必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
It's time to pluck the last fall offering from the Apple tree. These are all the juicy details we have so far:
Fully laminated, 12.9" Multi-Touch LCD with a 2,732 × 2,048 resolution at 264 ppi and anti-reflective coating
3rd generation 64-bit A9X chip paired with M9 motion coprocessor
Self-balancing, four-speaker audio
8-megapixel 1080p rear-facing iSight camera + 1.2-megapixel 720p front-facing FaceTime HD camera
802.11a/b/g/n/ac MIMO Wi-Fi + Bluetooth 4.2
Touch ID fingerprint sensor + 3-axis gyro + accelerometer + barometer + ambient light sensor
32 GB or 128 GB on-board storage
この手順は未翻訳です。 翻訳を手伝う。
This 12.9" display has a prolific number of pixels per inch—264 of them to be exact—just a hair shy of the 267 ppi screen on the Surface Pro 4.
With Apple's new A9X chip and a 78% larger display, the Pro packs nearly twice the performance of the iPad Air 2, at less than twice the price.
This also means, thanks to Multitasking, you can use a full Air-sized app, and a secondary app at the same time.
Enough about doubling. The Pro's buttons, microphones, and rear-facing camera are the same size and in the same location as the Air 2's setup.
この手順は未翻訳です。 翻訳を手伝う。
Peeking along the edge of the iPad, we spot a new accessory port—Apple's Smart Connector—making its debut appearance.
On the bottom edge, two of the four speakers in the highly touted speaker array live on either side of a now-familiar Lightning Connector.
Turning our attention to the rear case, we find all the usual regulatory information, including a never-before-seen model number: A1584.
この手順は未翻訳です。 翻訳を手伝う。
It's time for a face-off between the two biggest contenders in the tablet category!
The iPad Pro has a slightly larger 12.9" display—as opposed to the 12.3" display found in the Surface Pro 4.
Despite the larger screen, the iPad Pro manages to be lighter than the Surface Pro 4 (1.57 pounds vs. 1.73 pounds for the i5 and i7 models of the Surface).
The iPad Pro is also thinner than the Surface, with a thickness of 6.9 mm vs. the Surface's 8.45 mm.
For the spec geeks out there, the iPad Pro's dimensions are: 305.7 × 220.6 × 6.9 mm, while the Surface Pro 4's dimensions are: 292.10 × 201.42 × 8.45 mm.
この手順は未翻訳です。 翻訳を手伝う。
この手順で使用する道具:iOpener$19.99-
After a little heat-to-heat with our iOpener, we bring in our opening picks and heavy duty suction cup to open up the conversation.
The Pro's display is packing the same adhesive as its smaller counterparts—it's tough and there's way too much—but it's still no match for our seasoned teardown hands.
With the adhesive finally out of the way, we get our first glimpse of the Pro's interior.
この手順は未翻訳です。 翻訳を手伝う。
Now to remove that (massive) display...
This isn't quite what we're used to! With the logic board situated in the center of the iPad, the display cables connect in the very middle of the device, so we can't even lay the display down while we work.
Instead, we first have to support the weight of the display while removing the screws that secure the display cable bracket.
Is this a giant iPad? Or a giant iPhone?
この手順は未翻訳です。 翻訳を手伝う。
On the back of the display, we find some juicy silicon!
2 × Broadcom BCM15900B0 Touch Screen Controller
NXP Semiconductors 8416A1 (NVT8416) Touch ID Sensor
Parade Technologies DP695 Timing Controller
Texas Instruments TPS65144 (Likely an iteration of the TPS65143A LCD Bias found in the Air 2)
Renesas (formerly Intersil) ISL24879 precision programmable LCD reference voltage generator
Rohm BR24G64NUX-3A 64 KB Serial EEPROM Memory
この手順は未翻訳です。 翻訳を手伝う。
And now back to the body!
A logic board relocation isn't the only easily-recognized layout difference between the iPad Pro and previous iPads. While the iPad Air 2's interior real estate was dominated by a proportionately massive battery, the iPad Pro dedicates a significant amount of room to speaker enclosures.
That's space that could have potentially been used for an extra 50% battery capacity. We're sure Apple was very careful setting the balance between battery capacity, weight, and sound quality.
この手順は未翻訳です。 翻訳を手伝う。
Next, we lend a hand to the FaceTime HD (left) and iSight cameras, which are trapped behind a bracket not unlike the one we dug up in Microsoft's new laplet.
While just about everything in this tablet has been billed as bigger and better than previous devices, these cameras seem to be the same as those found in the iPad Air 2.
この手順は未翻訳です。 翻訳を手伝う。
Here's a first in iPad history: we have to remove the logic board's EMI shielding to remove the logic board itself.
この手順は未翻訳です。 翻訳を手伝う。
As we continue to mine deeper into this iPad Pro, the next
Balrogcomponent we find is the headphone jack. -
Just like the 3.5 mm jack in the iPad Air 2, the ribbon cable on this headphone jack harbors one of the Pro's two front-facing ambient light sensors.
この手順は未翻訳です。 翻訳を手伝う。
Finally, we get to (one of) the highly anticipated self-balancing speaker drivers.
Although these speakers share a common design, their function changes depending on the tablet's orientation. Whether in portrait or landscape mode, the Pro always sends higher frequencies to the topmost speakers to produce a more balanced sound.
