メインコンテンツにスキップ
iPhone 6 Plusのリアカメラの交換
必要な工具と部品
ビデオの概要
  1. iPhone 6 Plusのリアカメラの交換, ペンタロープネジ: 手順 1、 1の画像 1
    • 作業を始める前に、バッテリーの残量を25%以下まで消費してください。充電されたリチウムイオンバッテリーにアクシデントで穴を開けてしまうと、引火や爆発の原因となります。
    • iPhoneの電源を必ず切ってください。
    • Lightningコネクター両側の3.6 mmペンタロープネジ2本を外します。
    I prefer to remove the SIM card as the very first step since it's safer to do so while the phone is fully assembled.
    estebanfallasf - 返信
    I stripped one of the two screws - at a dead stop.
    Margaret Patterson - 返信
    Before you even start: get the iOpener or hairdryer out. You’ll need it
    GPZ - 返信
    If a lightning connector won’t provide a charge or needs to be wiggled carefully to provide a charge, power off the device, then try using precision tweezers to scrape the innermost wall of the lightning jack in a pinching motion to check for lint buildup. Pocket lint or other debris can accumulate inside the jack, compacting each time a cable is inserted. This can prevent a lightning cable from seating fully. Clearing the lint may restore functionality without replacing the part.
    Andrew Dolan - 返信
    A few hints:
    * heating up the phone works great. I used a heating pad that you put in the microwave to heat sports injuries.
    * also, I made a sheet to help you keep track of the screws as you remove them. Print out the page, then place double sided tape below each color-coded listing of screws, and stick the screws to the tape as you disassemble. This helps prevent losing the screws and keeps track of what screws are what for easier reassembly. https://drive.google.com/file/d/1pLSvKvB...
    Paul Faulstich - 返信
    Additional hints, for anyone who needs them:
    * stick the screws to the tape in the same positions as they are shown in the guide. This will make it easier to identify them during reassembly.
    * if the screws get mixed together, the ‘mm’ (millimetre, millimeter) measurements given in the guide can be used to identify them. Compare the lengths of the threaded shafts to each other to determine which screw is which.
    Friendly Advice -
  2. iPhone 6 Plusのリアカメラの交換, リバースクランプの使用方法: 手順 2、 3の画像 1 iPhone 6 Plusのリアカメラの交換, リバースクランプの使用方法: 手順 2、 3の画像 2 iPhone 6 Plusのリアカメラの交換, リバースクランプの使用方法: 手順 2、 3の画像 3
    • 次の3つの手順では、デバイスの開口作業を簡単にするために開発されたツール、リバースクランプの使い方を紹介します。リバースクランプを使用しない場合は、この3つの手順をスキップして別の方法をご覧ください。
    • リバースクランプの詳細な使用方法については、 こちらのガイドをご覧ください。
    • 青いハンドルを後方に引き、リバースクランプのアームのロックを解除します。
    • iPhoneの左/右側の端に向けてアームをスライドします。
    • 吸盤カップを、ホームボタンすぐ上のiPhoneの下端付近に装着します。上部に一つ、下部に1つずつ取り付けます。
    • 両側のカップをしっかりと押し付けて、取り付けたい位置に装着します。
    • 作業中のデバイス表面が滑りやすく、吸盤がうまく装着できない場合は、梱包用テープを表面に貼ると、よりグリップ力を強めることができます。
  3. iPhone 6 Plusのリアカメラの交換: 手順 3、 3の画像 1 iPhone 6 Plusのリアカメラの交換: 手順 3、 3の画像 2 iPhone 6 Plusのリアカメラの交換: 手順 3、 3の画像 3
    • 青いハンドルを手前に引くと、アームがロックされます。
    • ハンドルを時計回りに360度回転させ、カップが両側をストレッチするまで回し続けます。
    • 吸盤カップ両側の位置が合っていることを確認してください。位置がずれてきた場合は、吸盤を少し緩めてアームの位置を合わせてください。
    • クランプで十分な隙間が作れたら、スクリーンのプラスチックベゼルの下にオープニングピックを挿入します。
    • クランプで十分な隙間が作れない場合は、さらに接着面に熱を当てて、クランプを1/4程度時計回りに回してください。
    • 一回ごとの作業で1/4以上回さないでください。クランプをまわしたら数秒間待ってください。リバースクランプの効果を待ってから、作業を続けてください。
    • 次の3つの手順をスキップして手順7までお進みください。
    Use clear nontextured tape place that over the phone screen. Refer to any guide that addresses replacing a shattered screen
    Abigail Cherry - 返信
    I know it's tough with cracked glass. You just need enough to get in a plstic pry tool or guitar pick. Then you can pry it apart. Just be patient, I cannot stress that enough; the electronics are very, very small and fragile.
