メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhone 4 Verizon Power Button Replacement
必要な工具と部品
    1. iPhone 4 Verizon Power Button Replacement, Rear Panel: 手順 1、 1の画像 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
      • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
      FixBotに聞いてみる
      コメントを追加
    2. iPhone 4 Verizon Power Button Replacement: 手順 2、 2の画像 1 iPhone 4 Verizon Power Button Replacement: 手順 2、 2の画像 2
      • Push the rear panel toward the top edge of the iPhone.
      • The panel will move about 2 mm.
      FixBotに聞いてみる
      コメントを追加
    3. iPhone 4 Verizon Power Button Replacement: 手順 3、 1の画像 1
      • Pinch the rear panel with your fingers, and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
      • Be careful not to damage the plastic clips attached to the rear panel.
      FixBotに聞いてみる
      コメントを追加
    1. iPhone 4 Verizon Power Button Replacement, Battery: 手順 4、 1の画像 1
      • Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
      FixBotに聞いてみる
      コメントを追加
    2. iPhone 4 Verizon Power Button Replacement: 手順 5、 1の画像 1
      • Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
      • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
      • Remove the metal clip covering the antenna connector.
      FixBotに聞いてみる
      コメントを追加
    3. iPhone 4 Verizon Power Button Replacement: 手順 6、 2の画像 1 iPhone 4 Verizon Power Button Replacement: 手順 6、 2の画像 2
      • Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
      • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
      • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
      • Remove the battery.
      • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
      • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
      • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
      FixBotに聞いてみる
      コメントを追加
    1. iPhone 4 Verizon Power Button Replacement, Dock Connector Cable: 手順 7、 2の画像 1 iPhone 4 Verizon Power Button Replacement, Dock Connector Cable: 手順 7、 2の画像 2
      • Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
      • Remove the thin metal dock connector cable cover.
      FixBotに聞いてみる
      コメントを追加
    2. iPhone 4 Verizon Power Button Replacement: 手順 8、 1の画像 1
      • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
      FixBotに聞いてみる
      コメントを追加
    3. iPhone 4 Verizon Power Button Replacement: 手順 9、 1の画像 1
      • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
      FixBotに聞いてみる
      コメントを追加
    4. iPhone 4 Verizon Power Button Replacement: 手順 10、 2の画像 1 iPhone 4 Verizon Power Button Replacement: 手順 10、 2の画像 2
      • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
      • Remove the pressure contact.
      FixBotに聞いてみる
      コメントを追加
    5. iPhone 4 Verizon Power Button Replacement: 手順 11、 2の画像 1 iPhone 4 Verizon Power Button Replacement: 手順 11、 2の画像 2
      • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
      • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
      • When reconnecting the antenna wire be VERY certain that the round connector at the end of the wire is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connector.
      FixBotに聞いてみる
      コメントを追加
    1. iPhone 4 Verizon Power Button Replacement, Rear Camera: 手順 12、 1の画像 1
      • Remove the following five screws:
      • Three 1.3 mm Phillips screws
      • One 1.5 mm Phillips screw
      • One 2.4 mm Phillips screw
      FixBotに聞いてみる
      コメントを追加
    2. iPhone 4 Verizon Power Button Replacement: 手順 13、 2の画像 1 iPhone 4 Verizon Power Button Replacement: 手順 13、 2の画像 2
      • Lift the cable cover from its edge nearest the top of the iPhone.
      • Pull the cable cover tabs out of their slots cut into the EMI shield on the logic board and remove it from the iPhone.
      FixBotに聞いてみる
      コメントを追加
    3. iPhone 4 Verizon Power Button Replacement: 手順 14、 2の画像 1 iPhone 4 Verizon Power Button Replacement: 手順 14、 2の画像 2
      • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
      • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
      • Remove the rear camera from the iPhone.
      • Be careful not to scratch the back of the display assembly after the removal of the rear facing camera.
      FixBotに聞いてみる
      コメントを追加
    1. iPhone 4 Verizon Power Button Replacement, Logic Board: 手順 15、 1の画像 1
      • Disconnect the five cables near the top of the logic board in the following order:
      • Headphone jack/volume button cable
      • Power button cable
      • Front facing camera cable
      • Digitizer cable
      • Display data cable
      • To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
      • Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
      FixBotに聞いてみる
      コメントを追加
    2. iPhone 4 Verizon Power Button Replacement: 手順 16、 1の画像 1
      • Remove the 1.5 mm Phillips #000 screw near the headphone jack.
      FixBotに聞いてみる
      コメントを追加
    3. iPhone 4 Verizon Power Button Replacement: 手順 17、 1の画像 1
      • Lift the small grounding clip up off the logic board and remove it from the iPhone.
