it's safer to do so while the phone is fully assembled.
    estebanfallasf - 返信
    I stripped one of the two screws - at a dead stop.
    Margaret Patterson - 返信
    Before you even start: get the iOpener or hairdryer out. You’ll need it
    GPZ - 返信
    If a lightning connector won’t provide a charge or needs to be wiggled carefully to provide a charge, power off the device, then try using precision tweezers to scrape the innermost wall of the lightning jack in a pinching motion to check for lint buildup. Pocket lint or other debris can accumulate inside the jack, compacting each time a cable is inserted. This can prevent a lightning cable from seating fully. Clearing the lint may restore functionality without replacing the part.
    Andrew Dolan - 返信
    A few hints:
    * heating up the phone works great. I used a heating pad that you put in the microwave to heat sports injuries.
    * also, I made a sheet to help you keep track of the screws as you remove them. Print out the page, then place double sided tape below each color-coded listing of screws, and stick the screws to the tape as you disassemble. This helps prevent losing the screws and keeps track of what screws are what for easier reassembly. https://drive.google.com/file/d/1pLSvKvB...
    Paul Faulstich - 返信
    Additional hints, for anyone who needs them:
    * stick the screws to the tape in the same positions as they are shown in the guide. This will make it easier to identify them during reassembly.
    * if the screws get mixed together, the ‘mm’ (millimetre, millimeter) measurements given in the guide can be used to identify them. Compare the lengths of the threaded shafts to each other to determine which screw is which.
    Friendly Advice -
  2. iPhone 6 Plusのリアケースの交換, リバースクランプの使用方法: 手順 2、 3の画像 1 iPhone 6 Plusのリアケースの交換, リバースクランプの使用方法: 手順 2、 3の画像 2 iPhone 6 Plusのリアケースの交換, リバースクランプの使用方法: 手順 2、 3の画像 3
    • 次の3つの手順では、デバイスの開口作業を簡単にするために開発されたツール、リバースクランプの使い方を紹介します。リバースクランプを使用しない場合は、この3つの手順をスキップして別の方法をご覧ください。
    • リバースクランプの詳細な使用方法については、 こちらのガイドをご覧ください。
    • 青いハンドルを後方に引き、リバースクランプのアームのロックを解除します。
    • iPhoneの左/右側の端に向けてアームをスライドします。
    • 吸盤カップを、ホームボタンすぐ上のiPhoneの下端付近に装着します。上部に一つ、下部に1つずつ取り付けます。
    • 両側のカップをしっかりと押し付けて、取り付けたい位置に装着します。
    • 作業中のデバイス表面が滑りやすく、吸盤がうまく装着できない場合は、梱包用テープを表面に貼ると、よりグリップ力を強めることができます。
  3. iPhone 6 Plusのリアケースの交換: 手順 3、 3の画像 1 iPhone 6 Plusのリアケースの交換: 手順 3、 3の画像 2 iPhone 6 Plusのリアケースの交換: 手順 3、 3の画像 3
    • 青いハンドルを手前に引くと、アームがロックされます。
    • ハンドルを時計回りに360度回転させ、カップが両側をストレッチするまで回し続けます。
    • 吸盤カップ両側の位置が合っていることを確認してください。位置がずれてきた場合は、吸盤を少し緩めてアームの位置を合わせてください。
    • クランプで十分な隙間が作れたら、スクリーンのプラスチックベゼルの下にオープニングピックを挿入します。
    • クランプで十分な隙間が作れない場合は、さらに接着面に熱を当てて、クランプを1/4程度時計回りに回してください。
    • 一回ごとの作業で1/4以上回さないでください。クランプをまわしたら数秒間待ってください。リバースクランプの効果を待ってから、作業を続けてください。
    • 次の3つの手順をスキップして手順7までお進みください。
    Use clear nontextured tape place that over the phone screen. Refer to any guide that addresses replacing a shattered screen
    Abigail Cherry - 返信
    I know it's tough with cracked glass. You just need enough to get in a plstic pry tool or guitar pick. Then you can pry it apart. Just be patient, I cannot stress that enough; the electronics are very, very small and fragile.
    Mike - 返信
  4. iPhone 6 Plusのリアケースの交換, フロントパネルアセンブリ: 手順 4、 1の画像 1
    • シングルタイプの吸盤カップを使って、フロントパネルを引き上げます。
    • 吸盤カップをホームボタン上のスクリーンに押し当てます。
    • カップがスクリーンにしっかりと固定しているか確認します。
    • ディスプレイの亀裂の程度がひどい場合、吸盤カップがしっかりと装着するために、透明な梱包テープを表面に貼ってください。もしくは吸盤カップの代わりに、強力テープを使用できます。それでも上手くいかない場合は、壊れたスクリーン上に強力ボンドをつけた吸盤カップを付けて固定してください。
    Avec la ventouse, l’ouverture est brutale, tout s’est déclipsé d’un seul coup. Faire attention.
    Paul Briffaut - 返信
    English Please!
    tom mozeleski -
    With the sucker, the opening is brutal, everything was cleared at once. Pay attention. (Paul’s comment translated by Google)
    Steve Schlotter - 返信
    May need to burp the sticker before it sticks. Need to let the air out. Once Idid that, no problem. Except it was still hard to get the cover to start up.
    Patricia Tucker - 返信
    Don’t waste your time with the suction cup - it doesn’t work! insert the blade of a box cutter just below the lower screen edge below the home button and gently pry just enough to start cracking the seal.
    Stephen Smith - 返信
  5. iPhone 6 Plusのリアケースの交換: 手順 5、 1の画像 1
    • 片手で iPhoneを押さえながら、吸盤カップを引き上げて、ゆっくりとリアケースからフロントパネルアセンブリを離します。
    • 時間をかけてゆっくりと、同じ強さ加減で作業を進めます。他のデバイスに比べてより強固に接着されています。
    • プラスチックの開口ツールを使って隙間に差し込み、リアケースからディスプレイアセンブリを丁寧にこじ開け、吸盤カップで持ち上げます。
    • フロントパネルアセンブリをリアケースに固定させているクリップが幾つかあります。吸盤カップとプラスチック製開口ツールの両方を使いながら、フロントパネルアセンブリを外してくださ。
    Be extra careful here. If you don’t take your time, your front panel may jerk back on you, causing you to overextend and break the front camera/mic flex cable; happened to me. Slowly peel back the front panel, opening it no more than 90º.
    Thomas - 返信
    watch out for the left side of the phone the adhesive bunches up around the inner clips, i didn’t realize it and the upper left of my screen cracked pretty bad. But this guide is awesome follow every direction to the letter
    Aaron Fitzpatrick - 返信
    Note: this comment is written for the iPhone 6 Plus, but may also apply to other models of iPhone.
    Disassembly:
    The clips in the rear case attach to small slotted shapes under the edges of the display assembly, and these attachment points alternate from one side to the other. Moving from bottom to top, gently pulling the rear case away at these points will help to separate the two halves without using too much force.
    Reassembly:
    Ensure that the plastic clips along the top edge of the front panel (shown in step 8) are fitted properly inside the rear case, then gently press the display assembly into the rear case at these points, moving from top to bottom. There may be a small click sound as the clips in the rear case engage with the slots on the display assembly, and the rear case should fit flush with the edges of the display assembly.
    Friendly Advice - 返信
    This was challenging. For me, the suction cup could only create a tiny bit of motion and at first, no actual gap at all. You might have to pull the suction cup away from the base a few times just to loosen things up a tiny bit. Eventually, I got my fingernail in, and then after a few minutes got the plastic tool in.