    Mike - 返信
  4. iPhone 6 Plusのリアカメラの交換, フロントパネルアセンブリ: 手順 4、 1の画像 1
    • シングルタイプの吸盤カップを使って、フロントパネルを引き上げます。
    • 吸盤カップをホームボタン上のスクリーンに押し当てます。
    • カップがスクリーンにしっかりと固定しているか確認します。
    • ディスプレイの亀裂の程度がひどい場合、吸盤カップがしっかりと装着するために、透明な梱包テープを表面に貼ってください。もしくは吸盤カップの代わりに、強力テープを使用できます。それでも上手くいかない場合は、壊れたスクリーン上に強力ボンドをつけた吸盤カップを付けて固定してください。
    Avec la ventouse, l’ouverture est brutale, tout s’est déclipsé d’un seul coup. Faire attention.
    Paul Briffaut - 返信
    English Please!
    tom mozeleski -
    With the sucker, the opening is brutal, everything was cleared at once. Pay attention. (Paul’s comment translated by Google)
    Steve Schlotter - 返信
    May need to burp the sticker before it sticks. Need to let the air out. Once Idid that, no problem. Except it was still hard to get the cover to start up.
    Patricia Tucker - 返信
    Don’t waste your time with the suction cup - it doesn’t work! insert the blade of a box cutter just below the lower screen edge below the home button and gently pry just enough to start cracking the seal.
    Stephen Smith - 返信
  5. iPhone 6 Plusのリアカメラの交換: 手順 5、 1の画像 1
    • 片手で iPhoneを押さえながら、吸盤カップを引き上げて、ゆっくりとリアケースからフロントパネルアセンブリを離します。
    • 時間をかけてゆっくりと、同じ強さ加減で作業を進めます。他のデバイスに比べてより強固に接着されています。
    • プラスチックの開口ツールを使って隙間に差し込み、リアケースからディスプレイアセンブリを丁寧にこじ開け、吸盤カップで持ち上げます。
    • フロントパネルアセンブリをリアケースに固定させているクリップが幾つかあります。吸盤カップとプラスチック製開口ツールの両方を使いながら、フロントパネルアセンブリを外してくださ。
    Be extra careful here. If you don’t take your time, your front panel may jerk back on you, causing you to overextend and break the front camera/mic flex cable; happened to me. Slowly peel back the front panel, opening it no more than 90º.
    Thomas - 返信
    watch out for the left side of the phone the adhesive bunches up around the inner clips, i didn’t realize it and the upper left of my screen cracked pretty bad. But this guide is awesome follow every direction to the letter
    Aaron Fitzpatrick - 返信
    Note: this comment is written for the iPhone 6 Plus, but may also apply to other models of iPhone.
    Disassembly:
    The clips in the rear case attach to small slotted shapes under the edges of the display assembly, and these attachment points alternate from one side to the other. Moving from bottom to top, gently pulling the rear case away at these points will help to separate the two halves without using too much force.
    Reassembly:
    Ensure that the plastic clips along the top edge of the front panel (shown in step 8) are fitted properly inside the rear case, then gently press the display assembly into the rear case at these points, moving from top to bottom. There may be a small click sound as the clips in the rear case engage with the slots on the display assembly, and the rear case should fit flush with the edges of the display assembly.
    Friendly Advice - 返信
    This was challenging. For me, the suction cup could only create a tiny bit of motion and at first, no actual gap at all. You might have to pull the suction cup away from the base a few times just to loosen things up a tiny bit. Eventually, I got my fingernail in, and then after a few minutes got the plastic tool in.
    Also, use the plastic tool to gently pry along the sides of the phone once there’s light there. I was afraid of using too much leverage and breaking the screen as per the other comments, but starting at the bottom and then going around the sides slowly worked for me.
    FixingMyiPhone - 返信
  6. iPhone 6 Plusのリアカメラの交換: 手順 6、 2の画像 1 iPhone 6 Plusのリアカメラの交換: 手順 6、 2の画像 2
    • 吸盤カップ中央のグリップを持ち上げて、吸引力を緩めます。
    • 吸盤カップをディスプレイアセンブリから取り外します。
    There is an adhesive strip all along the edge between the top and bottom of the phone. Is that just adhesive or is it wire of some sort?
