メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhone 3G Camera Replacement
必要な工具と部品
    1. iPhone 3G Camera Replacement, Broken Glass: 手順 1、 3の画像 1 iPhone 3G Camera Replacement, Broken Glass: 手順 1、 3の画像 2 iPhone 3G Camera Replacement, Broken Glass: 手順 1、 3の画像 3
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      FixBotに聞いてみる
      コメントを追加
    1. iPhone 3G Camera Replacement, Camera: 手順 2、 1の画像 1
      • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
      FixBotに聞いてみる
      コメントを追加
    2. iPhone 3G Camera Replacement: 手順 3、 1の画像 1
      • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
      • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
      • Be very careful when opening the iPhone so that the cables under the display are not severed.
      • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
      • If the display assembly is to damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape maybe used.
      FixBotに聞いてみる
      コメントを追加
    3. iPhone 3G Camera Replacement: 手順 4、 1の画像 1
      • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
      • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
      FixBotに聞いてみる
      コメントを追加
    4. iPhone 3G Camera Replacement: 手順 5、 1の画像 1
      • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
      FixBotに聞いてみる
      コメントを追加
    5. iPhone 3G Camera Replacement: 手順 6、 1の画像 1
      • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
      • Use a spudger to disconnect the black ribbon cable labeled "2."
      FixBotに聞いてみる
      コメントを追加
    6. iPhone 3G Camera Replacement: 手順 7、 1の画像 1
      • Ribbon cable "3" is held in place by an FPC style connector. Unlocking this connector is a must before removing the ribbon cable: use a plastic spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
      • Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
      FixBotに聞いてみる
      コメントを追加
    7. iPhone 3G Camera Replacement: 手順 8、 1の画像 1
      • Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
      • Press down on the tool until the SIM card tray pops out.
      • Grasp the SIM card tray and slide it out of the iPhone.
      FixBotに聞いてみる
      コメントを追加
    8. iPhone 3G Camera Replacement: 手順 9、 1の画像 1
      • Use a spudger to disconnect the ribbon cable labeled "4."
      FixBotに聞いてみる
      コメントを追加
    9. iPhone 3G Camera Replacement: 手順 10、 1の画像 1
      • Use a spudger to disconnect the ribbon cable labeled "5."
      FixBotに聞いてみる
      コメントを追加
    10. iPhone 3G Camera Replacement: 手順 11、 2の画像 1 iPhone 3G Camera Replacement: 手順 11、 2の画像 2
      • Use a spudger to disconnect the ribbon cable labeled "6."
      • If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
      FixBotに聞いてみる
      コメントを追加
    11. iPhone 3G Camera Replacement: 手順 12、 1の画像 1
      • Carefully peel up the small sticker labeled "Do not remove."
      FixBotに聞いてみる
      コメントを追加
    12. iPhone 3G Camera Replacement: 手順 13、 1の画像 1
      • Remove the following 8 screws:
      • Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
      • Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
      • One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
      FixBotに聞いてみる
      コメントを追加
    13. iPhone 3G Camera Replacement: 手順 14、 1の画像 1
      • Use a spudger to gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
      FixBotに聞いてみる
      コメントを追加
    14. iPhone 3G Camera Replacement: 手順 15、 1の画像 1
      • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
      • If the board won't lift up, double check to make sure all the screws securing the logic board have been removed.
      FixBotに聞いてみる
      コメントを追加
    15. iPhone 3G Camera Replacement: 手順 16、 1の画像 1
      • Slide the logic board towards the dock connector and out of the iPhone.
      FixBotに聞いてみる
      コメントを追加
    16. iPhone 3G Camera Replacement: 手順 17、 1の画像 1
      • Use a spudger to disconnect the camera from the logic board.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
65 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
1件のガイドコメント
Thanks for an awesome guide. On mine after getting it reassembled the camera had a green screen. The cable for the camera got slightly disconnected while putting things back together. I'm thinking because the one I got the ribbon was kinda stiff and straight when it had to fold to go back in properly it came slightly unplugged. I just squashed around the camera corner of the case pinching it, of course not to hard, and it came up and works perfectly now. Thanks again, my friend sold me this iphone cheap cause the camera was broke. Thanks to you its good as new.
Eric - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 69
今までの合計 126,195