    Also, use the plastic tool to gently pry along the sides of the phone once there’s light there. I was afraid of using too much leverage and breaking the screen as per the other comments, but starting at the bottom and then going around the sides slowly worked for me.
    FixingMyiPhone - 返信
  6. iPhone 6 Plusのリアケースの交換: 手順 6、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 6、 2の画像 2
    • 吸盤カップ中央のグリップを持ち上げて、吸引力を緩めます。
    • 吸盤カップをディスプレイアセンブリから取り外します。
    There is an adhesive strip all along the edge between the top and bottom of the phone. Is that just adhesive or is it wire of some sort?
    Larry Ingerling - 返信
    @lingerling The adhesive strip was introduced on the iPhone 6s and 6s Plus (one model year later than what’s shown on this page). Guides specific to each model can be found here—be sure to use the correct one for your particular phone. And yes, just adhesive, no wires. ;)
    Jeff Suovanen - 返信
  7. iPhone 6 Plusのリアケースの交換: 手順 7、 3の画像 1 iPhone 6 Plusのリアケースの交換: 手順 7、 3の画像 2 iPhone 6 Plusのリアケースの交換: 手順 7、 3の画像 3
    • 本体上部先端を蝶番にして、背面ケースからフロントパネルアセンブリのホームボタン端を引き上げます。
    • 約90度の角度でディスプレイを開け、後ろに立て掛けて固定できる衝立を置きます。
    • ゴムバンドでディスプレイと衝立を留めて動かないようにします。これはディスプレイケーブルがアクシデントで引き伸ばされるのを防ぐためです。
    • 急ぎの場合は未開封の飲料用缶を使用できます。
    Be careful If we leave the screen connected and set it to 90 degrees, the speaker / sensor flex may break. With an opening of 60 degrees it is convenient to completely disconnect the screen. The headset's flex is short, and if we put it at 90º, it can break. Guiding me from the images of iFixit, I have broken two cables.
    Español:
    Cuidado. Si dejamos la pantalla conectada y lo ponemos a 90 grados, el flex del altavoz/sensor puede romperse. Con una abertura de 60 grados es conveniente desconectar enteramente la pantalla. El flex del auricular es corto, y si lo ponemos en 90º , se puede romper. Guiándome de las imágenes de iFixit, se me han roto dos cables.
    txaukos - 返信
    At 60º the display will block access to all the screws and the phone would be practically unserviceable, so I’m having trouble making sense of this comment. The cables on a factory original display are pretty tough and designed with enough slack that a 90º angle is no problem. Same with any decent aftermarket display.
    Jeff Suovanen - 返信
    If you look at the enlarged image, you can see how the flex cable from the camera / speaker is in tension. This is my opinion. Sorry for my bad English
    Si usted se fija en la imagen ampliada, puede ver cómo el flex cable de la cámara/altavoz está en tensión. Esta es mi opinión.
    Perdón por mi mal inglés
    txaukos - 返信
    your English isn’t the issue, it’s the proposed 60 degree opening space that doesn’t allow for the removal of the screws of the mounting plate where the connectors connect to the main pcb…
    if can make a recommendation here; it helps if the can is full and not refrigerated, the weight helps in keeping the phone where it should stay without adding additional tension to the ‘flex’ ribbon cable. it’s called flex for a reason people, if your breaking these the phones already been overheated too much, the cables become brittle and should also be replaced. i replaced my battery without disconnecting the screen, at 90 degrees with a rubber band around an empty beer can. pierced the orig. battery and caused sparks. albeit, i wasn’t in a hurry and it took me a good 30+ minutes, removal of the battery and stickers is by far the most challenging, especially when NOT disconnecting the screen…
    it’s not a race, take your time. move slowly but precisely with forethought and persistent force…
    circuitbender 477 - 返信
    Werkt dit ook voor iPhone 7(plus)?
    Christina Pegtel - 返信
    Werkt dit hetzelfde voor iPhone 7 (plus)?
  8. iPhone 6 Plusのリアケースの交換: 手順 8、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 8、 2の画像 2
    • フロントパネル上部に留められた幾つかのクリップを蝶番のようにして、本をめくるようにフロントパネルアセンブリを開きます。
    • 再組み立ての際は、クリップが背面ケース上部端のちょうど真下になるように配置します。それからフロントパネル上部先端と背面ケース上部先端が重なるまで上方にスライドします。
    I would recommend protecting the screen once the display is free and the suction cup has been removed. This will help avoid any possibility of accidental scratching of the display crystal while the remaining steps are being performed. I used an inexpensive screen protector then removed it after reassembling and testing are complete.
    anthonyspampinato - 返信
  9. iPhone 6 Plusのリアケースの交換: 手順 9、 1の画像 1
    • 次のプラスネジをバッテリーコネクターブラケットから外します。
    • 2.3 mm プラスネジ ー1本
    • 3.1 mm プラスネジー1本
    for the iPhone 6 Plus, all screws were Phillips #000
    Michael Adams - 返信
    I had difficulty removing the 3.1mm (iPhone 6 Plus / Phillips #000); had to give it significant downward pressure to get it started.
    Allen Matheson - 返信
    stripped the 2.3mm screw attempting to remove, had to use excessive force to successfully remove
    Matthew Gao - 返信
    The Phillips bits provided in the kit would not engage the Phillips heads enough to loosen them. Luckily I had my own small screwdriver set that worked like a charm.
    David Davis - 返信
    Same issue. Could not remove the screw. Dead in the water.
    Tiffany - 返信
    Agree with above comments regarding the supplied Phillips bit. It is not the correct size.
    Use a Phillips #000.
    bobgottner - 返信
    Phillips #000 is what’s included in the kit. As others mentioned above, firm downward pressure is key. The phone is not that delicate; just press hard and crank it.
    Jeff Suovanen -
    Is this step necessary ?\
    Asianay - 返信
    @asianay0129 Yes, disconnecting the battery is necessary. You can sometimes get away with skipping it, at the risk of destroying something important and potentially bricking your phone. Not a wise gamble for the sake of skipping two screws.
    Jeff Suovanen - 返信
  10. iPhone 6 Plusのリアケースの交換: 手順 10、 1の画像 1
    • iPhoneからメタル製バッテリーコネクターブラケットを取り出します。
    Was not able to remove the battery connector bracket as one of the cable connectors was glued/stuck to the underside. Instead moved the bracket out of the way to disconnect the battery. Care should be taken not to over bend/stretch the ribbon cable.
    dwtan - 返信
    That may be just the foam connector adhering to the bracket. If you pull up gently and twist slightly it should separate.
    Evan Noronha -
    It was the foam connector, and it did twist free with a gentle pull
    Al Taylor - 返信
  11. iPhone 6 Plusのリアケースの交換: 手順 11、 1の画像 1
    • 爪先もしくは開口ツールの先端を使って、基板上のソケットからバッテリーコネクターの接続を外します。
    • バッテリーコネクターのみにツールを差し込んで持ち上げてください。基板のソケットに接触しないでください。コネクター全体を破損してしまうことがあります。
    you may consider placing a thin non-conductive item between the connector and the socket like a bit of rubber band to prevent any power flowing during this procedure
    Michael Adams - 返信
    It was too close to other parts to pry up with either end of plastic tool. Finally used 1 tine of tweezer to lift edge. Came free easily
    Al Taylor - 返信
    J’ai pris une loupe pour bien observer l’endroit où placer l’outil.
    Paul Briffaut - 返信
    Magnification is key for many tasks and this is certainly one.
    Kenneth Gilbert - 返信
    I couldn’t use the iFixit blue opening tool to pry that battery connector. I used the top of the black spudger near the hole where the 3.1mm screw was in step 9-10 to easily pry it open!
