はじめに
このガイドはiPad Pro11を強制的に再起動するために使ってください。
一連の動作で…
音量”+”ボタンを1秒間押して離します。
そしてすぐに音量”-“ボタンを押して離します。
その後、画面上にAppleロゴが表示されるまで5秒以上電源ボタンを押し続けます。
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
5 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
12 件のコメント
It does work on my iPad Pro 11 either please help us I purchased This iPad Pro 11 and Apple Pencil 2 on 3/2/19
Pushing volume up button for 1 second and then pushing volume down button for 1 second are wrong,
should just press them once and release immediately.
Vol Up -> Vol Down -> Power (hold for 5s)
I have tried this “trick” several times and it does not work. I don’t know why I can’t use face id or thumb print like I do with my older Ipad pro. I am getting too old to remember new passwords- That is why I purchased the ipad pro so I could use fingerprint and or face ID. This is driving me crazy!!!
Can you guy help me.i have one pro 2018 with black screen and and circle spin around.
Thanks
Does not work on mine
Siri just Kees coming on?
Thank you, your instructions were clear and worked. That’s the best!
Pushing volume up button for 1 second and then pushing volume down button for 1 second are wrong, should just press them once and release immediately.
Chi Hin Wong - 返信
Thanks for the note. I clarified and rephrased.
Tobias Isakeit -
I’m stuck in an app and doing this doesn’t reboot the ipad, any other suggestions?
Jimi Rice - 返信
You might try putting it in sleep mode and then do the restart procedure. Waking it up from sleep mode by plugging it in and then doing the procedure might be also worth a try.
Tobias Isakeit -
I have been trying to restart it using this method and still cant get it turn on. Is there another way of doing the press and release vol up and dwn and hold top button for 5 sec?
loh kenloong - 返信
Hallo Tobias,
wenn ich es richtig sehe ist der Hinweis von Chi Hin Wong noch nicht übernommen worden.
Deepl übersetzt seinen Hinweis so:
“Das Drücken der Lautstärketaste für 1 Sekunde und das anschließende Drücken der Lautstärketaste für 1 Sekunde sind falsch, sie sollten nur einmal gedrückt und sofort wieder losgelassen werden.”
So habe ich das Ipad Pro zurück gesetzt, nachdem es sich auf schwarzem Bildschirm nur ein ewig rotierendes Rädchen zeigte.
Jess Derboven - 返信
Danke Jess für den Hinweis. Die Übersetzung hat hier ein wenig hinterher gehinkt. Ich habe es soeben im Deutschen angepasst.
Tobias Isakeit -
Thank, thank you thank you……Your fix worked for my Ipad Pro 11 beautifully. The only one that did. I had an unresponsive touch screen and therefore could NOT slide the slider. One second up and then one second down and then just holding the start/stop button brought up the Apple and ten mintues later, when I turned it back on, it was like new. The followed the last 13.6.1 IOS update that I did last night. Worked fine for about six hours and then completely froze. This is my 4th Ipad since the #2 and the first time I’ve had any difficulty with any of them. Again, thank you. ))
leschwartz627 - 返信
You’re welcome
Tobias Isakeit -
