メインコンテンツにスキップ
iPad Mini 3 Wi-Fi フロントパネルの交換
必要な工具と部品
  1. iPad Mini 3 Wi-Fi フロントパネルの交換, iOpenerの使用方法: 手順 1、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換, iOpenerの使用方法: 手順 1、 2の画像 2
    • 電子レンジに付着している汚れがiOpenerに付いてしまうことがあるので、使用前に電子レンジの底をきれいに拭き取ってください。
    • iOpenerを電子レンジ中央に置きます。
    • 回転型の電子レンジ:iOpenerが電子レンジのターンテーブルで回転しているか確認してください。iOpenerが作動中に留まってしまうと、熱しすぎや焦げてしまいます。
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 返信
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 返信
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 返信
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 返信
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 返信
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - 返信
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - 返信
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - 返信
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - 返信
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - 返信
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - 返信
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - 返信
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - 返信
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - 返信
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - 返信
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - 返信
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - 返信
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - 返信
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - 返信
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - 返信
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - 返信
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - 返信
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - 返信
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - 返信
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - 返信
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - 返信
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - 返信
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - 返信
    Can’t you just use a hair curler instead?
    Aspect22 - 返信
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - 返信
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - 返信
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - 返信
  2. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 2、 1の画像 1
    • iOpenerを30秒温めます。
    • 修理作業中はiOpenerが冷めてしまいますので、使用毎に電子レンジに30秒入れて温めてからご利用ください。
    • 作業中、iOpenerを温めすぎないようにご注意ください。過熱すると、iOpenerが破裂することがあります。100˚Cを超えるまで加熱しないでください。
    • 膨らんでいる状態のiOpenerは絶対に触らないでください。
    • 適切に温められたiOpenerは約10分間、温かい状態を保ちます。
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 返信
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 返信
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 返信
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 返信
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 返信
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 返信
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 返信
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 返信
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - 返信
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - 返信
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - 返信
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - 返信
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - 返信
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - 返信
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - 返信
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - 返信
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - 返信
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - 返信
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - 返信
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - 返信
  3. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 3、 1の画像 1
    • 電子レンジからiOpenerを取り出します。iOpenerの中央は熱くなっているため、両端の平面になっている部分を持ってください。
    • iOpenerは大変熱くなっていることがあります。必要であれば、オーブン用のミトンカバーをご利用ください。
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 返信
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    breadandbits - 返信
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - 返信
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - 返信
    This thing melts when placed up side down in the microwave…
    Mark - 返信
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - 返信
  4. iPad Mini 3 Wi-Fi フロントパネルの交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 2
    • 電子レンジがない場合は、熱湯の中にiOpener をいれて温める方法もあります。
    • 鍋を十分な量のお湯で満たして、iOpener を完全に沈めます。
    • お湯を沸かして熱くなったら火を止めます
    • iOpenerを熱湯の中に約2−3分間沈めます。iOpener全体が完全に浸かっているか確認してください。
    • トングなどを浸かって、温まったiOpenerをお湯から取り出します。
    • タオルでiOpener全体を拭き取ります。
    • iOpenerが非常に熱い場合は、先端のタブを持って火傷をしないようにご注意ください。
    • iOpenerの準備は整いました。iOpenerを再度温める必要がある場合は、お湯を沸騰させて、火を止めてからiOpenerを2-3分間浸してください。
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - 返信
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - 返信
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Robert Garcia - 返信
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - 返信
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - 返信
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - 返信
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
  5. iPad Mini 3 Wi-Fi フロントパネルの交換, LCDシールドプレート: 手順 5、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換, LCDシールドプレート: 手順 5、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換, LCDシールドプレート: 手順 5、 3の画像 3
    • ディスプレイガラスにひびが入っている場合は、ガラス表面にテープを貼り,修復中に怪我をしないように注意してください。
    • iPadのディスプレイの表面全体が覆われように、透明テープを重ね張りします。
    • これにより、ガラスの破片が飛び散らず、ディスプレイを取り外す時に扱いやすくなります。
    • 残りも手順通りに作業をしますが,ガラスが割れてしまうと,ひび割れが広がってしまいます。その場合,金属製のヘラなどを使用する必要があるかもしれません。
    • 必ず,保護メガネを着用してください。また,液晶パネルを傷つけないように注意してください。
    Need some extra instruction on how to handle a truly shattered glass. There was only one spot that the suction cup would even hold on the whole screen - top right, and even with tape there is very little structure to drive a pick under. how do you handle that?