    Alyssa Sayuki - 返信
    The blue plastic board breaker can easily cause damage here. Professionals would recommend using the human fingernail as the ideal tool for this job.
    Jessa Jones - 返信
  12. iPhone 6 Plusのリアケースの交換: 手順 12、 1の画像 1
    • フロントパネルアセンブリーのケーブルブラケットに留められたネジを外します。
    • 1.2 mm ネジー3本
    • 1.5 mm ネジー1本
    • 2.9 mm ネジー1本
    • 絶対に赤い丸印のネジ穴に長いネジを差し込まないでください。基板にダメージを与えてしまいます。
    There's an other panel with one screw in the middle.........
    Herbert - 返信
    Sounds like you have an iPhone 6s Plus, rather than a 6 Plus. Be sure to use the correct guide! And make sure you’ve ordered the correct part, as they’re not cross-compatible.
    Jeff Suovanen -
    I _love_ the color coding of screws. I know this is a little OCD, but it would be incredibly useful if there were an 8.5 X 11 you could print with indicated homes for where to drop items from each step of disassembly. That is, in the box for step 9, little colored circles for where to place each screw type. As long as you don't jostle the paper, it would make it a lot easier to know exactly where you are in reassembly.
    cscarlson47shop - 返信
    I have done the exact same thing. Created a sheet where each screw goes.
    Chris Murphy -
    I used the 000 bit from the ifixit 54 piece kit.
    hhandh - 返信
    Actually you don’t need to do steps 12 to 18 if you attach the display panel to the iPhone box as shown in step 7 and handle your iPhone with care during the replacement. I didn’t disconnect the display panel mainly because the more you work on the interior of your phone the higher is the chance you break something.
    Dany Castillo - 返信
    Since this guide is for DISPLAY replacement, I don’t see how you can skip the steps for disconnecting and removing the DISPLAY.
    Jim Bateman -
    That's what I was thinking.
    The Wizard - 返信
    I skipped this series of steps too. I was very careful when removing the battery and never had an issue with the screen leaning back against the box that this battery shipped in. I even broke half of the third strip of adhesive but used a plastic card to slide under the battery and it slowly lifted out without applying heat.
    mark - 返信
    I'm having trouble with one screw not wanting to come out. Any suggestions to keep from stripping the head and getting it?
    Patric - 返信
    which screws are which sizes cause i ordered new ones and cant figure it out
    MONsterHEIT - 返信
    I also did not see the need to remove the display assembly for this repair. However I did place a can of corn against the vertically positioned display and then secured the display to the can with a rubber band.
    whiteshephard - 返信
    I recommend removing the display assembly, I didn’t and somehow damaged the home button cable. At least remove the cover to ease the tension on the cables.
    I played around with different screwdrivers to get certain screws out. I made sure I wasn’t applying heavy pressure so I wouldn’t strip the head. Apple is crazy for doing this to us lol.
    Anyways invest in a magnetized mat to organize your screws. It was really difficult to keep things organized and still, especially with these tiny screws…
    Jeffrey Robinos - 返信
    what happens if i forgot to put the ribbon cable shield back on? the phone is now working but i forgot to put the shield back on and i am missing 2 screws. can i leave the shield off?
    Fred ticoman. - 返信
    @ticoman12 It’ll work without the shield, but the connectors may pop out unexpectedly.
    Jeff Suovanen -
    Just be really careful remembering which screw is which. I drew a quick sketch of the bracket, then put the screws in the relevant places. There’s no way I would have been able to figure them out otherwise - my eyes can’t see the difference between a 1.2 and 1.5mm screw!
    Paul Johnson - 返信
    The most fiddly part of the job.
    Much easier if you put the screwdriver head on the screw and then insert it into the opening. The slight magnetism will hold it in place. Don’t fully tighten a screw until all the screws are in place. Much like installing lug nuts on a car.
    GPZ - 返信
    I also skipped steps 12-18 as Danny had suggested. It made this repair quite easy, so thank you and others for suggesting this. I was also very careful to allow the battery to discharge before starting the process.
    Bruce Platt - 返信
    I question whether Steps 12-18 (separating the display from the case) is actually necessary? The battery can be removed/replaced with the display connected (but standing upright, as displayed in Step 7.
    Leaving the display attached obviates the most difficult steps (re-connecting the various control ribbons — 3/4 of ‘em!
    I followed this manual completely and the repair was successful. But if I had this to do over, I’d leave the display connected.
    Dana Smith - 返信
    I skipped the steps 12-18 as well and thank goodness I did so I won’t have to worry about issues with any of the cables.
    my panel is different from what is pictured anyway ‘cause I have one screw in the middle like what Herbert said on the first comment.
    Maria Filamor-Robinson - 返信
    I realized too late just how handy the magnetic mat is that they have in their shop. So I organized the screws with a piece of clear packing tape. On the smooth side, use a sharpie to draw spacious circles with “R” “O” and “Y” inside each circle to represent the color coded screws and then use the sticky side to keep the screws in place. I found that using the tweezers to take them off the screwdriver helps you stick them head first to the tape better.
    Selena Castillo - 返信
  13. iPhone 6 Plusのリアケースの交換: 手順 13、 1の画像 1
    • 基板からフロントパネルアセンブリのケーブルブラケットを取り外します。
  14. iPhone 6 Plusのリアケースの交換: 手順 14、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 14、 2の画像 2
    • 次の4つの手順ではケーブルコネクターのみこじ開けます。基板上のケーブルコネクター用ソケットには接触しないでください。
    • フロントパネルを固定したまま、爪先もしくは開口ツールの先端を使って、正面カメラとイヤピーススピーカーのコネクタの接続を外します。
    Why does the screen need to come off?
    Sterling Coffey (N0SSC) - 返信
    Because the cables are delicate, and following steps are easier if phone halves are not flopping around together, especially for amateurs.
    Matthew Goheen - 返信
    I don't know if anyone will see this but here it goes: for the life of me I can't get the front-facing camera and earpiece speaker connector to seat. Everything else went back together fine but this one connector will not go in. Sometimes it seems like it's in even though it doesn't really pop in and it'll kinda sit there for a sec and then it pops out.
    Any insight would be greatly appreciated, thank you
    Droopy Caledonia - 返信
    Try starting at one end instead of in the middle. It's to easy to bend a connector and this way, I can get a safe start and go from there.
    Rongwey - 返信
  15. iPhone 6 Plusのリアケースの交換: 手順 15、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 15、 2の画像 2
    • ホームボタンケーブルコネクターの接続を外します。
  16. iPhone 6 Plusのリアケースの交換: 手順 16、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 16、 2の画像 2
    • この手順でケーブルの接続を外したり、再接続する前に、バッテリーの接続が外れているか必ず確認してください。
    • プラスチックの開口ツールを使って、ディスプレイデータのケーブルコネクターの接続を外します。
    • デバイスを再組み立てする際は、本体ディスプレイのデータケーブルがコネクターから飛び出すことがあります。これは電源スイッチを入れた時、黒い画面に白い線が表れる原因となります。この症状が現れた場合は一度ケーブルを再接続して、再起動してください。電話を再起動する一番ベストな方法は、バッテリーコネクターの接続を切ってから再び再接続します。
    The piece of advice about power cycling the phone by disconnecting and reconnecting the battery proved crucial to the success of my repair (camera and lens replacement). At first when charging the phone after closing it, I got a dark, blank screen with an intermittent buzzing noise. After re-opening the phone and making sure all cables had been properly reconnected, I ignored the advice to power cycle the phone. Still all I got was a dark, blank screen (and intermittent buzzing if charging t). Then I opened it a third time (leaving the screen connected and attached at a 90 degree angle) and I only disconnected and reconnected the battery. Voila! When I closed the phone and powered it up, I got the screen to light up!
