はじめに
No audio? Replace the headphone jack!
必要な工具と部品
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Remove the two 3.7mm Phillips #00 screws from the dock-connector end of the iPhone.
Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
Rotate the display assembly up until it is at an angle of approximately 45 degrees.
Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1". (Cable 1 is for the display)
Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
Use a spudger to disconnect the black ribbon cable labeled "2". (Cable 2 is for the capacitative touch panel)
Use a spudger to flip up the white plastic tab holding the ribbon cable "3" in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
Press down on the tool until the SIM card tray pops out.
Grasp the SIM card tray and slide it out of the iPhone.
Remove the following 8 screws:
Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear case.
Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
Note for re-assembly:
The screw that goes next to the camera (bottom right orange highlighted screw) also has a metal strip that holds the camera in place.
Use a spudger to gently pry the camera up and out of its housing in the rear case.
Use a spudger to gently pry up the end of the logic board closest to the dock connector.
Slide the logic board towards the dock connector and out of the iPhone.
When replacing the logic board after installing battery, connect the camera to the logic board before inserting it into the case. Then make sure to set the top section of the logic board (where the SIM tray is) in place before settling the rest of the board in place. This is important, as sometimes the SIM card slot will not align into place. Once the top section is in place, the bottom section can be maneuvered into place. You will know the logic board is correctly installed when the SIM tray is aligned with the opening in the iPhone case and the camera module seats neatly into its place.
Use a spudger to pry the battery up from the rear case. The battery is attached with an adhesive strip around the perimeter of the battery.
Remove the two Phillips #00 screws securing the on/off switch to the front bezel.
Remove the four Phillips #00 screws securing the volume and mute switch.
The mute switch assembly screws should be tightened with the switch in the off position. Check the protrusion of the switch when turned on, since it may not stick out far enough to operate if the switch assembly is incorrectly positioned. (Check the gap between the switch frame and the bezel (white gap showing between the two screws near the 6). The screw on the far right is slightly longer than the other 3 screws. When reassembling the phone, keep this in mind.
147 の人々がこのガイドを完成させました。
3件のガイドコメント
My mute/silent switch went bad. I obtained an assembly that included the metal bracket assembly for the mute switch. Here are some issues I ran into and I hope it helps someone out. This repair takes a while - plan on 2 hours or more! I did all my work in a cookie sheet with white paper on the bottom for contrast. It saved me from losing 1-2 screws. Magnetize your screwdriver. My flex cable needed a lot of careful bending to fit the contours needed to route within the phone. I forgot to fold the actual connector up before inserting the logic board, which meant it was hiding under the board, and I didn't notice until I had fully installed the board. This is easy to do on a new flex assembly because the connector want's to lie flat! On reassembly, I had success putting the mute button on the switch, then installing that combination first. Then the volume up/down, then the headphone jack. I placed small plastic shims on the case side and internal side of the headphone jack - for insulation. Part 1
Part 2: Also, there is a gold contact on the top of the headphone jack. There is a spring contact on the display assembly that contacts this - I had to bend my spring down a bit. If this contact is not good the symptom is you won't really be able to turn the headphone volume down low (it stays pretty loud), and you'll get a LOUD click when moving off minimum volume. Also, if you try the phone before fully assembling it keep in mind the "home" button won't work until the display is fully seated into the case.
Hi, -Yeasterday night i did it! Replacing iPhone 3GS Headphone Jack mission Completed!
advice: use a support to view better the screw.
use a 10x lens to help your view
make a sandwich falt cable as per original before put in place (can help and more easy)
bye Giampiero