    Greg Crawford - 返信
  6. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 6、 1の画像 1
    • 温めたiOpenerをiPadのホームボタンアセンブリの左横サイドに当たるように載せます。
    • iOpenerを約5分間置き、ガラスの下に付けられた接着剤を柔らかくします。
    Can you explain how using the iOpener ? That's can be great !
    Matthieu Nasri - 返信
    The iOpener used is essentially a bag of gel, which you put in the microwave for 30 seconds. You lay this against the screen edges to transfer heat and loosen up the glue.
    You could also use a hot-air blower with a re-work station but that's up to you. Mine worked well up to 150°C
    Sam Attwood -
    what about heating a cloth bag filled with rice in the microwave? Would that work?
    SkipR - 返信
    That might work! Rice is less likely to get, and stay, hot enough. But it can't hurt to try! Just be sure you're being patient and letting it really warm up before you pry. People have had luck double bagging a washcloth dipped in very hot water, too.
    Sam Goldheart -
  7. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 7、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 7、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 7、 3の画像 3
    • 温めた側の中央部分より少し上辺りに、吸盤カップを取り付けます。
    • 吸盤がしっかりとスクリーンに装着されるように、スクリーン上に完全に平らに付いているかを確認してください。
    • iPadを片手で押さえながら、吸盤カップを上部に向けて引っ張りあげます。
    • ピックを差し込むための充分なスペースを作るため、ガラスを引っ張り上げます。あまり持ち上げ過ぎるとガラスが割れる恐れがあります。
    I'm having trouble getting the suction cup to stay connected to the screen to pull it. It just isn't creating a seal no matter how flat I make it. I thought maybe the crack was causing it, so I tried tape. I originally didn't put tape on it because it wasn't losing glass. The tape made it worse of creating a seal. Any advice?
    William - 返信
    After following instructions to cover cracked glass with packing tape, the suction cup won’t adhere at all. Not even a little bit. Any suggestions?
    Brian Tate - 返信
    I had that exact problem when I fixed an Iphone 8. What I did was that I put some ducktape where the suction cup would be placed. That worked for me. That’s of course is if you where doing to replace the glass anyway.
    Pontus Sennerstam -
    I had a screen on an iPad 4 that was so shattered that I literally had to spend 2.5 hours picking every single piece of glass out with tweezers after pulling the few larger pieces off with tape on them. Sometimes you need a lot of patience to be successful. The final cleaning out of the sticky tape along the sides is also very important once the glass is removed. Or the new screen will stick out an/or not go in neatly.
    Michael Burger - 返信
    I also had a problem getting the suction cup to adhere. Tried tape, no luck until I added some KY jelly, which did the trick.
    cskilton - 返信
  8. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 8、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 8、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 8、 3の画像 3
    • 吸盤でガラスを引き上げながら、ピックの先端をガラスとiPad本体の隙間に差し込みます。
    • ピックをディスプレイ横にある黒い外縁よりも奥に差し込まないでください。深くまで差し込み過ぎると、液晶ディスプレイを傷つけてしまうことがあります。
    • 吸盤カップのプラスチック部分の持ち手(ノブ)を引っ張り、吸盤力を緩めてディスプレイアセンブリから外します。
    Could I use some guitar picks? If so, what gauge (thickness) of a picks should I get?
    SkipR - 返信
    I'm not sure what the correct balance of thickness to strength you'd need, maybe try a couple different types. The idea is to be thin and fit into the smallest gap, but if it gets bogged down in adhesive, it needs to be strong enough to push through. Be sure to use heat and be patient!
    Sam Goldheart -
    i have to use a blow dryer and pack that came with the replacement is there anything i could do to make the adhesive more hot?