    Larry Ingerling - 返信
    @lingerling The adhesive strip was introduced on the iPhone 6s and 6s Plus (one model year later than what’s shown on this page). Guides specific to each model can be found here—be sure to use the correct one for your particular phone. And yes, just adhesive, no wires. ;)
    Jeff Suovanen - 返信
  7. iPhone 6 Plusのリアカメラの交換: 手順 7、 3の画像 1 iPhone 6 Plusのリアカメラの交換: 手順 7、 3の画像 2 iPhone 6 Plusのリアカメラの交換: 手順 7、 3の画像 3
    • 本体上部先端を蝶番にして、背面ケースからフロントパネルアセンブリのホームボタン端を引き上げます。
    • 約90度の角度でディスプレイを開け、後ろに立て掛けて固定できる衝立を置きます。
    • ゴムバンドでディスプレイと衝立を留めて動かないようにします。これはディスプレイケーブルがアクシデントで引き伸ばされるのを防ぐためです。
    • 急ぎの場合は未開封の飲料用缶を使用できます。
    Be careful If we leave the screen connected and set it to 90 degrees, the speaker / sensor flex may break. With an opening of 60 degrees it is convenient to completely disconnect the screen. The headset's flex is short, and if we put it at 90º, it can break. Guiding me from the images of iFixit, I have broken two cables.
    Español:
    Cuidado. Si dejamos la pantalla conectada y lo ponemos a 90 grados, el flex del altavoz/sensor puede romperse. Con una abertura de 60 grados es conveniente desconectar enteramente la pantalla. El flex del auricular es corto, y si lo ponemos en 90º , se puede romper. Guiándome de las imágenes de iFixit, se me han roto dos cables.
    txaukos - 返信
    At 60º the display will block access to all the screws and the phone would be practically unserviceable, so I’m having trouble making sense of this comment. The cables on a factory original display are pretty tough and designed with enough slack that a 90º angle is no problem. Same with any decent aftermarket display.
    Jeff Suovanen - 返信
    If you look at the enlarged image, you can see how the flex cable from the camera / speaker is in tension. This is my opinion. Sorry for my bad English
    Si usted se fija en la imagen ampliada, puede ver cómo el flex cable de la cámara/altavoz está en tensión. Esta es mi opinión.
    Perdón por mi mal inglés
    txaukos - 返信
    your English isn’t the issue, it’s the proposed 60 degree opening space that doesn’t allow for the removal of the screws of the mounting plate where the connectors connect to the main pcb…
    if can make a recommendation here; it helps if the can is full and not refrigerated, the weight helps in keeping the phone where it should stay without adding additional tension to the ‘flex’ ribbon cable. it’s called flex for a reason people, if your breaking these the phones already been overheated too much, the cables become brittle and should also be replaced. i replaced my battery without disconnecting the screen, at 90 degrees with a rubber band around an empty beer can. pierced the orig. battery and caused sparks. albeit, i wasn’t in a hurry and it took me a good 30+ minutes, removal of the battery and stickers is by far the most challenging, especially when NOT disconnecting the screen…
    it’s not a race, take your time. move slowly but precisely with forethought and persistent force…
    circuitbender 477 - 返信
    Werkt dit ook voor iPhone 7(plus)?
    Christina Pegtel - 返信
    Werkt dit hetzelfde voor iPhone 7 (plus)?
  8. iPhone 6 Plusのリアカメラの交換: 手順 8、 2の画像 1 iPhone 6 Plusのリアカメラの交換: 手順 8、 2の画像 2
    • フロントパネル上部に留められた幾つかのクリップを蝶番のようにして、本をめくるようにフロントパネルアセンブリを開きます。
    • 再組み立ての際は、クリップが背面ケース上部端のちょうど真下になるように配置します。それからフロントパネル上部先端と背面ケース上部先端が重なるまで上方にスライドします。
    I would recommend protecting the screen once the display is free and the suction cup has been removed. This will help avoid any possibility of accidental scratching of the display crystal while the remaining steps are being performed. I used an inexpensive screen protector then removed it after reassembling and testing are complete.
    anthonyspampinato - 返信
  9. iPhone 6 Plusのリアカメラの交換: 手順 9、 1の画像 1
    • 次のプラスネジをバッテリーコネクターブラケットから外します。
    • 2.3 mm プラスネジ ー1本
    • 3.1 mm プラスネジー1本
    for the iPhone 6 Plus, all screws were Phillips #000
    Michael Adams - 返信
    I had difficulty removing the 3.1mm (iPhone 6 Plus / Phillips #000); had to give it significant downward pressure to get it started.
    Allen Matheson - 返信
    stripped the 2.3mm screw attempting to remove, had to use excessive force to successfully remove
    Matthew Gao - 返信
    The Phillips bits provided in the kit would not engage the Phillips heads enough to loosen them. Luckily I had my own small screwdriver set that worked like a charm.
    David Davis - 返信
    Same issue. Could not remove the screw. Dead in the water.
    Tiffany - 返信
    Agree with above comments regarding the supplied Phillips bit. It is not the correct size.
