メインコンテンツにスキップ
はじめに
Prerequisite to remove the camera after the logic board.
パーツ
パーツは指定されていません。
  1. Using a pair of tweezers, flip the rubber camera cover out of its clip and toward the outside of the rear case. Do not attempt to fully remove this cover. It is attached to the rear case and only needs to be flipped open, not removed. Do not attempt to fully remove this cover. It is attached to the rear case and only needs to be flipped open, not removed.
    • Using a pair of tweezers, flip the rubber camera cover out of its clip and toward the outside of the rear case.
    • Do not attempt to fully remove this cover. It is attached to the rear case and only needs to be flipped open, not removed.
  2. Remove the rear-facing camera from the rear case. During reassembly, the camera cable should bend in a 'U' shape to slot in behind the logic board. If the rubber camera bumper has shifted, be sure to replace it before reassembling your iPhone.
    • Remove the rear-facing camera from the rear case.
    • During reassembly, the camera cable should bend in a 'U' shape to slot in behind the logic board.
    • If the rubber camera bumper has shifted, be sure to replace it before reassembling your iPhone.
終わりに
5 の人々がこのガイドを完成させました。
Sam Goldheart
メンバー登録日: 2012年10月18日
442,347 ポイント
547のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
138 メンバー
17,020のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,399