    Ace of Spades - 返信
  9. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 9、 1の画像 1
    • iOpenerを再び温めて、同じ箇所に載せます。
    • 作業中、 iOpenerを温めすぎないようにご注意ください。 iOpenerを再度温める場合は、少なくとも前の作業から10分間間隔を置いてから行ってください。
    • iPadの左側を再度温めるため、数分間iOpenerを置きます。
    Well if you want to save some time and your screen is shattered just pry up one corner either left or right side at the top and tear the whole screen off going down towards the home button but do not completely remove the screen there is a wire connecting the digitizer to the board inside but tearing off the screen will skip you down to step 29 :-) i seen this in a video and saved me about an hour after the fact because my screen was cracking as i was inserting the blue picks so i ripped the whole screen off and used some adhesive remover to get off all the extra goo leftover
    Chris Grayden - 返信
  10. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 10、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 10、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 10、 3の画像 3
    • 2番目のピックを1番目を差し込んだ付近に挿入し、iPadの端に沿って接着剤を剥がしながら下側に動かします。
    • 以降の手順でピックをスライドする最中に引っ掛かりを感じた場合は、一旦手を止めてその場所を再度 iOpenerで温めます。無理にピックを動かすと、ガラスが割れる恐れがあります。
    I found that all the following step were much easier for me using a heat gun while keeping the pull on the screen with the suction cup. Basically heat up a section, put the suction cup on, keep pulling the screen upwards on that side, while using the heat gun to continuously heat along the side. It came nicely off, one or two inches at a time. Once I had a whole side up, I just put some of the picks in to keep it up and continued along the side, heating, pulling, heating pulling. This obviously only works if the screen is not totally shattered. Mine only had two cracks.
    Michael Burger - 返信
  11. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 11、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 11、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 11、 3の画像 3
    • 続けて接着剤を剥がしながら、ピックをディスプレイの横から下部に向かって動かしていきます。
    • ピックが接着剤に絡まり動かなくなった場合は、ピックをiPadの横に沿って"回転させながら"接着剤を剥がします。
  12. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 12、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 12、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 12、 3の画像 3
    • 1番最初に差し込んだピックを、iPadの上部端に向かってスライドして動かします。
    • フロントガラス越しにピックの先端が見えても焦らないでください。この場合、ピックを少しだけ外側へ戻して下さい。問題ない場合がほとんどですが、奥まで差し込みすぎないように注意してください。液晶ディスプレイ上に接着剤が付いてしまった場合、取り除くのが難しくなります。。
  13. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 13、 1の画像 1
    • iOpenerを再び温め、iPadの上部端、フロントカメラ上に載せます。
    • 修理作業中、 iOpenerを温めすぎないようにご注意ください。前回の作業から10分間は開けてから iOpenerを再度温めます。
    • 形を自由に変化できるiOpenerをお持ちの場合は、画像のように上部左端コーナーと上部先端を同時に温めるよう曲げてください。
  14. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 14、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 14、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 14、 3の画像 3
    • ピックをiPadの左端上部コーナーにスライドさせて接着剤を剥がします。
  15. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 15、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 15、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 15、 3の画像 3
    • ピックをiPadの上部端に沿ってスライドさせます。カメラの手前で止めます。
    • 3番目の画像はフロントカメラがiPadのどの位置に内蔵されているかを示したものです。
    • ピックをフロントカメラ上にスライドしないでください。レンズ上に接着剤が付着してしまうとカメラを損傷してしまいます。次の手順は正面カメラを傷つけないで作業を進めるための方法を扱っています。
  16. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 16、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 16、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 16、 3の画像 3
    • ピックを少し外側に向かって引き出し、ピックのわずかな先端をフロントカメラ上部に沿ってゆっくりと動かします。
  17. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 17、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 17、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 17、 3の画像 3
    • オープニングピック一度、フロントカメラから少し離れたところにずらします。
    • 別のピックを、カメラの左側に挿し込んでください。最初のピックを挿し込んだ辺りです。これを 隅までスライドさせて、残りの接着剤を完全に剥がします。
    • 接着剤が冷えて再シーリングされないように、二番目のピックを所定の位置に挿したままにしておきます。
  18. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 18、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 18、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 18、 3の画像 3
    • 1つ目のピックを再度深く挿し直し、フロントカメラから角に向かってスライドさせます。
    If you have the LTE there is a cable on the right upper side! There’s no mention of this in this guide even though it’s for the LTE. I found out after the fact when I saw I cut the cable with the pick.