    Use a Phillips #000.
    bobgottner - 返信
    Phillips #000 is what’s included in the kit. As others mentioned above, firm downward pressure is key. The phone is not that delicate; just press hard and crank it.
    Jeff Suovanen -
    Is this step necessary ?\
    Asianay - 返信
    @asianay0129 Yes, disconnecting the battery is necessary. You can sometimes get away with skipping it, at the risk of destroying something important and potentially bricking your phone. Not a wise gamble for the sake of skipping two screws.
    Jeff Suovanen - 返信
  10. iPhone 6 Plusのリアカメラの交換: 手順 10、 1の画像 1
    • iPhoneからメタル製バッテリーコネクターブラケットを取り出します。
    Was not able to remove the battery connector bracket as one of the cable connectors was glued/stuck to the underside. Instead moved the bracket out of the way to disconnect the battery. Care should be taken not to over bend/stretch the ribbon cable.
    dwtan - 返信
    That may be just the foam connector adhering to the bracket. If you pull up gently and twist slightly it should separate.
    Evan Noronha -
    It was the foam connector, and it did twist free with a gentle pull
    Al Taylor - 返信
  11. iPhone 6 Plusのリアカメラの交換: 手順 11、 1の画像 1
    • 爪先もしくは開口ツールの先端を使って、基板上のソケットからバッテリーコネクターの接続を外します。
    • バッテリーコネクターのみにツールを差し込んで持ち上げてください。基板のソケットに接触しないでください。コネクター全体を破損してしまうことがあります。
    you may consider placing a thin non-conductive item between the connector and the socket like a bit of rubber band to prevent any power flowing during this procedure
    Michael Adams - 返信
    It was too close to other parts to pry up with either end of plastic tool. Finally used 1 tine of tweezer to lift edge. Came free easily
    Al Taylor - 返信
    J’ai pris une loupe pour bien observer l’endroit où placer l’outil.
    Paul Briffaut - 返信
    Magnification is key for many tasks and this is certainly one.
    Kenneth Gilbert - 返信
    I couldn’t use the iFixit blue opening tool to pry that battery connector. I used the top of the black spudger near the hole where the 3.1mm screw was in step 9-10 to easily pry it open!
    Alyssa Sayuki - 返信
    The blue plastic board breaker can easily cause damage here. Professionals would recommend using the human fingernail as the ideal tool for this job.
    Jessa Jones - 返信
  12. iPhone 6 Plusのリアカメラの交換: 手順 12、 1の画像 1
    • フロントパネルアセンブリーのケーブルブラケットに留められたネジを外します。
    • 1.2 mm ネジー3本
    • 1.5 mm ネジー1本
    • 2.9 mm ネジー1本
    • 絶対に赤い丸印のネジ穴に長いネジを差し込まないでください。基板にダメージを与えてしまいます。
    There's an other panel with one screw in the middle.........
    Herbert - 返信
    Sounds like you have an iPhone 6s Plus, rather than a 6 Plus. Be sure to use the correct guide! And make sure you’ve ordered the correct part, as they’re not cross-compatible.
    Jeff Suovanen -
    I _love_ the color coding of screws. I know this is a little OCD, but it would be incredibly useful if there were an 8.5 X 11 you could print with indicated homes for where to drop items from each step of disassembly. That is, in the box for step 9, little colored circles for where to place each screw type. As long as you don't jostle the paper, it would make it a lot easier to know exactly where you are in reassembly.
    cscarlson47shop - 返信
    I have done the exact same thing. Created a sheet where each screw goes.
    Chris Murphy -
    I used the 000 bit from the ifixit 54 piece kit.
    hhandh - 返信
    Actually you don’t need to do steps 12 to 18 if you attach the display panel to the iPhone box as shown in step 7 and handle your iPhone with care during the replacement. I didn’t disconnect the display panel mainly because the more you work on the interior of your phone the higher is the chance you break something.
    Dany Castillo - 返信
    Since this guide is for DISPLAY replacement, I don’t see how you can skip the steps for disconnecting and removing the DISPLAY.
    Jim Bateman -
    That's what I was thinking.
    The Wizard - 返信
    I skipped this series of steps too. I was very careful when removing the battery and never had an issue with the screen leaning back against the box that this battery shipped in. I even broke half of the third strip of adhesive but used a plastic card to slide under the battery and it slowly lifted out without applying heat.
    mark - 返信
    I'm having trouble with one screw not wanting to come out. Any suggestions to keep from stripping the head and getting it?