    Gianni - 返信
    how did you disconnect and reconnect the battery?
    Teresa Trevino - 返信
    If you’ve been following the guide, you already disconnected it in this step. To reconnect it, just line up the connector and press it into place.
    Jeff Suovanen -
    After replacing the battery, the phone seems dead. I thought it just needed recharging so I left it charging all night. Still dead in the morning. Now I think it might be because the display data cable is off, and I should open the phone and check it. But the battery might be on full power in that case, and they don’t advice to open the phone when battery if full. What can I do?
    Ila Awasthi - 返信
    The advice aims at avoiding battery fire. Just be careful.
    Katherine Williams - 返信
  17. iPhone 6 Plusのリアケースの交換: 手順 17、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 17、 2の画像 2
    • 最後に、デジタライザーケーブルコネクターの接続を外します。
    • デジタイザーケーブルを再接続する際は、コネクターの中央部分を押さないでください。コネクターの端一方を押してから、もう片方を押し込みます。コネクターの中央を押してしまうと、コンポーネントを曲げてしまい、デジタイザーにダメージを与えてしまうことがあります。
    some images and guidance regarding reassembly would be helpful. You don't need to use the spudger to get them back on: fingers are better because there's a really subtle click you feel when you get them seated properly.
    When you're reassembling, a note that this is the step where you should test for proper screen function would be really useful. First time I reassembled, I didn't seat something properly, got all the screws back together and then realized the screen wasn't functioning properly. Had to disassemble back down to step 14 and then re-reassemble.
    I am having this issues right now! I have unplugged and plugged in these cables at least 20 times and each time I get white lines. I finally have it to where there are only 4 white lines and I am almost willing to live with it. Any suggestions?
    mattmay002 -
    Clean the screen connectors incase they are not making a clean connection
    Karen Jones - 返信
    I'm having nightmares with the digitizer connector. Simply can't get it to work unless I'm applying some pressure on the connectors. Everything seems almost microscopically clean. Any suggestions friends?
    Henry A -
    could it be the replacement screen? test with your old screen and see if you have the same problem.
    Charles - 返信
    To ++mattmay002++  Did you power cycle the phone? Check out the comments on the previous step for a how to.
    Robert Liles - 返信
    I had issues with it too. When connecting this cable, make sure to rock finger side to side after connecting. It’s a wide connector so try to listen for 2 clicks on this one connector. That’s how I fixed mine
    Albert Einstein - 返信
    Re-attaching this cable is the only tricky part to replacing the battery on my 6+. It had a bow on the middle that I had to flatten out before pressing the connector on with finger first on one edge and then on the other. I had white tire tracks on the screen and no touch screen until I connected it correctly. The front has to rest in just the right place on the back while attaching this thing so the cables aren’t strained the front doesn’t fall down. Small fingers would be a plus at this step.
    richard - 返信
    Reseating these connectors on reassembly is definitely the most difficult part of this repair. It took me several attempts before the lowermost connector would seat properly and I did accidentally bend it slightly in the process. Fortunately I was able to get it straight again and get it to click in. The other three went in fine though and no lasting damage seems to have been done.
    Andy Gibbons - 返信
    Another thing - These cables can become overlapped in the wrong way and make you think they are in a different order than they should be. Eg. it’s easy to mix up the ones from step 15 and 17. You can actually unravel the cables and re-layer them on top of each other in any order, so remember this! They look like they’re one solid mass but they’re not.
    domarius - 返信
    I never removed the last digitizer connctor. I removed the first three connectors, left the screen propped at 90 deg tied to a box and removed the battery, there is minimal movement. In fact when I reattached the connectors, only the first and maybe second connector feels taut, so it’s necessary to only remove the first connector if you can be gentle with it. Less headache. And my guess why so many people had issues is that micro dust gets into the connectors and cause connection loss. You be surprised how little dust can cause havoc.
    darrcc - 返信
    And forgot one thing, keep a can of air duster woth you to remove as must dust as you can see. A camera air blower will also do nice.
    darrcc - 返信
    I haven’t removed my screen in past battery replacements, I found it easier. However, this time I followed the instructions because my old battery was very stuck, and I needed the screen gone to get the battery out…
    When I replaced the screen, at first it wouldn’t even boot/start up. (Yes, I inserted my own testing step, as someone here suggested, before final reassembly).
    The screen would just show a fuzzy image, and the board that all the cables attach to would heat up, then it would turn itself off. I tried reconnecting them carefully 3 times, and even made sure to get a little “click”, all to no avail.
    The final try, I used my fingernail to really press down on the back side of the digitizer cable. I heard more clicking, though I thought I might be tearing the cable too. With nothing left to lose, I continued across the back, and heard several more clicking/tearing sounds.
    This worked, and it booted after that. It still had white lines, but those faded away overnight.
    Morgan Giddings - 返信
    About the digitizer connector: its flat cable is so short that the when I attempted to seat the next connector, its flat cable pressed on the digitizer cable, which can pull on the connector and dislodge it. That happened several times for me before success.
    Robert Bernard 27 Nov 19
    Robert H Bernard - 返信
    Nous n’apercevons pas bien les nappes et l’ordre dans lesquelles elles doivent être replacer
    Patrick AZOULAY - 返信
  18. iPhone 6 Plusのリアケースの交換: 手順 18、 1の画像 1
    • リアケースからフロントパネルアセンブリを取り出します。
    Never remove the screen without disconnecting the battery. It's possible the back light can be blown and that's a even more difficult repair. Always, ALWAYS, disconnect battery before repairing items. (Unless it's not possible.)
    Marvin Ballard - 返信
    How do you disconnect the battery from the screen?
    Shamil Bhatti -
    The Step 11 disconnects the battery :)
    jeffxtechs - 返信
    I think you mean Step 8 :)
    Jeff Suovanen -
    I tried it once and
    Brian - 返信
    And what? I tried it once and here’s a million dollars?
    Oh I get it… they got him! :(
    https://www.youtube.com/watch?v=UlznqpBg...
    domarius -
    When disassembling the iphone at this point note the cables, and there placement/orientation.
    GERARD SZAREK - 返信
    Be really careful with the step after this. Do not commence until you have read all the comments. You need to get a good hold of the plastic strips preferably before they double over on themselves. You have to avoid puncturing the battery at all costs. Slowness and caution here will save you a lot of long term pain.
    Laura Houghton - 返信
  19. iPhone 6 Plusのリアケースの交換, バッテリー: 手順 19、 1の画像 1
    • バッテリーの右端下部に付けられた第1番目の接着タブを剥がします。
    • バッテリー周辺の作業であるため、指や先の尖っていないピンセットを用いて十分に注意しながら行います。リチウムイオンバッテリーを損傷してしまうと危険な化学物質が漏れたり、火災の原因となります。
    Ça été pour moi la partie la plus difficile du démontage de l’iPhone, j’ai cassé les 2 bandes parce que je ne me suis pas bien appliqué pour les décoller avec la pince. Pour m’en sortir,. j’ai tordu la batterie avec les outils de manière à faire apparaître les bandes adhésives pour les enlever sans problème.
    Paul Briffaut - 返信
    Translation from Google:
    It was for me the most difficult part of the disassembly of the iPhone, I broke the two bands because I did not apply well to take off with the clamp. To get out of it ,. I twisted the battery with the tools so that the adhesive strips appeared to remove them without any problem.