    Will Lyon - 返信
    Will Lyon, you may want to look again. This is the guide for the WiFi version.
    mcr4u2 -
  19. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 19、 1の画像 1
    • iPadの角に3本のピックを残したまま、接着剤が再度粘着するのを防いでおきます。
    • iOpenerを再度温め、iPadのもう片方の長辺に沿って搭載されているボリュームとロックボタン上に載せます。
  20. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 20、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 20、 2の画像 2
    • ガラス上端部を完全に分離するために、上端右側にある開口ピックをコーナー周辺までスライドします。
    • 接着剤が自動的に再接着するのを防ぐため、ピックは差したままにして新しいピックを用意して次のステップに進んでください。
  21. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 21、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 21、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 21、 3の画像 3
    • 新しいピックを挿し込み、iPad上部右側コーナーの中央までスライドさせて粘着を剥がします。
    This is not an LTE ipad mini 3, it is a wifi ipad mini 3
    lordofmordor - 返信
  22. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 22、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 22、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 22、 3の画像 3
    • 続けて接着を分離させながら、iPadの右側下までピックをスライドします。
  23. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 23、 1の画像 1
    • ピックを挟んだまま、iOpenerで再び温めます。
    • iOpenerを温め過ぎないで下さい。次の温め作業までは、10分の間隔を置いてください。
    • 温めたiOpenerをホームボタン端の上に置いてそのまま数分待ち、接着剤を柔らかくします。
    For those who are replacing a severely shattered front panel, be aware that there are two smart cover magnets attached to the interior side of the front panel that you will need later. Keep an eye out for them (see steps 49 and 50 below for pictures of what these tiny magnets look like) so that you don't have to go digging through the debris later.
    Jeff G - 返信
  24. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 24、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 24、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 24、 3の画像 3
    • 本体左側の下に挟んであるピックをスライドさせ左側下のコーナーに付けられた接着材を分離します。
    • ピックを角に挟んだままにします。これ以上こじ開けず、iPadにピックを挟んだままにします。
    • このベゼル下の間には避けるべきパーツが多く搭載されています。3番目の画像をよく確認してください:
    • アンテナ
    • ホームボタン
    • デジタイザーケーブル
    • 以下の手順では、これらのパーツを損傷しないよう、どこをこじ開ければ良いかを示してます。指定された場所をこじ開けてください。
  25. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 25、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 25、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 25、 3の画像 3
    • 前のステップで再接着を防止するため挟んだままの開口ピックは、そのまま残したままにします。
    • 新しいピックで左側アンテナの上をゆっくりと滑らせ、ホームボタン手前で止めます。
    • ピックをスライドする際は、本体外側からiPadの中央に向けてください。中央から外側に向かってピックを動かさないでください。この方向に動かすとアンテナにダメージを与えてしまうことがあります。
    • 開口ピックを2回以上スライドする必要がある場合は、左端外側から中央に向かって取り出し、再度同じ場所からピックを再挿入してください。
    • 次に進む前にピックを挟んだままにします。
  26. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 26、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 26、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 26、 3の画像 3
    • 最後のピックの先端を前の手順で差し込んだピックの付近に差し込み、ホームボタンの下をスライドさせます。
    • デジタイザーケーブルの切断を避けるため右側コーナーから約2.5cmの所で止めてください。
    • ピックを少し深く差し込み、ホームボタンの方向にスライドさせます。
    • 左側のアンテナと同様に、本体外側端から中央に向かってスライドします。中央から外側に向けて動かすと、アンテナを傷つけてしまうことがあります。
    Do NOT insert the pick much deeper to the right of the home button, you can easily damage the fingerprint ID chip.
    kimhoover - 返信
    There is no fingerprint id chip in an iPad mini 2 (retina)
    blakebest -
    Be very careful in the vicinity and to the right of the home button. Only insert the very tip of the pick (similar to the instructions earlier for by the camera). Do not try to go beneath the home but as suggested here, just along the glass edge. I damaged the small metal clip under the button and detached the IC tape from the button, meaning I had to replace the glass touch screen with digitiser and home button.
