はじめに
Follow this guide to remove or replace the power button assembly on an iPad Pro 9.7".
The power button assembly includes one of two microphones, one of two ambient light sensors, the flash, and the internal power button switch for the iPad Pro 9.7". You may need to replace the power button assembly if any of these components stop working.
Note that this guide is for replacing the internal power button cable and switch assembly, not the external power button face.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
必要な工具と部品
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
この手順で使用する道具:Anti-Clamp
Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
Twist the top and bottom picks to separate the display assembly from the rear case.
Use a Phillips screwdriver to remove the eleven 1.3 mm screws securing the EMI shield.
Slide the battery blocker underneath the left side of the logic board's battery connector at a 35 degree angle.
Leave the battery blocker in place as you work.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the logic board to the left and right of the battery connection.
Wait one minute for the isopropyl alcohol to weaken the adhesive under the logic board.
Try to insert the battery blocker. If the logic board doesn't easily lift up, apply a few more drops of isopropyl alcohol.
Use a Phillips screwdriver to remove the three 1.3 mm Phillips screws securing the display cable bracket.
Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
Slide an opening pick under the right ambient light sensor to loosen its adhesive.
Use a Phillips screwdriver to remove the four 1.9 mm-long screws securing the upper speaker to the frame.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the upper speaker.
Wait one minute for the isopropyl alcohol to weaken the adhesive under the upper speaker.
Use the flat end of a spudger to push the left side of the upper speaker toward the battery just enough for the left speaker to slide out of its recess in the frame.
Use the pointed end of a spudger to disconnect the rear camera's press connector from its socket.
Insert the flat end of a spudger under the bottom edge of the rear camera and pry up to detach it from the frame.
Apply a few drops of high-concentration isopropyl alcohol to all four corners of the flash.
Wait thirty seconds for the isopropyl alcohol to weaken the adhesive securing the flash to the frame.
Use the flat end of a spudger to scrape away the adhesive on the flash.
Use the pointed end of a spudger to disconnect the power button assembly's press connector from its socket.
Apply a few drops of high-concentration isopropyl alcohol to the edges of the power button cable.
Wait thirty seconds for the isopropyl alcohol to weaken the adhesive under the power button cable.
Use an opening pick to cut through the adhesive under the power button cable.
Use a Phillips screwdriver to remove the two 4.4 mm-long screws securing the power button bracket to the frame.
Apply a few drops of high-concentration isopropyl alcohol to the adhesive securing the power button bracket to the frame.
Wait thirty seconds for the isopropyl alcohol to weaken the adhesive.
Use the pointed end of a spudger to scrape away the adhesive on the bottom edge of the power button bracket.
Only the power button assembly remains.
Use a pair of tweezers to remove any leftover adhesive on the power button bracket.
Apply pre-cut adhesive to secure the power button cable to the power button bracket.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 9.7" Answers community for help.
