はじめに
Use this guide to replace the power and sensor cable. This part contains the proximity sensor, ambient light sensor and power cable.
必要な工具と部品
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
Remove the following screws securing the battery connector to the logic board:
One 1.7 mm Phillips screw
One 1.5 mm Phillips screw
Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
Wait about one minute for the alcohol solution to weaken the adhesive.
Use the flat end of a plastic opening tool to gently lift the battery.
Remove the following screws securing the dock connector cable cover to the logic board:
One 1.2 mm Phillips screw
Remove the metal dock connector cable cover.
Use a SIM eject tool or a paperclip to eject the SIM and its tray.
Remove the SIM and its tray.
Remove the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Front facing camera cable
Digitizer cable
Display data cable
Power button cable (located underneath the headphone jack/volume button cable as shown in the second picture.)
Use the edge of a plastic opening tool to carefully pry the metal front facing camera retainer away from the case of your iPhone.
Remove the front facing camera retainer.
Remove the two 1.6 mm Phillips screws securing the power button bracket to the outer case.
Slightly pull the power button bracket away from the outer case.
Use the edge of a plastic opening tool to pry the earpiece speaker off the adhesive securing it to the outer case. Note that the power button cable is glued to the the case as well, and will need to be pried up.
Use a pair of tweezers to unfold the earpiece speaker from its recess in the outer case.
Use the edge of a plastic opening tool to peel the earpiece speaker off the foam adhesive securing it to the iPhone.
Remove the earpiece speaker.
Use the edge of a plastic opening tool to separate the power button contact from its plastic bracket.
532 の人々がこのガイドを完成させました。
20 件のコメント
The #00 Phillips and 2.5 mm flat head screwdrivers that are suggested tools are too big. I needed to use a #000 Phillips and 5/64 in flat head screwdrivers.
This repair will destroy your soul. I would not recommend even attempting it without even more specialized tools (eye loupe, headlamp, preternatural patience) as it is extraordinarily easy to ruin your phone with one quick misstep. I've thrown in the towel after weeks of attempting the job. After ripping the screen cable for the second and final time, I'm selling for parts.
