メインコンテンツにスキップ
はじめに
Prerequisite only. This guide shows how to disconnect the iPad Pro's display assembly.
パーツ
パーツは指定されていません。
  1. Use a Phillips screwdriver to remove the three 1.3 mm Phillips screws securing the display cable bracket.
    • Use a Phillips screwdriver to remove the three 1.3 mm Phillips screws securing the display cable bracket.
  2. Remove the display cable bracket. Remove the display cable bracket.
    • Remove the display cable bracket.
  3. Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket. Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
    • Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
  4. Repeat the previous step for the two remaining connectors. Repeat the previous step for the two remaining connectors.
    • Repeat the previous step for the two remaining connectors.
  5. Remove the display assembly from the frame. If you are reusing the original display assembly, follow this display adhesive application guide to apply replacement display adhesive during reassembly.
終わりに
Arthur Shi
メンバー登録日: 2018年01月03日
173,665 ポイント
428のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
140 メンバー
17,055のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 85