    Ken - 返信
    Slowly roll the pulled-out adhesive onto itself as you progress, this makes it easier to gauge how much stretch you need to exert on the remaining adhesive, as well as to gain enough grip to hold the adhesive properly. I also nearly tore off the middle one, it’s not due to my rough but because the battery’s black tape (at the area where these adhesive tabs are) caught onto the white adhesive, this must be the reason why most people’s tore off. Mine nearly tore off, so i slow rolled the pulled-out adhesive to catch back the adhesive, and then it’s roll and pull as per normal. With that I took equal precaution for the last one on the left, and it also was caught by the black tape, but since i know it this time, i slowly pulled it free of the black tape first before continuing the roll snd pull. 100% works. Trust me. My battery is slightly warm as i deliberately let it run for a while before i started the disassembly. I doubt it contributes much to the removal but no harm.
    darrcc - 返信
    It's easier if you grasp the full width of the adhesive strip, straight across it, before starting to pull. That way the force is applied gently and evenly to the whole strip. I used watchmaker's forceps because they precisely pull up the adhesive tab, and easily squeeze the whole width of the strip—since it's critical to apply the pulling force evenly across the strip. Tug gently and twist the forceps to take up the slack, pulling just a few millimeters at a time. I learned this the hard way. My center strip snapped pretty quick because I didn't have a good, even grasp of it.
    For heat, I put a cup of raw white rice in a clean sock, knotted the open end, and microwaved it for 2 minutes. When it was cool enough to handle, I flattened it on the table and lay the phone upon it. That gave off enough gentle steady heat that I could pry up the battery without much bending, locate the adhesive end, and successfully wind it up with the forceps. I think I would use the hot rice-bed from the start next time. —Kw
  20. iPhone 6 Plusのリアケースの交換: 手順 20、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 20、 2の画像 2
    • この手順では、接着用プルタブをできるだけ水平にシワが寄らない状態で作業を進めてください。シワが入ったプルタブは互いに絡まり、引っ張ると切断してしまいます。
    • バッテリーの接着タブをバッテリーから取り出し、iPhone下側に向けてゆっくりと慎重に引っ張ります。プルタブが長くストレッチします。
    • プルタブを強く引っ張る前に、完全にバッテリーから取り出してください。プルタブがストレッチしていないと感じたら、すぐに緩めてください。プルタブを切断してしまうことがあります。
    • デバイス下側の端に装着されているコンポーネントにプルタブが接触しないようにご注意ください。プルタブは低い角度で引っ張ってください。
    • プルタブを引っ張りながら、バッテリーを押さえ込まないでください。
    • 接着用プルタブはオリジナルの長さから何倍にも伸びます。プルタブが取り出せるまで、ゆっくりと引き続けてください。バッテリーの下側からプルタブが出てきます。
    • プルタブが作業途中で切れた場合、自分の指や先鋭でないピンセットを使って残りのストリップを掴み、続けて引っ張ります。
    • プルタブがバッテリーの下で切断され取り出せない場合、残りのプルタブを取り出すように作業を続けます。こちらの手順に進んでください
    I found this much easier than when I did it on a 5S. Not sure if the adhesive strips are different, but I also left the phone on a radiator for a few minutes to help warm the glue. All three then pulled straight out of the phone in one go.
    James - 返信
    I set my phone on a microfiber cloth on a plate that I had warmed (warm to the touch and that I could hold with my bare hands) in the microwave prior to this step. All 3 strips came off from the bottom and without any trouble.
    armitagd - 返信
    Excellent tip, thanks.
    vanshdx10 - 返信
    absolutely impossible unless you heat it. Thank You armitagd, that did the trick.
    chris - 返信
    All three of mine tore off immediately, I had warmed the phone up too. A bit of a struggle with the tweezers and card method, the battery bent and leaked. Came out okay.
    John Blanchard - 返信
    I recommend preheating the case before trying to remove each adhesive tape. Also, try wrapping the tape around a pencil as you pull and stretch the tape. I think that such gives a more even pull across the tape than by using one’s fingers.
    GPZ - 返信
    I even didn’t find an adhesive in my phone, I had to use hairdryer to heat the battery, then remove it gently using the blue plastic and couple of plastic cards
    Mohammed Jitarayah - 返信
    I can’t stress enough how important it is to preheat the case as others have mentioned. GPZ’s recommendation using a pencil is also pure gold - get enough initial purchase on the adhesive strip so that you can pull it taut and then place your pencil. From there, roll and tag alternately, keeping tension on it so that the adhesive doesn’t wrinkle in the process of removal.
    Jesse Espe - 返信
    Heating probably works but I slowly pulled out an inch or so and then started rolling it onto my screwdriver. Then I slowly rolled the screwdriver which gave me a good grip and I could go slowly. Took more than 5 min but it got easier and easier. Believe me, getting the battery out using the alternative is very hard, and dangerously easy to penetrate the battery and start a small flame thrower (voice of experience).
    Thomas Hayes - 返信
  21. iPhone 6 Plusのリアケースの交換: 手順 21、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 21、 2の画像 2
    • バッテリーの反対側から2番目の接着付きプルタブを取り出します。
    • ここでも、バッテリーとリアケースの間からプルタブをゆっくりと引っ張り、バッテリーをスライドして取り出します。
    • 続けてバッテリーからプルタブが完全に外れるまで引っ張ります。途中で切断した場合は、残っているタブを取り出してください。もしくはこの下のインストラクションに従ってください。
    This strip broke almost immediately with the first pull. I changed the battery on two iPhone 6 Plus’s. Impossible for me to retrieve broken ends. I moved on to the middle strip with no issue. I then used the blue opening tool to pry the battery up along the lower right edge of the battery (BE CAREFUL!). Once the battery is leveraged up enough to put the tip of the tweezers on the broken strip, grab a piece of the strip and pull it to a point where the removal process can continue as prescribed.
    whiteshephard - 返信
    Pulling the strip around the corner did not work for me - it broke. I then pulled the middle strip straight out with no issues and the remaining left strip also straight without no problem. I don’t recommend pulling the side strips around the corner of the battery
    Swenja - 返信
  22. iPhone 6 Plusのリアケースの交換: 手順 22、 3の画像 1 iPhone 6 Plusのリアケースの交換: 手順 22、 3の画像 2 iPhone 6 Plusのリアケースの交換: 手順 22、 3の画像 3
    • 最後のバッテリー用接着ストリップのタブをバッテリー下端から剥がします。このタブをゆっくりと上に引っ張り、バッテリーから剥がすと、接着ストリップがバッテリーとリアケースの間からゆっくりと出てきます。
    • 最後のストリップを取り出す際は、片手をバッテリーの上に置いてください。バッテリーがiPhoneから飛び出してしまう可能性があります。
    • 最後のストリップがiPhoneから外れるまで引っ張り続けます。
    • 3つの接着ストリップ全てを取り除くことができた場合は、手順24に進みます。バッテリーの下で接着剤が切断して取り出せない場合は、高濃度(90%以上)のイソプロピルアルコールを数滴、破れた接着剤の部分の電池の縁の下に塗ります。
    • アルコール溶液が接着剤を弱めるため、約1分待ちます。ツバキの平らな部分を使って、バッテリーをゆっくりと持ち上げます。
    • バッテリーを力づくで引き抜かないでください。必要に応じてイソプロピルアルコールを数滴注入して、接着剤を弱めます。バッテリーをこじ開けて変形させたり、穴を開けたりしないでください。
    • ボリュームダウン(ー)ボタンとバッテリー上端の間にスパッジャーを差し込まないでください。この下に搭載されたボリュームアップボタンと消音スイッチもしくはオーディオコントロールケーブルを破損してしまうことがあります。
    • バッテリーの接着ストリップを剥がす代用方法を参照する場合は、次の手順に進んでください。
    I don’t know why the instructions didn’t mention this, but I pulled it to the left and back, like the previous strip, rather than straight back, to avoid snapping.
    domarius - 返信
    Pull the adhesive strips at a 45° angle up away from the back or the strip will catch on the bottom board and will tear and break. If it starts to tear, , see if you can grab a spot after the ear and keep pulling. These things are super thin and fragile. Go sloooow when you pull the strips. You are going to pull them a long way, so be patient.