この手順は未翻訳です。 翻訳を手伝う。
The speakers are nice, but what makes them really sing are the fancy back volume chambers, machined directly into the unibody enclosure.
After removing the carbon fiber caps, we find the enclosures are filled with foam. Apple's own renders don't actually show this foam, but we're betting that it's used to amplify the effective volume of the enclosure.
That, or the stuffing indicates Apple got into the Thanksgiving spirit early this year.
この手順は未翻訳です。 翻訳を手伝う。
On our way to the logic board, we stop to smell the
flowersantennas. -
Just like the iPad Air 2, the Pro's two antennas use MIMO technology to provide 802.11ac Wi-Fi speeds of up to 866 Mbps, and LTE speeds of up to 150 Mbps.
この手順は未翻訳です。 翻訳を手伝う。
There are just a few things left standing between us and the logic board.
A bit of deft spudgering frees the remaining speaker connectors, and a flex cable that appears to run beneath the left battery cell to drive the Smart Connector contacts.
At long last we've extracted the logic board—and its (sadly) soldered on Lightning connector.
この手順は未翻訳です。 翻訳を手伝う。
We've finally found the brains of the operation, the logic board!
Apple APL1021 A9X 64-bit Processor
SK Hynix H9HCNNNBTUMLNR-NLH 16 Gb (2 GB) LPDDR4 RAM (2 GB × 2 = 4 GB total)
Toshiba THGBX5G8D4KLDXG 32 GB NAND Flash
InvenSense MP67B (MPU-6700B) 6-axis Gyroscope and Accelerometer Combo
NXP 65V10 NFC Controller (also found in the iPhone 6/6 Plus, as well as Nexus 5X and 6P marked NXP 54802)
Apple (Cirrus Logic) 338S1213 Audio Codec
この手順は未翻訳です。 翻訳を手伝う。
Even more chips on the logic board:
Fresco Logic FL1100SX 2-port USB 3.0 Host Controller
Universal Scientific Industrial 339S00045 Wi-Fi Module
NXP Semiconductor 1610A3 (also found in iPhone 6s/6s Plus, likely an iteration of the 1610A1 found in the iPad Mini 4) Display Port Multiplexer (likely)
Dialog Semiconductor 343S00025-A1 Power Management
Dialog Semiconductor 343S00052-A1
Maxim Integrated MAX98721CEWV (likely an iteration of the MAX98721BEWV found in the iPad Air 2) Audio Amplifier
Fairchild Semiconductor FDMC 6683 MOSFET
この手順は未翻訳です。 翻訳を手伝う。
Even, even more chips on the logic board:
AKM Semiconductor AK8963C 3-Axis Electronic Compass
Bosch Sensortec BMA282 Accelerometer
Bosch Sensortec BMP282 Pressure Sensor
STMicroelectronics STM32L052T8 32-Bit Arm Cortex-M0+ Microcontroller w/ 64 Kb Flash
Diodes Incorporated PI3USB102E 480 Mbps USB 2.0 Switch
Texas Instruments TPS3898 Adjustable Voltage Monitor
ON Semiconductor FXMA2102 2-Bit Voltage Translator/Buffer/Repeater Isolator
この手順は未翻訳です。 翻訳を手伝う。
Great Scott! Do our eyes deceive us?
We must have been extra good this year—we've received the gift of adhesive pull tabs under iPad batteries.
We've only been asking for iPad tabs since the very first pull tabs showed up in the iPhone 5s...
These new pull tabs are even cooler than their iPhone counterparts; there's no need to worry about tweezer grip or stubby fingers—these tabs have a handy spudger hole!
この手順は未翻訳です。 翻訳を手伝う。
The last component we'll try to remove on the road to teardown glory is the Smart Connector port cable.
''Try'' being the operative word...
There are no visible screws, and after a lot of Jedi mind tricks, i.e. elbow grease (and totally mangling the cable bracket), the port is still not budging.
After literally smashing the contacts through with a hammer, we manage to free the cable.
この手順は未翻訳です。 翻訳を手伝う。
iPad Pro Repairability Score: 3 out of 10 (10 is easiest to repair)
The battery is not soldered to the logic board, and can now be removed with adhesive tabs, greatly simplifying battery removal.
The Smart Connector port is virtually impossible to replace—but incorporates no moving parts and is unlikely to fail.
The LCD and front panel glass are fused together. This slightly simplifies the opening procedure.
The fused front panel increases the cost of screen repair, and the risk of damaging the LCD when opening.
Gobs of adhesive hold everything in place making all repairs more difficult.
27 件のコメント
The display seemed to come off really easily, and your pics don't show all the messy glue residue we normally see. But you don't mention its thickness or strength, compared to the wafer-thin (and shattering) Microsoft Surface Pro 4.
Also, that unibody shell is one helluva lot of machined-out (and so pretty thin) alumin[i]um - has Apple used the same 7000 series alloy as in the iPhone 6S/6S+ - or are we waiting for Bendgate Pro?
Brian
I'd like to know the same. I have an iPad pro and there's a dent in it. I didn't notice until I got home. However, Apple was right on it by sending me a new one. Just by holding both the 6s plus, which is 7000 and the iPad pro. I must say the iPad pro doesn't seem like it's the same 7000. This is my best guess is because the iPad pro feels a lot like the original 6, which had issues with its housing. Hope this helps.
i actually did a bit of searching on this and it turns out that the ipad pro is mad of 7000 series aluminium to prevent the ipad from bending in bags for example