    Patric - 返信
    which screws are which sizes cause i ordered new ones and cant figure it out
    MONsterHEIT - 返信
    I also did not see the need to remove the display assembly for this repair. However I did place a can of corn against the vertically positioned display and then secured the display to the can with a rubber band.
    whiteshephard - 返信
    I recommend removing the display assembly, I didn’t and somehow damaged the home button cable. At least remove the cover to ease the tension on the cables.
    I played around with different screwdrivers to get certain screws out. I made sure I wasn’t applying heavy pressure so I wouldn’t strip the head. Apple is crazy for doing this to us lol.
    Anyways invest in a magnetized mat to organize your screws. It was really difficult to keep things organized and still, especially with these tiny screws…
    Jeffrey Robinos - 返信
    what happens if i forgot to put the ribbon cable shield back on? the phone is now working but i forgot to put the shield back on and i am missing 2 screws. can i leave the shield off?
    Fred ticoman. - 返信
    @ticoman12 It’ll work without the shield, but the connectors may pop out unexpectedly.
    Jeff Suovanen -
    Just be really careful remembering which screw is which. I drew a quick sketch of the bracket, then put the screws in the relevant places. There’s no way I would have been able to figure them out otherwise - my eyes can’t see the difference between a 1.2 and 1.5mm screw!
    Paul Johnson - 返信
    The most fiddly part of the job.
    Much easier if you put the screwdriver head on the screw and then insert it into the opening. The slight magnetism will hold it in place. Don’t fully tighten a screw until all the screws are in place. Much like installing lug nuts on a car.
    GPZ - 返信
    I also skipped steps 12-18 as Danny had suggested. It made this repair quite easy, so thank you and others for suggesting this. I was also very careful to allow the battery to discharge before starting the process.
    Bruce Platt - 返信
    I question whether Steps 12-18 (separating the display from the case) is actually necessary? The battery can be removed/replaced with the display connected (but standing upright, as displayed in Step 7.
    Leaving the display attached obviates the most difficult steps (re-connecting the various control ribbons — 3/4 of ‘em!
    I followed this manual completely and the repair was successful. But if I had this to do over, I’d leave the display connected.
    Dana Smith - 返信
    I skipped the steps 12-18 as well and thank goodness I did so I won’t have to worry about issues with any of the cables.
    my panel is different from what is pictured anyway ‘cause I have one screw in the middle like what Herbert said on the first comment.
    Maria Filamor-Robinson - 返信
    I realized too late just how handy the magnetic mat is that they have in their shop. So I organized the screws with a piece of clear packing tape. On the smooth side, use a sharpie to draw spacious circles with “R” “O” and “Y” inside each circle to represent the color coded screws and then use the sticky side to keep the screws in place. I found that using the tweezers to take them off the screwdriver helps you stick them head first to the tape better.
    Selena Castillo - 返信
  13. iPhone 6 Plusのリアカメラの交換: 手順 13、 1の画像 1
    • 基板からフロントパネルアセンブリのケーブルブラケットを取り外します。
  14. iPhone 6 Plusのリアカメラの交換: 手順 14、 2の画像 1 iPhone 6 Plusのリアカメラの交換: 手順 14、 2の画像 2
    • 次の4つの手順ではケーブルコネクターのみこじ開けます。基板上のケーブルコネクター用ソケットには接触しないでください。
    • フロントパネルを固定したまま、爪先もしくは開口ツールの先端を使って、正面カメラとイヤピーススピーカーのコネクタの接続を外します。
    Why does the screen need to come off?
    Sterling Coffey (N0SSC) - 返信
    Because the cables are delicate, and following steps are easier if phone halves are not flopping around together, especially for amateurs.
    Matthew Goheen - 返信
    I don't know if anyone will see this but here it goes: for the life of me I can't get the front-facing camera and earpiece speaker connector to seat. Everything else went back together fine but this one connector will not go in. Sometimes it seems like it's in even though it doesn't really pop in and it'll kinda sit there for a sec and then it pops out.
    Any insight would be greatly appreciated, thank you
    Droopy Caledonia - 返信
    Try starting at one end instead of in the middle. It's to easy to bend a connector and this way, I can get a safe start and go from there.