    Ok, so you broke one. Or two. Or all three. Forget the alcohol. Lay your phone face down on a towel and heat it with a hair dryer for two minutes. Flip it over carefully as it will be hot. Insert a plastic spudger under the bottom edge and carefully push/slide it under the battery toward to top of the phone along the strip(s) that are still stuck. DO NOT PRY. You may have to heat it again if it gets hard to push. BE CAREFUL. The battery will bend a bit, but don’t bend it excessively or poke it as it can catch fire when exposed to air. Eventually the battery will pop free. Remove the stuck adhesive and wipe it a bit with alcohol and let it dry.
    Sheldon Carpenter - 返信
  23. iPhone 6 Plusのリアケースの交換, ケースからバッテリー接着ストリップを外す代用方法: 手順 23、 1の画像 1
    • バッテリーがリアケースに付着したままの場合は、iOpenerを用意するか、ヘアドライヤーでバッテリーの真後ろのリアケースを加熱します。気持ちよく触れられる程度の温度になります。
    • その後、プラスチックの開口ツールを使って、バッテリーをゆっくりと持ち上げます。
    • iPhoneを加熱しすぎると、バッテリーが発火する恐れがあります。
    • 代わりに、デンタルフロスもリアケースからバッテリーを取り出す作業に使用できます。さらにデンタルフロスに代わるより強力な代用品はギターの弦です。12ストリングセットの0.009 Eがおすすめです。
    • フロスや糸をバッテリーの下にくぐらせて鋸を引くように左右に動かします。接着剤を剥がしながらバッテリーの上部から下部までスライドします。
    Hat leider alles nicht geklappt! Musste mit einer Karte und einer Seite sehr lange fummeln und da sich die Folie vom Akku zu sehr mit dem gehäuse verbunden hat. Dadurch hat sie sich gelöst und durch das erwärmen leider auch nicht wirklich besser.
    Jess Sass - 返信
    Unfortunately, everything did not work out! Had to fumble with a card and a page for a long time and because the film from the battery has too much connected to the housing. As a result, she has solved and by warming unfortunately not really better.
    Ken -
    This step was very difficult as the adhesive strips snapped on me and I had to use a card to make the strips come out by siding the plastic card on the strips as thought I was trying to cut a very thin slice of cheese. (NOTE: DO NOT USE ANYTHING METAL when attempting this method) I actually tried using a metal spudger while trying to remove the adhesive strips and punctured the old battery slightly enough to cause smoke.
    Bryan - 返信
    iBreak-it: caught the wifi antenna connector when using a guitar string to work the extremely stubborn battery adhesive strips off. Now I need a new wifi antenna. What next?
    Dale Williams - 返信
  24. iPhone 6 Plusのリアケースの交換: 手順 24、 1の画像 1
    • iPhoneからバッテリーを取り出します。
    • 交換用のバッテリーがプラスチックのスリーブに入っている場合は、装着前にリボンケーブルからスリーブを引き抜いてください。
    • デバイス内にアルコール溶液が残っている場合は、新しいバッテリーをインストールする前にきちんと拭き取るか、自然乾燥させてください。
    • 交換用バッテリを装着前に、バッテリーコネクタをロジックボードのソケットに一時的に再接続してください。バッテリーが定位置に装着できるか確認します。
    • バッテリーを装着して、接続を外してからデバイスの再組み立てを継続してください。
    • 新しいバッテリーに接着剤がインストールされていない場合は、接着剤ストリップを交換するために、このガイドを参照してください。
    • 再組み立ての後、ハードセットをしてください。これは幾つかの問題が生じるのを事前に防いでくれ、トラブルシューティングを簡単にしてくれます。
    Once again, ifixit comes through! I bought the battery and the repair kit and the new battery installed and charging. My only hitch was that the three adhesive strips all broke when I pulled on them. I had to heat the bottom of the phone to separate the battery. It was a small moment of panic, but it just required a bit more patience. Thanks for all you do!
    jamesg - 返信
    Awesome procedure! Thanks. iPhone 6plus working great. Make sure you have quality tools. Thanks again.
    Leo Lambert - 返信
    Everything went well enough but, I replaced the battery last month and after a while the phone started going into an on-off cycle. It only happens intermittently. At first it would do it only once and stop. Now it does it, still intermittently, but when it happens it keeps cycling on and off. It even does it when it’s charging. If I let it sit, while charging, after several hours it stops doing it again.
    The battery kit didn’t come with adhesives. It seems that I’m not the only one to mention it .
    Nat Turner - 返信
    Hi there! The battery kit does come with replacement adhesive along with all the tools needed to complete the repair. The part-only battery does not include adhesive, it needs to be purchased separately!
    Sam Goldheart -
    Almost blew up the battery with alot of holes, im traumatized. In the end i did by force and trew it 10 meters away while i were outside.
    Milan - 返信
    i turned on my phone and the screen is all stripes :(
    Emily M. Curran - 返信
    Sounds like either the display cable isn't properly connected or it’s been damaged. If all else fails, send it to a professional.
    Rongwey -
    The Ifixit battery comes with new adhesive strips already attached to the battery. Suggest that it’s best to leave the protective acetate over the strips until AFTER the new battery is re-connected and the connector cover is reinstalled (2 screws). Then its easy to remove the acetate cover from the adhesive strips and locate the battery.
    If the battery is stuck in (with the adhesive strips BEFORE the connector is correctly installed it is impossible to adjust the position of the battery to align the connector.
    Dana Smith - 返信
    My screen doesn’t even show up anything when charging but it makes the sound thought.
