メインコンテンツにスキップ
iPhone 13 No Power Easy Solution
必要な工具と部品
  1. iPhone 13 No Power Easy Solution, Check the iPhone 13 on DC Power: 手順 1、 1の画像 1
    • Prompt to boot and we see that the current jumps to 1.9 AMPs and hangs out.
    • That is a short circuit.
  2. iPhone 13 No Power Easy Solution, Diode mode to find the shorted line: 手順 2、 1の画像 1
    • Diode mode around (red probe on ground) to find the line that is short.
    • Don't fall in love with the cap that you find that shows you the shorted line. It doesn't mean that it is the cause of the shorted line, though it could be.
    • If the line is short anywhere, the line is short everywhere.
  3. iPhone 13 No Power Easy Solution, Determine the line with the short: 手順 3、 1の画像 1
    • This line is short, it looks alot like our 3PV0 Nand Power line that drives power for the Nand chip in every phone.
    • That is a common line for shorts.
    • Now determine which of these components on the line are the cause of the short.
  4. iPhone 13 No Power Easy Solution, Check with thermal cam: 手順 4、 1の画像 1
    • Connect with DC power (make note of the connector direction for the 13 on the squid)
    • Prompt to boot and look for heat near the NAND chip.
    • That cap is the cause of the short.
  5. iPhone 13 No Power Easy Solution, Remove the shorted component: 手順 5、 1の画像 1
    • Remove the black coating from the shorted cap.
    • Check the measurement, it is indeed measuring low resistance to ground.
    • Safest way to remove this cap is to use the iPad Rehab Short Killer and pop that cap off.
    • Check the line to make sure the short was removed.
  6. iPhone 13 No Power Easy Solution, Prompt to boot and SUCCESS!!: 手順 6、 2の画像 1 iPhone 13 No Power Easy Solution, Prompt to boot and SUCCESS!!: 手順 6、 2の画像 2
    • Prompt to boot.
    • DC power looks normal, screen boots with touch.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
jessabethany
メンバー登録日: 12/02/13
30,593 ポイント
1ガイドが承認済み
チーム
Master Techs Master Techs人のメンバー
Community
319 メンバー
1,354のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 50
過去 30 日: 195
今までの合計 2,085
