メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
As we all know, iPhone new series have undergone considerable changes on both inside and outside. Especially on the motherboard. How will these changes affect the repair industry? Will it make third-party repair harder or easier? Find the answer by yourself now.
ビデオの概要
  1. Compared with iPhone X series, iPhone 11 Pro’s motherboard is smaller with a much denser component array. It is also thicker. Remove the graphite thermal transfer material with tweezers first. Fit two screws into the screw holes reserved on the motherboard.
    • Compared with iPhone X series, iPhone 11 Pro’s motherboard is smaller with a much denser component array. It is also thicker.
    • Remove the graphite thermal transfer material with tweezers first.
    • Fit two screws into the screw holes reserved on the motherboard.
    • Place the motherboard on the heating platform to heat for 3 minutes.
    • Clamp the screws fitted into the screw holes with tweezers and pick up the upper layer with tweezers vertically.
    • Continue to pick up the lower layer.
  2. 全てのタブを開く
    Mac用RAMアップグレードキット
    キット商品を見る
    どれだけタブを開いても
    十分に足りるRAM容量
    キット商品を見る
  3. Place the lower layer on the heating platform to heat for 10 seconds. Apply some Paste Flux to the third space PCB evenly. Get the upper layer in position and heat for about 5 minutes.
    • Place the lower layer on the heating platform to heat for 10 seconds. Apply some Paste Flux to the third space PCB evenly. Get the upper layer in position and heat for about 5 minutes.
    • Then, press the SIM card reader with the tweezers and push the upper layer with another tweezers slightly. If the upper layer returns to the previous position automatically, then the soldering process is completed.
Phryne
メンバー登録日: 2019年11月17日
9,473 ポイント
80のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 49
今までの合計 708