    Rongwey - 返信
  15. iPhone 6 Plusのリアカメラの交換: 手順 15、 2の画像 1 iPhone 6 Plusのリアカメラの交換: 手順 15、 2の画像 2
    • ホームボタンケーブルコネクターの接続を外します。
  16. iPhone 6 Plusのリアカメラの交換: 手順 16、 2の画像 1 iPhone 6 Plusのリアカメラの交換: 手順 16、 2の画像 2
    • この手順でケーブルの接続を外したり、再接続する前に、バッテリーの接続が外れているか必ず確認してください。
    • プラスチックの開口ツールを使って、ディスプレイデータのケーブルコネクターの接続を外します。
    • デバイスを再組み立てする際は、本体ディスプレイのデータケーブルがコネクターから飛び出すことがあります。これは電源スイッチを入れた時、黒い画面に白い線が表れる原因となります。この症状が現れた場合は一度ケーブルを再接続して、再起動してください。電話を再起動する一番ベストな方法は、バッテリーコネクターの接続を切ってから再び再接続します。
    The piece of advice about power cycling the phone by disconnecting and reconnecting the battery proved crucial to the success of my repair (camera and lens replacement). At first when charging the phone after closing it, I got a dark, blank screen with an intermittent buzzing noise. After re-opening the phone and making sure all cables had been properly reconnected, I ignored the advice to power cycle the phone. Still all I got was a dark, blank screen (and intermittent buzzing if charging t). Then I opened it a third time (leaving the screen connected and attached at a 90 degree angle) and I only disconnected and reconnected the battery. Voila! When I closed the phone and powered it up, I got the screen to light up!
    Gianni - 返信
    how did you disconnect and reconnect the battery?
    Teresa Trevino - 返信
    If you’ve been following the guide, you already disconnected it in this step. To reconnect it, just line up the connector and press it into place.
    Jeff Suovanen -
    After replacing the battery, the phone seems dead. I thought it just needed recharging so I left it charging all night. Still dead in the morning. Now I think it might be because the display data cable is off, and I should open the phone and check it. But the battery might be on full power in that case, and they don’t advice to open the phone when battery if full. What can I do?
    Ila Awasthi - 返信
    The advice aims at avoiding battery fire. Just be careful.
    Katherine Williams - 返信
  17. iPhone 6 Plusのリアカメラの交換: 手順 17、 2の画像 1 iPhone 6 Plusのリアカメラの交換: 手順 17、 2の画像 2
    • 最後に、デジタライザーケーブルコネクターの接続を外します。
    • デジタイザーケーブルを再接続する際は、コネクターの中央部分を押さないでください。コネクターの端一方を押してから、もう片方を押し込みます。コネクターの中央を押してしまうと、コンポーネントを曲げてしまい、デジタイザーにダメージを与えてしまうことがあります。
    some images and guidance regarding reassembly would be helpful. You don't need to use the spudger to get them back on: fingers are better because there's a really subtle click you feel when you get them seated properly.
    When you're reassembling, a note that this is the step where you should test for proper screen function would be really useful. First time I reassembled, I didn't seat something properly, got all the screws back together and then realized the screen wasn't functioning properly. Had to disassemble back down to step 14 and then re-reassemble.
    I am having this issues right now! I have unplugged and plugged in these cables at least 20 times and each time I get white lines. I finally have it to where there are only 4 white lines and I am almost willing to live with it. Any suggestions?
    mattmay002 -
    Clean the screen connectors incase they are not making a clean connection
    Karen Jones - 返信
    I'm having nightmares with the digitizer connector. Simply can't get it to work unless I'm applying some pressure on the connectors. Everything seems almost microscopically clean. Any suggestions friends?
    Henry A -
    could it be the replacement screen? test with your old screen and see if you have the same problem.
    Charles - 返信
    To ++mattmay002++  Did you power cycle the phone? Check out the comments on the previous step for a how to.
    Robert Liles - 返信
    I had issues with it too. When connecting this cable, make sure to rock finger side to side after connecting. It’s a wide connector so try to listen for 2 clicks on this one connector. That’s how I fixed mine
    Albert Einstein - 返信
    Re-attaching this cable is the only tricky part to replacing the battery on my 6+. It had a bow on the middle that I had to flatten out before pressing the connector on with finger first on one edge and then on the other. I had white tire tracks on the screen and no touch screen until I connected it correctly. The front has to rest in just the right place on the back while attaching this thing so the cables aren’t strained the front doesn’t fall down. Small fingers would be a plus at this step.
    richard - 返信
    Reseating these connectors on reassembly is definitely the most difficult part of this repair. It took me several attempts before the lowermost connector would seat properly and I did accidentally bend it slightly in the process. Fortunately I was able to get it straight again and get it to click in. The other three went in fine though and no lasting damage seems to have been done.
