はじめに
Use this guide to replace the sensor cable containing the front-facing camera, microphone, ambient sensors, and the earpiece speaker contact pad, in your iPhone 5s.
You can also use this guide to replace the following parts:
必要な工具と部品
Power off your iPhone before beginning disassembly.
Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
この手順で使用する道具:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
Open the phone just enough to reveal the metal bracket covering the home button cable.
Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
Use the tip of a spudger to push the bracket free and remove it with tweezers.
Use the tip of a spudger to pry the home button cable connector up out of its socket.
Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the two screws securing the upper component bracket:
4.0 mm Phillips #000
2.3 mm Phillips #000
Place the earpiece speaker bracket over the speaker so that it fits snugly in its housing.
Slide the left hook of the bracket into the notch above the top left corner of the front facing camera.
Rotate the bracket so it lays flat on the rear case, aligning the two screw holes. Press the bracket into place, ensuring the hook on the right side of the metal bracket latches onto the display.
この手順で使用する道具:iOpener$19.99
Using an iOpener to soften the adhesive will help safely remove it. Follow our iOpener instructions to use it.
Remove any plastic coverings from the microphone on the sensor cable assembly.
152 の人々がこのガイドを完成させました。
21 件のコメント
I'm confused as to what you attach the top part in the last picture, the part with yellow or orange on it? Does that connect to the grounding sticker portion? And how is that removed originally, just by pulling it off?
How do you attached the copper grounding shield to the new proximity flex ribbon?
I can't find a video showing that anywhere
jlh -
I have to second Machek Kozoil's question. What do you do with the yellow contacts? I can get the proximity sensor to work but not the camera. I assume it has to do with these yellow contacts. Any ideas? If anyone knows I will make a youtube video explaining this for others as I haven'y found one yet. In the link below I have included a picture of the factory part on top and replacement part on bottom.
lanekrarup - 返信
As someone has suggested, it is probably a part used in manufacturing process. The original part doesn't have it, and it seems to be cut off. And that is exactly what I did, and everything works. There is nowhere to attach it anyway so instead of folding it and trying to fit it in, you might as well just cut it off.
This is not a good guide. iFixit have been very lazy on the final, critical points regarding the EMI shielding. Without correct shielding the screen will wobble or the camera/proximity sensors will fail.
