メインコンテンツにスキップ
iPhone 4S Battery Replacement
必要な工具と部品
  1. iPhone 4S Battery Replacement, Pentalobe Screws: 手順 1、 1の画像 1
    • Remove the Bottom Pentalobe Screws next to the charger connecter.
    • It is recommended that you use a small 5-Point screwdriver.
    • Remember to make sure your iPhone is fully turned off before tearing it down, to prevent serious injury.
  2. iPhone 4S Battery Replacement, Back Panel Removal: 手順 2、 2の画像 1 iPhone 4S Battery Replacement, Back Panel Removal: 手順 2、 2の画像 2
    • Push the back panel towards the top edges of the iPhone. Doing this should allow the back to slide off.
    • Do NOT apply so much pressure. Especially if your iPhone is cracked.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: 手順 3、 1の画像 1
    • Remove these two screws that are securing the battery connecter to the Logic Board.
    • Remember to focus and pay attention. So you don't accidentally slip and pierce the Battery!
    • For the bottom screw, it is recommended that you use a 1.5 mm Screwdriver, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: 手順 4、 1の画像 1
    • Locate and pull the Plastic tab to pull out battery. Make sure to pry up outsides of battery on other sides as well.
    • Do not pull the plastic tab to hard, as it can easily rip!
  5. iPhone 4S Battery Replacement, Battery Removal: 手順 5、 1の画像 1
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone once its all finished.
終わりに
60 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Cole Anello
メンバー登録日: 11/01/16
1,986 ポイント
1ガイドが承認済み
コメント 1 件
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 32
過去 30 日: 167
今までの合計 20,723