    Andy Gibbons - 返信
    Another thing - These cables can become overlapped in the wrong way and make you think they are in a different order than they should be. Eg. it’s easy to mix up the ones from step 15 and 17. You can actually unravel the cables and re-layer them on top of each other in any order, so remember this! They look like they’re one solid mass but they’re not.
    domarius - 返信
    I never removed the last digitizer connctor. I removed the first three connectors, left the screen propped at 90 deg tied to a box and removed the battery, there is minimal movement. In fact when I reattached the connectors, only the first and maybe second connector feels taut, so it’s necessary to only remove the first connector if you can be gentle with it. Less headache. And my guess why so many people had issues is that micro dust gets into the connectors and cause connection loss. You be surprised how little dust can cause havoc.
    darrcc - 返信
    And forgot one thing, keep a can of air duster woth you to remove as must dust as you can see. A camera air blower will also do nice.
    darrcc - 返信
    I haven’t removed my screen in past battery replacements, I found it easier. However, this time I followed the instructions because my old battery was very stuck, and I needed the screen gone to get the battery out…
    When I replaced the screen, at first it wouldn’t even boot/start up. (Yes, I inserted my own testing step, as someone here suggested, before final reassembly).
    The screen would just show a fuzzy image, and the board that all the cables attach to would heat up, then it would turn itself off. I tried reconnecting them carefully 3 times, and even made sure to get a little “click”, all to no avail.
    The final try, I used my fingernail to really press down on the back side of the digitizer cable. I heard more clicking, though I thought I might be tearing the cable too. With nothing left to lose, I continued across the back, and heard several more clicking/tearing sounds.
    This worked, and it booted after that. It still had white lines, but those faded away overnight.
    Morgan Giddings - 返信
    About the digitizer connector: its flat cable is so short that the when I attempted to seat the next connector, its flat cable pressed on the digitizer cable, which can pull on the connector and dislodge it. That happened several times for me before success.
    Robert Bernard 27 Nov 19
    Robert H Bernard - 返信
    Nous n’apercevons pas bien les nappes et l’ordre dans lesquelles elles doivent être replacer
    Patrick AZOULAY - 返信
  18. iPhone 6 Plusのリアカメラの交換: 手順 18、 1の画像 1
    • リアケースからフロントパネルアセンブリを取り出します。
    Never remove the screen without disconnecting the battery. It's possible the back light can be blown and that's a even more difficult repair. Always, ALWAYS, disconnect battery before repairing items. (Unless it's not possible.)
    Marvin Ballard - 返信
    How do you disconnect the battery from the screen?
    Shamil Bhatti -
    The Step 11 disconnects the battery :)
    jeffxtechs - 返信
    I think you mean Step 8 :)
    Jeff Suovanen -
    I tried it once and
    Brian - 返信
    And what? I tried it once and here’s a million dollars?
    Oh I get it… they got him! :(
    https://www.youtube.com/watch?v=UlznqpBg...
    domarius -
    When disassembling the iphone at this point note the cables, and there placement/orientation.
    GERARD SZAREK - 返信
    Be really careful with the step after this. Do not commence until you have read all the comments. You need to get a good hold of the plastic strips preferably before they double over on themselves. You have to avoid puncturing the battery at all costs. Slowness and caution here will save you a lot of long term pain.
    Laura Houghton - 返信
  19. iPhone 6 Plusのリアカメラの交換, リアカメラ: 手順 19、 2の画像 1 iPhone 6 Plusのリアカメラの交換, リアカメラ: 手順 19、 2の画像 2
    • ピンセットを使って、リアケースとリアカメラを固定している隠れたネジのテープカバーを取り出します。
    Before peeling back the piece of tape, check the next step to locate the covered screw.
    Peel the tape back only as far needed to remove the screw—the piece of tape covering the screw sticks poorly after being peeled back, and the end may stick upward slightly afterward.
  20. iPhone 6 Plusのリアカメラの交換: 手順 20、 1の画像 1
    • リアケースに留められたリアカメラのブラケットから次のネジを外します。
    • 1.7 mm プラス#00 ネジー1本
    • 2.3 mm プラス#00 ネジー1本
    Careful to not unscrew the screw right below the 2.3 mm one circled in orange. I did it and some mystery part that was attached to the camera bracket broke off as it was attached to that screw and pretty fragile !
    nanomeko - 返信
    The part that fell off is the nfc cable for apple pay which is housed behind the camera
    nanomeko - 返信
  21. iPhone 6 Plusのリアカメラの交換: 手順 21、 1の画像 1
    • リアカメラブラケットからリアカメラを持ち上げて外します。
    There is a small ribbon cable under the right screw tab, it sticks to the bottom of the bracket. Be careful to separate them when lifting away the bracket and don't rip off the cable.
    Steve Berardi - 返信
  22. iPhone 6 Plusのリアカメラの交換: 手順 22、 1の画像 1
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからリアカメラコネクターの接続を外します。
    Reassembly:
    The rear-facing camera cable may need to be pressed down slightly along the side of the camera module in order to align the connector with the socket on the logic board.
  23. iPhone 6 Plusのリアカメラの交換: 手順 23、 1の画像 1
    • 丁寧にiPhoneからリアカメラを持ち上げて取り出します。
    Does anyone know if the bracket that the camera module rests in, is removable?
