必要な工具と部品
Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
Disconnect the rear facing camera cable connector from its socket on the logic board.
Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
