メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhone 3GS Logic Board Replacement
必要な工具と部品
  1. iPhone 3GS Logic Board Replacement, Broken Glass: 手順 1、 3の画像 1 iPhone 3GS Logic Board Replacement, Broken Glass: 手順 1、 3の画像 2 iPhone 3GS Logic Board Replacement, Broken Glass: 手順 1、 3の画像 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    FixBotに聞いてみる
    コメントを追加
  2. iPhone 3GS Logic Board Replacement, Logic Board: 手順 2、 1の画像 1
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  3. iPhone 3GS Logic Board Replacement: 手順 3、 1の画像 1
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape, or thick, clear packing tape may be used.
    FixBotに聞いてみる
    コメントを追加
  4. iPhone 3GS Logic Board Replacement: 手順 4、 1の画像 1
    • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
    FixBotに聞いてみる
    コメントを追加
  5. iPhone 3GS Logic Board Replacement: 手順 5、 1の画像 1
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
    FixBotに聞いてみる
    コメントを追加
  6. iPhone 3GS Logic Board Replacement: 手順 6、 1の画像 1
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
    FixBotに聞いてみる
    コメントを追加
  7. iPhone 3GS Logic Board Replacement: 手順 7、 1の画像 1
    • Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
    • Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
    FixBotに聞いてみる
    コメントを追加
  8. iPhone 3GS Logic Board Replacement: 手順 8、 1の画像 1
    • Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
    • Press down on the tool until the SIM card tray pops out.
    • Grasp the SIM card tray and slide it out of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  9. iPhone 3GS Logic Board Replacement: 手順 9、 1の画像 1
    • Use a spudger to disconnect the ribbon cable labeled "4."
    FixBotに聞いてみる
    コメントを追加
  10. iPhone 3GS Logic Board Replacement: 手順 10、 1の画像 1
    • Use a spudger to disconnect the ribbon cable labeled "5."
    FixBotに聞いてみる
    コメントを追加
  11. iPhone 3GS Logic Board Replacement: 手順 11、 2の画像 1 iPhone 3GS Logic Board Replacement: 手順 11、 2の画像 2
    • Use a spudger to disconnect the ribbon cable labeled "6."
    • If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
    FixBotに聞いてみる
    コメントを追加
  12. iPhone 3GS Logic Board Replacement: 手順 12、 1の画像 1
    • Carefully peel up the small sticker labeled "Do not remove."
    FixBotに聞いてみる
    コメントを追加
  13. iPhone 3GS Logic Board Replacement: 手順 13、 1の画像 1
    • Remove the following 8 screws:
    • Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
    • Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
    • One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
    FixBotに聞いてみる
    コメントを追加
  14. iPhone 3GS Logic Board Replacement: 手順 14、 1の画像 1
    • Use a spudger to gently remove the camera retaining clip, (formerly secured by the removed screw) and gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
    FixBotに聞いてみる
    コメントを追加
  15. iPhone 3GS Logic Board Replacement: 手順 15、 1の画像 1
    • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
    • If the board won't lift up, double check to make sure all the screws securing the logic board have been removed.
    FixBotに聞いてみる
    コメントを追加
  16. iPhone 3GS Logic Board Replacement: 手順 16、 1の画像 1
    • Slide the logic board towards the dock connector and out of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  17. iPhone 3GS Logic Board Replacement: 手順 17、 1の画像 1
    • Use a spudger to disconnect the camera from the logic board.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
142 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ben Eisenman
87,850 ポイント
59のガイドは作成済み
1件のガイドコメント
Hi, thank you for the instructions! Maybe you can help. I'm tryin to recover data from a logic board of an iphone 3gs. I bought a working iphone 3gs and opened it, it now has a blue logic board. After replacing the blue to the green, the phone says 'connect to itunes' and does not start properly. Why are there two different colours of logic boards, what's the difference? Thanks for helping!
Julia Marmitt - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 110
今までの合計 181,059
