はじめに
Use this guide to replace the right-hand antenna in your iPad Mini 3.
必要な工具と部品
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Leave the opening pick in the iPad slightly past the front-facing camera.
Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
Antennas
Home button cavity
Digitizer cable
The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
If reusing the front panel assembly during reassembly, you will need to replace your display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
Use the tip of a spudger to lift the digitizer cable connector straight up off of its socket.
Use the tip of a spudger to peel the tape off of the antenna cables near the logic board.
Remove the following Phillips #00 screws from the right antenna:
Three 1.5 mm screws
One 2.6 mm screw
