メインコンテンツにスキップ
はじめに
For an easier repair, use our fix kit and follow this shorter guide to replace your iPhone 5’s entire screen.
For more advanced fixers, this guide will help you replace only the iPhone’s LCD + digitizer assembly (a.k.a. the bare “front panel”). This requires you to transfer several components from your original screen to the new one before installing it—including the front-facing camera, earpiece speaker, LCD shield plate, and home button assembly.
You can also use this guide to replace the front panel assembly cable bracket.
Need a guide for the iPhone 5s LCD and digitizer instead? We got you covered!
ビデオの概要
  1. If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
  3. In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips. Regardless of the tool you use, you need to be sure you pull up the entire display. If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5 that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip to Step 6.
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  4. Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case. The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on Step 9.
  5. Press a suction cup onto the screen, just above the home button.
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
  6. Make sure the suction cup is firmly attached to the front panel assembly.
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The screen is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  7. Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
  8. Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone. Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. Remove the following two screws securing the metal battery connector bracket to the logic board:
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
  10. Remove the metal battery connector bracket from the iPhone.
    • Remove the metal battery connector bracket from the iPhone.
  11. Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  12. Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
  13. Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone. During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
  14. Make sure the battery is disconnected before you disconnect or reconnect the cables in this step. Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables: Front-facing camera and sensor cable
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  15. Remove the front panel assembly from the rear case.
    • Remove the front panel assembly from the rear case.
  16. Remove two screws securing the front-facing camera bracket to the display assembly.
    • Remove two screws securing the front-facing camera bracket to the display assembly.
    • One 4.1 mm Phillips screw
    • One 2.2 mm Phillips screw
  17. Remove the earpiece speaker bracket from the display assembly. Remove the earpiece speaker bracket from the display assembly.
    • Remove the earpiece speaker bracket from the display assembly.
  18. Remove the earpiece speaker from the iPhone.
    • Remove the earpiece speaker from the iPhone.
  19. There is a small, black plastic spacer underneath the metal bracket at the upper screw. The upper screw goes through the metal bracket then through this plastic spacer.
    • There is a small, black plastic spacer underneath the metal bracket at the upper screw. The upper screw goes through the metal bracket then through this plastic spacer.
  20. Starting under the earpiece speaker contacts, use a plastic opening tool or the tip of a spudger to pry the front facing camera cable out of the display assembly. Caution: Removing the earpiece speaker contacts can cause them to tear. Use extreme caution when peeling the contacts up.
    • Starting under the earpiece speaker contacts, use a plastic opening tool or the tip of a spudger to pry the front facing camera cable out of the display assembly.
    • Caution: Removing the earpiece speaker contacts can cause them to tear. Use extreme caution when peeling the contacts up.
  21. Remove the front-facing camera and rear microphone assembly. If you are installing a new part, your new part may have two tabs with holes in it used for manufacturing purposes. These tabs can be cut off with scissors.
    • Remove the front-facing camera and rear microphone assembly.
    • If you are installing a new part, your new part may have two tabs with holes in it used for manufacturing purposes. These tabs can be cut off with scissors.
    • There is a small, square plastic and metal holder for the proximity sensor. This holder is essential for the proximity sensor to function correctly.
    • If replacing the proximity sensor or camera make sure that the holder remains adhered to the back of the display. If it comes off with the old proximity sensor, remove it from the old sensor and use a tiny bit of adhesive to re-attach it to the back of the display.
  22. Remove the two 1.3 mm Phillips #000 screws securing the home button bracket to the display assembly.
    • Remove the two 1.3 mm Phillips #000 screws securing the home button bracket to the display assembly.
    • NOTE: When reinstalling the two 1.3 mm Phillips #000 screws, take care not to over tighten them as they can penetrate the other side of the display.
  23. Use a plastic opening tool to pry the edge of the home button ribbon cable up from the display assembly. Start on the right, at the area of the ribbon cable between the gold contact points, and work to the left.
    • Use a plastic opening tool to pry the edge of the home button ribbon cable up from the display assembly.
    • Start on the right, at the area of the ribbon cable between the gold contact points, and work to the left.
    • Going left to right may rip your ribbon cable as the contacts are well adhered to the front panel.
    • Prying directly at one gold contact point or the other may break its soldering and pop it off the ribbon cable.
    • If you have trouble sliding the plastic opening tool under the contact points, flip the tool over and gently push against the right side of the contacts to loosen the adhesive, then try again.
  24. Use a plastic opening tool to pry the home button up from the display assembly. Use a plastic opening tool to pry the home button up from the display assembly.
    • Use a plastic opening tool to pry the home button up from the display assembly.
  25. Remove the home button from the display assembly.
    • Remove the home button from the display assembly.
  26. Remove two 1.2 mm Phillips screws from each side of the LCD frame (four total). Remove two 1.2 mm Phillips screws from each side of the LCD frame (four total).
    • Remove two 1.2 mm Phillips screws from each side of the LCD frame (four total).
  27. Remove the two screws securing the LCD shield plate to the display assembly:
    • Remove the two screws securing the LCD shield plate to the display assembly:
    • One 1.4 mm Phillips screw
    • One 2.6 mm Phillips screw
  28. Remove the LCD shield plate from the display assembly. Remove the LCD shield plate from the display assembly.
    • Remove the LCD shield plate from the display assembly.
  29. The bare display assembly remains.
    • The bare display assembly remains.
    • For reassembly, make sure to transfer over the LCD shield, home button, front facing camera assembly, front facing camera lens bezel and earpiece speaker to your new part.
    • If the replacement screen seems to not fit in the original frame, do not put too much force on the screen, or the glass might crack. Instead, try inserting the screen at a 30° angle, starting at the top. The aim here is to get the three plastic brackets under the metal frame of the phone and move with slight pressure from the sides to the bottom.
    • Make sure to remove the protective cover from your new display assembly as well as the protective cover on the back of the LCD.
    • Note: When reassembled, the screen may not turn on. Try fixing this by plugging your phone in, and holding down the power and home buttons at the same time for 20 seconds.
終わりに
1565 の人々がこのガイドを完成させました。
Andrew Optimus Goldheart
メンバー登録日: 2009年10月17日
474,252 ポイント
410のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
137 メンバー
16,409のガイドは作成済み
141 件のコメント
As far as screens go, with the technology and build quality involved, I dont see this screen going under $200. Wasn't difficult at all, but there are still many steps involved. Great guide ifixit!
crevz - 返信
Actually right now they are $30 for Grade A.
Josh Bacon -
12 for a copy :D the 6s screens are also dropping, it happens every year. might be different with iphone 8 oled display though
Ethan Chow -
iPhone 8 screen replacements now less than $20 :)
Esther Goldberg -
thanx for all your great repair manuals
adam - 返信
コメントを追加
統計データを表示:
過去 24時間: 25
過去 7 日: 202
過去 30 日: 710
今までの合計 2,517,326
