メインコンテンツにスキップ
iPhone 1st Generation Antenna Cover Replacement
必要な工具と部品
  1. iPhone 1st Generation Antenna Cover Replacement, SIM Card: 手順 1、 1の画像 1
    • Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
    • Press down on the paper clip until the SIM card tray pops out.
  2. iPhone 1st Generation Antenna Cover Replacement: 手順 2、 1の画像 1
    • Grasp the SIM card tray and slide it out of the iPhone.
  3. iPhone 1st Generation Antenna Cover Replacement, Antenna Cover: 手順 3、 1の画像 1
    • This image shows the two tabs and two catches located on the underside of the antenna cover. The two tabs at the top of the image must be pushed towards the black cover to release them.
  4. iPhone 1st Generation Antenna Cover Replacement: 手順 4、 1の画像 1
    • Be sure to slide the metal spudger between the dock connector and the antenna cover, and not into the dock connector itself.
    • Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
  5. iPhone 1st Generation Antenna Cover Replacement: 手順 5、 1の画像 1
    • Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
    • Repeat the same procedure on the other side of the dock connector.
  6. iPhone 1st Generation Antenna Cover Replacement: 手順 6、 1の画像 1
    • Grasp the antenna cover on either side and slide it up and away from the iPhone. This requires some force. If it does not come free, ensure that the antenna cover is lifted up enough to free the catches.
終わりに
108 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
3 件のコメント
parece muy bueno pero no entiendo es nada porque los pasos estan es en ingles
Ysmael - 返信
I need help I got my iPhone 2g 4gb pulled off the antenna cover and now it won’t go back on please help me!!!
Sergio Ayon - 返信
This is very helpful
kunle lawal - 返信
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 39
過去 30 日: 95
今までの合計 164,352