    I bought a new back housing, but I don't see anywhere if the bracket is removable. I don't even think it was removed by the ifixit team during the teardown...
    Will - 返信
    Note that the new camera may have a small plastic shield over the lens that should be removed before installation!
    Matthew Olwell - 返信
    There is a magnetic component in the camera module—while moving parts around, be careful to keep any magnetic sources away from the replacement camera module.
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
150 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
9人の作成者と共同で作成されました。
Walter Galan
694,627 ポイント
1,203のガイドは作成済み
21 件のコメント
Great how-to article. I was able to follow it and fix my son's camera within an hour. Patience is key -- take your time and stay organized and you'll get through this.
Josh Gormley - 返信
Great guide, replacement worked a treat!
eric - 返信
I liked How you explained step by step thanks
Reynaldo - 返信
After the replacement the LCD started to freezing.
auwadhablani - 返信
after my replacement with the ifixit camera, my camera twitches and will not focus :(
Brent Conklin - 返信
great, easy to follow directions... which i followed 3 times... d’oh! after the initial replacement, wondered why the picture was slightly out of focus... and it dawned on me there might be a protective film on the camera lens… BINGO. that problem solved… until i had NO picture after the second try. turns out i didn’t have the camera connector seated securely. third time was the charm.
craig rousseau - 返信
After change it my rear camera still stuck..and cannot use my flashlight..how????
bro fix - 返信
Mission accomplished after 90 min. No problems. Reading the extra comments by the users is mandatory.
Macrele - 返信
Did all these steps put new camera in and reassembled now blank screen when I use camera and flash not working so I reinstalled the old one and everything worked again but old cameras still not focused so I put new one in and same blank screen and I have a warning says flash to hot let cool down and either it or camera still not working also I reset phone still no go
2005harleyDarcyHrytsay - 返信
Wow what an amazingly EASY FIX. My picture was wavy and shaking before and now it works just like new. Thanks for the great guide and thanks to IFIXIT for supplying the part at such a great price.
Billy Ayoubi - 返信
This was amazingly simple and fixed my problem completely. Blurry camera that wouldn’t focus. The “isight” module was most likely gone in my old camera. Managed to fix in 20 minutes with zero issues on an iPhone 6 Plus - not a 6s Plus. If you have any questions at all or feel nervous about doing this upgrade, feel free to send me a message.
Wolfsuul - 返信
Great guide! Replaced my mother’s iPhone rear camera with new iFixit parts, and works perfect! Took 30 mins.
Stanislaw - 返信
Worked like a charm. Only took 20 min like the guide said.
Apple has issued a recall on iPhone 6+ back cameras and will replace them for free… unless you’ve already replaced your battery with one of the high quality iFixit ones. If you have they’ll waste an hour+ of your time in the apple store and then send you home to do it yourself, even though they admit the original part is faulty. Good times.
TheNickus - 返信
My rear camera was wavy and wouldn’t focus. It had double vision like a drunk person. This fixed it!
murat mckeown - 返信
Thank you for the guide. I had my wife’s camera, which the optical stabilizer was shaking like crazy, replaced in about 30 minutes.
bernardalm - 返信
You guys rock. I got the part, the tools, and had the camera swapped out and working in under 30 minutes! Thank you!
Mike Storck - 返信
Thank you for the wonderful guide. This was my first attempt at repairing something as small and intricate as an iPhone. I was able to complete the replacement of the rear camera without any issues. I now have a brand new camera in my iPhone 6 plus, and a phone that will last me for a while. This repair has inspired me to repair more things, and how I can help others repair their tech.
John Johnson - 返信
Hi,
I followed these instructions to the letter and everything went perfectly, but it has not solved the camera problem. The image, before I take the photograph, and then the resulting photograph itself are both very grainy, dark and blurry, as if a “light meter” is not working. Is there anything else I can do to fix the problem?
I suspect, although I am not sure, that the problem with the camera may have originated in a fall I had with the phone in hand: this cracked the front screen protector, but not the screen itself. There are a few missing pixels in the top left-hand corner of the screen to the right OSMC the rear-facing camera.
Nicholas Law - 返信
…to the right of the rear-facing camera.
Nicholas Law - 返信
Too easy. Lost 1 screw on the battery disconnect but got it together and working perfectly fine again. Got spare screws on order if I ever decide to disassemble the phone again. Glad I got my camera back in business! Feels rewarding to do it yourself!
Daniel Glodowski - 返信
It took me two tries to get it to work. I must not have had a good hookup on one of the cables the first time. Now all is working and thanks for a great write up and pictures.
Dave
David Reina - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 26
過去 30 日: 77
今までの合計 96,133
