必要な工具と部品
With a grand variety of colors to choose (white, blue, pink, green, and yellow), we decided on blue
What difference is there between the iPhone 5c and the iPhone 5? We are going to discuss this. To begin, the back cover is composite plastic, it seems that our work is really cut out for us here...
The technical specifications include:
Apple A6 chip system (SoC)
4 inch retina screen (1136-by-640-pixel resolution at 326 ppi)
8 megapixel iSight camera
4G LTE connectivity
16 or 32 GB storage capacity
As promised, each port, button, and physical slider has changed from metal to plastic.
"Very cheap", per chance?
These parts aren't all plastic, if not that they also look like much more than that...
The volume buttons are considerably large, and so are the 10-hole microphone grid and the 16-hole speaker grid (1 and 4 holes respectively)
These super small Pentalobe screws are slightly different than those of the iPhone 5 and 5s.
Now we UNSCREW the two marked screws (see image).
We DISCONNECT three cables (designated by the green markings).
Remove the black battery cable with CAUTION.
Remove the following Phillips #000 screws that hold support to the front panel assembly to the logic board.
Two 1.3mm screws
A 1.7mm screw
A 3.25mm screw
Use a plastic spudger tool to disconnect the front camera and the connector for the sensor cable.
Remove all of the Phillips #000 screws (2.0mm) that are fixed to the logic board.
The front part of the logic board:
Apple A6 APL0598 application processor
Qualcomm MDM9615M LTE WiFi module
Qualcomm WTR1605L LTE / HSPA + / CDMA2K / TDSCDMA / EDGE / GPS Tranciever
While not as flashy as its newest counterpart, we have to admit a certain affection for the A6 chip.
The iPhone 5c contains 1 GB of ram DDR2 with the A6 system chip.
The back portion of the logic board:
Toshiba THGBX2G7B2JLA01 128 Gb (16 GB) NAND flash
Apple 338S1164
Apple 338S1116 Cirrus Audio Codec
Qualcomm PM8018 RF power management IC
Broadcom BCM5976 Tactile touchscreen driver
Murata 339S0209 WiFi module (based on the Broadcom BCM4334)
11 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
コメント 1 件
This is a review that’ll get you about half way there, and then you’re on you’re own trying to figure out a whole bunch of other things… Kind of sucked.
