メインコンテンツにスキップ
iPhone 5 Display Assembly Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. iPhone 5 Display Assembly Replacement, Safety Precautions and Replacement Preparations: 手順 1、 3の画像 1 iPhone 5 Display Assembly Replacement, Safety Precautions and Replacement Preparations: 手順 1、 3の画像 2 iPhone 5 Display Assembly Replacement, Safety Precautions and Replacement Preparations: 手順 1、 3の画像 3
    • If your display is cracked, keep your eyes and skin protected. Wear Safety glasses to protect your eyes and wear latex or nitrile gloves to protect hands from shrapnel (Make sure you are not allergic to the material of the gloves.).
    • Laying clear packing tape over the broken glass until the whole screen is covered. Doing this can prevent any injuries or glass from being scattered on the table.
  2. iPhone 5 Display Assembly Replacement, Display Assembly Screws Removal: 手順 2、 2の画像 1 iPhone 5 Display Assembly Replacement, Display Assembly Screws Removal: 手順 2、 2の画像 2
    • Before removing the Display assembly, be sure to power off your phone. This can prevent power shortages.
    • Take the 5-Point Pentalobe screwdriver to remove two 3.6 mm Pentalobe screws next to the Lighting Connector (Charging Port).
  3. iPhone 5 Display Assembly Replacement, Display Assembly Removal Part I: 手順 3、 1の画像 1
    • An X-acto blade will be used for this step. Take immense caution when using the blade. Always cut away from you.
    • Extend the blade 2mm from closed position.
    • Place blade between the display assembly and the phone housing.
    • Push down between the display assembly and the phone housing until you see a gap. Once you see the gap, pry up using the blade to keep the gap.
  4. iPhone 5 Display Assembly Replacement, Display Assembly Removal Part II: 手順 4、 1の画像 1
    • Now that there is a fixed gap, use your plastic pry tool to pry around the display assembly, to separate the screen from the phone.
    • If you hear clicks, that means the display bezel is un-clipping from the phone, which is good.
  5. iPhone 5 Display Assembly Replacement, Display Assembly Removal Part III: 手順 5、 1の画像 1
    • Gently lift the display assembly away from the phone, and make a 90 degree angle with respect to the horizontal.
  6. iPhone 5 Display Assembly Replacement, Connector Protective Plate Removal: 手順 6、 1の画像 1
    • Locate the Connector Protective plate, it is at the top right of the phone. Along the side of the power button.
    • Take your #000 Phillips head screwdriver to unscrew three Phillip screws holding the Connector Protective plate to the logic board.
    • Once all the Phillips screws and removed, remove the Connector Protective Plate from the phone.
  7. iPhone 5 Display Assembly Replacement, Disconnecting Display Assembly Cables: 手順 7、 2の画像 1 iPhone 5 Display Assembly Replacement, Disconnecting Display Assembly Cables: 手順 7、 2の画像 2
    • Locate three cables that link from the back of the display assembly to the logic board.
    • Slowly, remove each cable with pliers.
  8. iPhone 5 Display Assembly Replacement, Display Assembly Full Removal: 手順 8、 1の画像 1
    • Now that the three cables are disconnected, remove the old Display Assembly and store it safely.
  9. iPhone 5 Display Assembly Replacement, Clean the Internals: 手順 9、 1の画像 1
    • Using compressed air specifically for electronics, blow away any dust and trash from the phone.
  10. iPhone 5 Display Assembly Replacement, Reverse: 手順 10、 1の画像 1
    • Perform everything in reverse with the new Display Assembly.
終わりに
13 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Xavier Benavides
メンバー登録日: 02/27/15
821 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,775