    Osvaldo G - 返信
  25. iPhone 6 Plusのリアケースの交換, 背面カメラ: 手順 25、 1の画像 1
    • 背面ケースに留められている背面カメラブラケットより次のネジを取り外します。
    • 1.7 mm フィリップス #00ネジー1本
    • 2.3 mm フィリップス #00 ネジー1本
    need to remove the screws third one that's underneath the 2.3
    sirgednosiam - 返信
  26. iPhone 6 Plusのリアケースの交換: 手順 26、 1の画像 1
    • iPhoneから背面カメラブラケットを持ち上げて取り外します。
  27. iPhone 6 Plusのリアケースの交換: 手順 27、 1の画像 1
    • スパッジャーの平面側先端を使って、背面カメラのコネクターをロジックボードのソケットから外します。
  28. iPhone 6 Plusのリアケースの交換: 手順 28、 1の画像 1
    • 丁寧にiPhoneから背面カメラを取り出して外します。
  29. iPhone 6 Plusのリアケースの交換, アンテナアセンブリ: 手順 29、 1の画像 1
    • 背面ケースに留められているアンテナブラケットから次のネジを取り外します。
    • 1.5 mm フィリップス #00ネジー1本
    • 2.8 mm フィリップス #00ネジー1本
  30. iPhone 6 Plusのリアケースの交換: 手順 30、 1の画像 1
    • ピンセットを使って、アンテナブラケットを持ち上げてiPhoneから取り外します。
  31. iPhone 6 Plusのリアケースの交換: 手順 31、 1の画像 1
    • プラスチックの開封ツールを使ってロジックボードからアンテナコネクターを丁寧に外します。
  32. iPhone 6 Plusのリアケースの交換: 手順 32、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 32、 2の画像 2
    • ピンセットを使ってアンテナコネクターを丁寧に持ち上げ、ロジックボード上の保持クリップから外します。
  33. iPhone 6 Plusのリアケースの交換: 手順 33、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 33、 2の画像 2
    • 2つのコネクターに1つの接着ストリップが留められていることがあります。この場合、接着ストリップを各コネクターに合わせて2つに切り離せます。
    • ロジックボード上の各ソケットからパワーボタンケーブルとオーディオコントロールケーブルを外します。
  34. iPhone 6 Plusのリアケースの交換: 手順 34、 1の画像 1
    • 背面ケースに留められたセルラーアンテナ上部から次のネジを外します。
    • 2.8 mmフィリップス #00ネジ−1本
    • 1.6 mm フィリップス #00ネジー2本
  35. iPhone 6 Plusのリアケースの交換: 手順 35、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 35、 2の画像 2
    • ピンセットを使って、セルラーアンテナ上部を持ち上げ、iPhoneから取り外します。
    • 再組み立ての際には、アンテナアセンブリの左端上部に小サイズの座金がはめられているか確認してください。
  36. iPhone 6 Plusのリアケースの交換, バイブレーター: 手順 36、 1の画像 1
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからバイブレーターケーブルを取り外します。
  37. iPhone 6 Plusのリアケースの交換: 手順 37、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 37、 2の画像 2
    • スパッジャーの先端を使って、ロジックボード上のソケットからインターコネクトアンテナケーブルを外します。
  38. iPhone 6 Plusのリアケースの交換: 手順 38、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 38、 2の画像 2
    • ピンセットを使ってインターコネクトアンテナケーブルを持ち上げ、スピーカーアセンブリの通信路から丁寧に外していきます。
  39. iPhone 6 Plusのリアケースの交換: 手順 39、 1の画像 1
    • 背面ケースに留められたバイブレーターから2.5 mm フィリップス #00ネジを2本取り外します。
  40. iPhone 6 Plusのリアケースの交換: 手順 40、 1の画像 1
    • バイブレーターをiPhoneから取り出します。
  41. iPhone 6 Plusのリアケースの交換, SIMカード: 手順 41、 2の画像 1 iPhone 6 Plusのリアケースの交換, SIMカード: 手順 41、 2の画像 2
    • SIMカード取り出しツールや紙クリップをSIMカードトレイの小さな穴に差し込みます。
    • 押し込んで、トレイを取り出します。
    • この作業にはかなりの力が必要です。
  42. iPhone 6 Plusのリアケースの交換: 手順 42、 1の画像 1
    • iPhoneからSIMカードトレイアセンブリを取り出します。
    • SIMカードを再挿入する際は、トレイが正しい位置より挿入されているか確認ください。
  43. iPhone 6 Plusのリアケースの交換, ロジックボードアセンブリ: 手順 43、 1の画像 1
    • ロジックボードに留められたプラスチック製クリップから1本の2.8 mm フィリップス #00 ネジを外します。
  44. iPhone 6 Plusのリアケースの交換: 手順 44、 1の画像 1
    • 背面ケースサイド上部に留められた1本の2.8 mm フィリップス #00ネジを外します。
  45. iPhone 6 Plusのリアケースの交換: 手順 45、 1の画像 1
    • ピンセットを使って、プラスチック製クリップをしっかりと持ち、iPhoneから取り外します。
  46. iPhone 6 Plusのリアケースの交換: 手順 46、 1の画像 1
    • 背面ケースに付けられたアンテナクリップより1本の1.6 mm フィリップス #00ネジを外します。
  47. iPhone 6 Plusのリアケースの交換: 手順 47、 1の画像 1
    • ピンセットを使ってアンテナクリップを丁寧に持ち上げ、iPhoneから取り外します。
  48. iPhone 6 Plusのリアケースの交換, ロジックボード: 手順 48、 1の画像 1
    • 背面ケースに付けられたロジックボードから次のネジを外します。
    • 2.4 mmスタンドオフネジー2本
    • これらのスタンドオフネジを外すには小サイズのフラットヘッドのスクリュードライバーをご使用ください。
    • 2.1 mm フィリップス #00ネジー1本
  49. iPhone 6 Plusのリアケースの交換: 手順 49、 1の画像 1
    • 丁寧にロジックボードを持ち上げますーが、完全に取り外さないでください。ライトニングコネクターに近い端の下を持ってあげます。
  50. iPhone 6 Plusのリアケースの交換: 手順 50、 1の画像 1
    • ロジックボードを取り外さないでください。この時点でアンテナコネクターと背面ケースが接合しています。
    • ロジックボードの下部が背面ケースに対して垂直になるまで、丁寧に持ち上げます。
  51. iPhone 6 Plusのリアケースの交換: 手順 51、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 51、 2の画像 2
    • iPhoneの背面ケースに上部が付いている状態で、ロジックボードをひっくり返します。
    • スパッジャーの平面側先端を使って、ロジックボードの裏側にあるソケットからアンテナコネクターを外します。
    An extra step needs to be added. the 1.3 millimeter Phillips head #00 screw retaining the antenna to the frame needs to be removed and then the antenna removed.
    Josh Ginsberg - 返信
  52. iPhone 6 Plusのリアケースの交換: 手順 52、 1の画像 1
    • iPhoneからロジックボードを持ち上げて外します。
  53. iPhone 6 Plusのリアケースの交換, 電源ボタンケーブル: 手順 53、 2の画像 1 iPhone 6 Plusのリアケースの交換, 電源ボタンケーブル: 手順 53、 2の画像 2
    • ピンセットを使って、電源ボタンとオーディオコントロール/ロッカスイッチケーブルコネクタ両方の上部に留められた一つの接着タブを剥がします。
  54. iPhone 6 Plusのリアケースの交換: 手順 54、 1の画像 1
    • 背面ケースに留められた電源ボタンケーブルから1.3 mm プラス #00ネジ を1本取り外します。
  55. iPhone 6 Plusのリアケースの交換: 手順 55、 1の画像 1
    • ピンセットを使って、iPhoneから丁寧にブラケットを持ち上げて取り外します。
  56. iPhone 6 Plusのリアケースの交換: 手順 56、 1の画像 1
    • 背面ケース内側端に留められた電源ボタンケーブルブラケットから次のネジを取り外します。
    • 2.1 mm プラス #00ネジー1本
    • 1.7 mm プラス #00ネジー1本
  57. iPhone 6 Plusのリアケースの交換: 手順 57、 1の画像 1
    • ピンセットで電源ボタンケーブルブラケットを持ち上げて、iPhoneから取り外します。
  58. iPhone 6 Plusのリアケースの交換: 手順 58、 1の画像 1
    • 背面ケースに留められた電源ボタンスイッチから2.1 mm プラス #00ネジを1本外します。
  59. iPhone 6 Plusのリアケースの交換: 手順 59、 1の画像 1
    • ピンセットを使って背面ケースの角から電源ボタンスイッチを掴み、丁寧に背面ケースから電源ボタンケーブルを剥がしていきます。
  60. iPhone 6 Plusのリアケースの交換: 手順 60、 3の画像 1 iPhone 6 Plusのリアケースの交換: 手順 60、 3の画像 2 iPhone 6 Plusのリアケースの交換: 手順 60、 3の画像 3
    • 電源ボタンケーブルを背面ケースからゆっくりと剥がしていき、iPhoneからケーブルを取り出します。
  61. iPhone 6 Plusのリアケースの交換, オーディオコントロールとろっかーススイッチケーブル: 手順 61、 1の画像 1
    • 背面ケースに留められたオーディオコントロールとロッカースイッチから次のネジを取り外します。
    • 2.0 mm フィリップス #00ネジー2本
    • 2.5 mm フィリップス #00ネジー1本
