はじめに
液晶ディスプレイをひっくり返し、シールドを取り出すための必須条件。
必要な工具と部品
ピンセットを使って、上部右側の液晶ディスプレイに留められたネジを覆っている長方形フォーム製テープを取り外します。
下部右側の液晶ディスプレイに留められた長方形のテープを外します。
背面ケースに留められた液晶ディスプレイから3.9 mm #000プラスネジを4本外します。
In my case the 4 screws are not the same. One is 4mm, and 3 of 3.5mm, or better 2 x 3.5mm and one 3.45mm. I put the longest one at the left edge at left of the LCD flat cable.
mitja
Hi Mitja. I just checked the measurements with an electronic digital caliper. I got 3.9 mm for all four screws. Are you sure it was the same model? Thanks.
ipad mini wifi no screws are longer
液晶ディスプレイのフレームと液晶ディスプレイ上部に留められたテープの隙間にスパッジャーの先端を差し込みます。
液晶ディスプレイのフレームとテープの間のスペースにスパッジャーを差し込んでスライドをさせ、テープを液晶ディスプレイフレームから剥がしていきます。
I finished a successful replacement of my screen following these instructions. Thanks.
Step 36 (remove tape from LCD perimeter), however, seems unnecessary. I ended up spending a lot of time separating the tape from the LCD frame only to discover it was not necessary for steps 37-44 and actually made things really difficult for step 45-46 (removing the tape near the speakers). Finally, steps 45-46 can be skipped since it is much easier to remove this tape once you flip the LCD over (Step 55).
ピックを液晶ディスプレイと背面ケースの間の隙間、液晶ディスプレイの左側上部に差し込みます。
液晶ディスプレイと背面ケースの間の隙間が十分広がるように、ピックをiPadの裏側に向かって引き上げるように曲げていきます。
I found a very simple method for removing the LCD from the metal shield. Slightly lift one of the top corners and insert a 1' piece of fishing line. Insert the line under the other top corner placing the length between the LCD and shield. Once in place, gently pull each end toward the bottom of the LCD breaking the adhesive as you go. This will make things much easier than using the picks and possibly breaking the LCD.
The fishing line trick is amazing… although i had already broken the LCD when i saw that comment. Good Learn!
This step is what destroys my LCDs :(
Dan Harris - 返信
I was able to do this the first time w/out damaging the LCD simply by following the instructions to the letter, slowly and carefully. The only thing I did differently was to follow Northstar’s instructions to remove the two pieces of tape at the bottom of the LCD before beginning.
I found a good way to remove the LCD without breaking it. Once you finish to clean up around the LCD just lift a bit one of the white metal backing plate and insert in the gap a plastified playing card under le LCD and slowly make your way to the center of the LCD. Repeat on the other side and the LCD will lift up intact.
nothing Brocken after
(I did not read the comments before doing it lol)
デバイスの上部右からスパッジャーを液晶ディスプレイフレームとメタル製バッキングプレートの間に差し込み、スライドさせながら接着剤を剥がします。
These steps were hard. I was too scared that I was going to brake the LCD. Luckily I got it off! Don’t know how delicate these things are and how much force they can take.
me to it was hard
液晶ディスプレイを背面ケースから数インチ押し上げます。ディスプレイから接着剤が剥がれていることを確認します。
When I did it I found that the adhesive sticking was mainly on the edges, so if you take a spudger and just break that adhesive carefully it will help. Be gentle lifting the lcd as it’s very breakable.
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
