メインコンテンツにスキップ
iPhone 4S Rear Panel Replacement
必要な工具と部品
  1. iPhone 4S Rear Panel Replacement, Rear Panel: 手順 1、 1の画像 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
    • Be sure the driver is well-seated when removing Pentalobe screws—they are easy to strip.
  2. iPhone 4S Rear Panel Replacement: 手順 2、 2の画像 1 iPhone 4S Rear Panel Replacement: 手順 2、 2の画像 2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4S Rear Panel Replacement: 手順 3、 1の画像 1
    • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
    • Remove the rear panel from the iPhone.
終わりに
808 の人々がこのガイドを完成させました。
作成者
15人の作成者と共同で作成されました。
Walter Galan
694,627 ポイント
1,203のガイドは作成済み
15 件のコメント
If you have trouble removing the back after sliding it, do not force or pry it. You didn't push it far enough. Gently push it further and it will come off easily!
Stephen Foskett - 返信
On the iPhone 4S Mirrored Rear Panel there was a clear plastic covering on the INSIDE side of the Panel that covers a jagged black area. There is also a small plastic covering over the camera lens, also on the inside side of the Panel. The iFixIt step-by-step instructions do not include any information about whether to remove these or leave them. I chose to peel them off and it appears everything works okay. But there probably should have been a mention about what to do with these "stickers."
jlinder1 - 返信
Thanks! I didn't notice the scuff covers until we noticed the poor quality of the photos. After I took the back off and removed the film covers, the photos are back to the original quality. Thanks again for your comment. The covers should have an obvious tab on them for easy removal
David Bergum -
www.partoflaptop.com/iphone-4s-repair-parts_iphone-4s-rear-panel-replacement.html
li ma - 返信
there are many kinds of iphone 4s rear panel from this site:
li ma - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 31
過去 30 日: 105
今までの合計 260,177