  62. iPhone 6 Plusのリアケースの交換: 手順 62、 3の画像 1 iPhone 6 Plusのリアケースの交換: 手順 62、 3の画像 2 iPhone 6 Plusのリアケースの交換: 手順 62、 3の画像 3
    • ピンセットを使ってオーディオコントロールとロッカースイッチケーブルを取り出します。
    • 背面ケースからオーディオコントロールとロッカースイッチケーブルをゆっくりと丁寧に剥がしていきます。
    • 丁寧に剥いでいきます。ケーブルは軽めの接着剤で背面ケースに留められています。
  63. iPhone 6 Plusのリアケースの交換, 音量コントロールとロッカースイッチボタン: 手順 63、 2の画像 1 iPhone 6 Plusのリアケースの交換, 音量コントロールとロッカースイッチボタン: 手順 63、 2の画像 2
    • スパッジャーの先端を使って、音量コントロールとロッカースイッチボタンを背面ケースの端から押し出します。
  64. iPhone 6 Plusのリアケースの交換: 手順 64、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 64、 2の画像 2
    • ピンセットを使って、音量コントロールボタンの両端を挟み、iPhoneから取り出します。
  65. iPhone 6 Plusのリアケースの交換, スピーカー: 手順 65、 2の画像 1 iPhone 6 Plusのリアケースの交換, スピーカー: 手順 65、 2の画像 2
    • ピンセットでアンテナコネクターを掴み、丁寧にスピーカー上の通信路からコネクターを外していきます。
  66. iPhone 6 Plusのリアケースの交換: 手順 66、 1の画像 1
    • アンテナコネクターを完全に外すには、これをスピーカーアセンブリに留めているメタル製クリップを引っ張る必要があります。
  67. iPhone 6 Plusのリアケースの交換: 手順 67、 1の画像 1
    • 背面ケースに留めてあるスピーカーから次のネジを取り外します。
    • 2.3 mm フィリップス #00ネジー1本
  68. iPhone 6 Plusのリアケースの交換: 手順 68、 1の画像 1
    • スピーカーを持ち上げてiPhoneから取り出します。
  69. iPhone 6 Plusのリアケースの交換, ライトニングコネクターアセンブリ: 手順 69、 1の画像 1
    • ライトニングコネクターアセンブリに留められたメタル製ブラケットより3.3 mm フィリップス #00ネジを2つ取り外します。
  70. iPhone 6 Plusのリアケースの交換: 手順 70、 1の画像 1
    • ピンセットを使って、iPhoneからメタル製ブラケットを取り出します。
  71. iPhone 6 Plusのリアケースの交換: 手順 71、 1の画像 1
    • スパッジャーの平面側先端を使って、ライトニングコネクターアセンブリ上のソケットから、アンテナコネクターケーブルを引き上げて外します。
  72. iPhone 6 Plusのリアケースの交換: 手順 72、 1の画像 1
    • iPhoneからアンテナコネクターを取り外します。
  73. iPhone 6 Plusのリアケースの交換: 手順 73、 1の画像 1
    • 背面ケースに留められたライトニングコネクターアセンブリより次のフィリップス #00ネジを取り外します。
    • 3.2 mmネジー2本
    • 3.8 mm ネジー1本
    • 1.7 mmネジー2本
    • 1.5 mmネジー2本
    • 1.4 mm ネジー2本
  74. iPhone 6 Plusのリアケースの交換: 手順 74、 1の画像 1
    • ピンセットを使って、ヘッドフォンジャックの右側に留められているプラスチック製クリップを持ち上げ、iPhoneから取り外します。
  75. iPhone 6 Plusのリアケースの交換, Lightning コネクターとヘッドホンジャックケーブル: 手順 75、 1の画像 1
    • 次の手順はライトニングコネクターとヘッドフォンジャックケーブルを剥がしていく作業です。背面ケースの内側に中程度の接着剤が付けられています。接着剤を取りやすくするために、背面ケースの裏側下部に iOpener を当てから作業を始める方法を強くお勧めします。
  76. iPhone 6 Plusのリアケースの交換: 手順 76、 3の画像 1 iPhone 6 Plusのリアケースの交換: 手順 76、 3の画像 2 iPhone 6 Plusのリアケースの交換: 手順 76、 3の画像 3
    • オープニングピックを使って、背面ケースからライトニングコネクターとヘッドホンジャックを丁寧に外します。
    • ライトニングコネクターとヘッドホンジャックケーブルの右側からピックを丁寧に差し込み動かしていきます。下部まで到達したら作業を必ず止めてください
  77. iPhone 6 Plusのリアケースの交換: 手順 77、 1の画像 1
    • ライトニングコネクターとヘッドホンジャックケーブル下部右端に下からピックを差し込みます。
  78. iPhone 6 Plusのリアケースの交換: 手順 78、 2の画像 1 iPhone 6 Plusのリアケースの交換: 手順 78、 2の画像 2
    • ライトニングコネクターとヘッドホンジャックケーブル上部にオープニングピックを差し込み、背面ケースとケーブルを留めている接着剤を剥がしながら横に動かしていきます。
  79. iPhone 6 Plusのリアケースの交換: 手順 79、 1の画像 1
    • ライトニングコネクターとヘッドホンジャックケーブルアセンブリを持ち上げ、iPhoneから取り外します。
  80. iPhone 6 Plusのリアケースの交換, リアケース: 手順 80、 1の画像 1
    • リアケースのみが残ります。
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
59 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
6人の作成者と共同で作成されました。
Jeff Suovanen
メンバー登録日: 08/06/13
427,925 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,757のガイドは作成済み
6 件のコメント
what are the 5 metal "spacers" attached to the housing? they are simplistic metal spacing bars with a tiny rubber block. all held to the left side and right side walls with 2 screws per spacer. The instructions totally skipped this step about removing them. all housings i see being sold do not include them, so wouldnt you want to move them over too?
quysu714 - 返信
they probably don't add it because its pretty self explanatory.
Chris Gourlay -
step 84, When you have finished tearing it all down, there are a couple of things you missed, the rubber piece that is connected to the case near the speaker and the charging port housing when you remove the board at the bottom.
jamielee2k - 返信
In addition to the metal "spacers," the screen for the speaker and the charging port housing, don't forget to transfer a few other things that weren't mentioned in the guide to your new rear case: the power button, the little metal switch for the sim tray; there's a tiny black speaker screen near the headphone jack that must be transferred over (might want to clean it off if it has collected dust); in the top left corner there are two more screws to loosen: one is for a tiny metal spacer piece and the other for the antennae connector cable; there is also a little metal square that cushions the antenna connector's socket; a small strip where the earpiece speaker would be that looks like a black rolled piece of tape; and finally, the foam cushion for the rear camera and the little black screen next to it. But yea... pretty self explanatory.
ikennaugwuh - 返信
Hi all,
During the instructions, the screws flip from having #00 next to them and then nothing.
Does this mean that these screws are different? If so, how do you differentiate them? I have a replacement set of screws that are unsorted so hoping to sort them with my digital caliper.
All the best
Mike
dixonmichael1989 - 返信
Phillips #00 is the driver size, so unfortunately it’s not much help for sorting the screws. Check each screw length with a digital caliper and compare against the guide. When you find a good candidate, carefully thread it into place and don’t force it. If it doesn’t feel right, back off and try a different screw. Good luck!
Jeff Suovanen -
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 34
過去 30 日: 94
今までの合計 146,638