      FixBotに聞いてみる
      コメントを追加
    4. iPhone 4 Verizon Power Button Replacement: 手順 18、 1の画像 1
      • Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna cable connector from the logic board.
      • When reconnecting the wifi ribbon connector to the mother board be VERY certain that the round connector at the end of the ribbon cable is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connection.
      FixBotに聞いてみる
      コメントを追加
    5. iPhone 4 Verizon Power Button Replacement: 手順 19、 2の画像 1 iPhone 4 Verizon Power Button Replacement: 手順 19、 2の画像 2
      • If present, remove the piece of tape covering a Phillips screw near the power button.
      FixBotに聞いてみる
      コメントを追加
    6. iPhone 4 Verizon Power Button Replacement: 手順 20、 1の画像 1
      この手順で使用する道具:
      Standoff Screwdriver for iPhones
      $5.49
      • Remove the 2.5 mm Phillips #000 screw securing the logic board near the power button.
      • Remove the 4.8 mm standoff screw near the headphone jack.
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      FixBotに聞いてみる
      コメントを追加
    7. iPhone 4 Verizon Power Button Replacement: 手順 21、 1の画像 1
      • Remove the 3.4 mm Phillips screw near the vibrator motor.
      • Remove the two 3.6 mm standoff screws along the side of the logic board nearest the battery opening.
      FixBotに聞いてみる
      コメントを追加
    8. iPhone 4 Verizon Power Button Replacement: 手順 22、 1の画像 1
      • Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
      • Remove the logic board.
      • Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
      • There's a small rectangular rubber pad at the top of the logic board that prevents the display cables from chafing against the edge of the board. If it comes loose during your repair, make sure to position it correctly when reinstalling your logic board.
      FixBotに聞いてみる
      コメントを追加
    9. iPhone 4 Verizon Power Button Replacement: 手順 23、 1の画像 1
      • Be sure not to lose the small grounding finger for the rear facing camera near the power button.
      FixBotに聞いてみる
      コメントを追加
    1. iPhone 4 Verizon Power Button Replacement, Power Button: 手順 24、 2の画像 1 iPhone 4 Verizon Power Button Replacement, Power Button: 手順 24、 2の画像 2
      • Remove the two 2.0 mm Phillips screws securing the power button bracket to the outer case.
      • Slightly pull the power button bracket away from the outer case.
      FixBotに聞いてみる
      コメントを追加
    2. iPhone 4 Verizon Power Button Replacement: 手順 25、 2の画像 1 iPhone 4 Verizon Power Button Replacement: 手順 25、 2の画像 2
      この手順で使用する道具:
      • Use a pair of tweezers to remove the power button from the iPhone.
      • During reassembly, take note of the correct orientation of the power button. The metal loop should be facing downwards and the outward edges should be on top.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
74 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Andrew Bookholt
600,880 ポイント
619のガイドは作成済み
6件のガイドコメント
where does the little rubber piece go? on power button or bracket?
marc - 返信 共有
If you look at the Logic Board, the top kind of looks like steps. Find the tallest point, the go left and down one step. The piece goes at the top of this. The thinner part should face towards the back of the phone. It is to protect the LCD cable.
savage24x - 返信 共有
Hello! New to this comment section and love it compared to the YouTube videos that always seem to have the wrong phone... I have a Verizon CDMA iPhone 4 (not 4s). I'm having a problem with the power button. I have changed the ribbon and the button still won't click. I have checked the ribbon button with a pointed screwdriver and it clicks like it should. For example, if I did not put the metal/physical button back into the phone, it would see that I could just poke something inside to turn on and off. Is there a "spring" to the physical button? Do I have something missing? The button seems as it is in the diagrams and I wonder if the wire on the bottom of the button is supposed to provide a springing of some sort...to allow for it to "stay tall" and away from the bubble button on the ribbon. Then when the physical button is pushed it will go down and activate or push the ribbon button, and then click or spring back up. Am I missing something here? Tks GANDL2123@gmail.com
Gregory Tripp - 返信 共有
If someone tells you or you figure it out,can you tell me at dima_fedorov@yahoo.com,or just reply on this.
dima - 返信 共有
"the outward edges should be on top"... what? I have the iphone 4 Verizon and I've followed the instructions to the letter. I have installed the power button with the metal wire thing down towards the screen...the button slides in nicely and I have replaced the new ribbon cable with the copper button on it new and when I test the copper button on the cable itself it does click...but when installed I can't get the button to spring in and out and click like it is supposed to. What am I doing wrong...? Tks to gandL2123@gmail.com. Augusta, GA
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 65
今までの合計 61,668