    PeterB - 返信
  27. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 27、 1の画像 1
    • iOpenerを再び温めてiPadのベゼル上部に当てます。
  28. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 28、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 28、 2の画像 2
    • この手順では特に慎重に作業を進めてください。時間をかけてゆっくりと、接着剤が温められて柔らかくなっているか確認します。開封ピックを使って接着剤全体を剥がします。必要に応じて、作業を中断して iOpenerを再び温めることも考慮してください。
    • ホームボタンと反対側の両角にはピックを挟んだままにします。ガラスを持ち上げるように、ピックを少しひねります。ディスプレイケーブルの端に沿って留められた接着剤が剥がれます。4つ全ての角の接着をはがします。
    • 接着剤から大きな抵抗があった場合、ひねるのを中断します。ピックをそのままにし、iOpenerを再加熱して該当箇所に当て、こう着している所にもう一度ピックを走らせます。
  29. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 29、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 29、 2の画像 2
    • 本体下側の端をゆっくり徐々に持ち上げ、接着を分離します。
  30. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 30、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 30、 2の画像 2
    • 全ての接着がはがれたら、前面ガラスを本のページをめくるように開き作業台に置きます。
    • フロントパネルアセンブリを再利用して再組み立てする際は、ディスプレイ用の接着剤を交換してください。ディスプレイ用の接着剤塗布ガイドを参照して、デバイスに接着剤を再装着してから、本体を密封します。
    This picture and several others that follow are not for the "LTE" model.
    Tim Osborn - 返信
    Some of the steps, including the comments, are replicated between guides.  Be aware! This can render them somewhat generic, and possibly non-optimal.  For instance, this step is replicated between at least the mini 2 LTE, mini 2 Wi-Fi, mini 3 LTE, & mini 3 Wi-Fi.
    ciradrak -
    Maybe that’s because this is for the WiFi model.
    mcr4u2 -
    Remember to remove the old black adhesive from the digitizer and iPad frame. Some can be pulled out and some needs a sharp blade to remove. This will give you room to apply your new adhesive strips when reassembling.
    Yousef Ghalib - 返信
  31. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 31、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 31、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 31、 3の画像 3
    • フロントカメラハウジングはフロントパネルに取り付けられている事があります。カメラを保護するため、ハウジングをはがしカメラに戻します。
    • カメラハウジングの片側を揺すり動かし接着をはがしフロントパネルから取り外します。
    • フロントカメラハウジングをリアケースの溝に戻します。
  32. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 32、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 32、 2の画像 2
    • LCDを固定している#00プラスネジを取り外します。
    • 3つの3.3 mmネジ
    • 1つの4.5 mmネジ
    • LCDのネジがテープで覆われている場合、ピンセットではがしてください。
    This is VERY IMPORTANT please be sure to put the screws EXACTLY how they were when you removed them otherwise your screen will not rotate when you put the new digitizer on. i closed my ipad thinking everything was ok but now the screen does not automatically rotate, but lucky i jailbroke my ipad first and have an activator gesture to rotate for me :-)
    Chris Grayden - 返信
    stripped the screws at the home button side of the ipad and the precision screw extractor set is too big to work. help?! paramedic064@gmail.com
    paramedic064 - 返信
    We have some great posts on Answers about getting stripped screws out, you can refer to What are your tips/tricks for removing or extracting stripped screws? for advice, or ask a new one and see if someone can come up with new ideas. We also have a stripped screw removal guide for you to check out. Good luck!
    Sam Goldheart -
    I found that Phillips #000 work better then the Phillips #00 for this entire product. I'll be recommending a change to the fix kit as well.
    William - 返信
    This is a tip:
    I have a terrible time cleaning the lcd because no matter how hard I try not to touch it, I always get smudges! So take my advice…remove the front film from the new digitizer and place it over the lcd. It is bigger so you can cut it down or just lift it to get to the screws. Now no fingerprints and also less chance for scratches. The front side is easy to clean once it’s installed so need to have that covered while working-the insides are what needs protecting.
    mamashannon4u - 返信
  33. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 33、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 33、 2の画像 2
    • LCDを完全に取り外さないでください。まだ接着剤で固定されており、ホームボタンの先端で、数本のケーブルによってiPadに接続されています。フロントカメラ側のみ持ち上げてください。
    • スパッジャーの平坦側をLCDとLCDシールドプレートの間に差し込み徐々に持ち上げます。
    • シールドプレートの下にスパッジャーが入らないようにご注意ください。LCDとシールドの間に差し込みます。
    • LCDをわずかに曲げてしまうだけで、永続的なダメージになります。そのため、持ち上げる際は特にご注意ください。
    • LCDにヒビが入ってしまう確率を低くするには、他の取り外し手順も可能です。
    • フロスや釣り用の糸などをディスプレイの下に通します。上部から始めて、作業のしやすい方向に動かします。
    • 薄くてフレキシブルなカードなどを使って、上部から接着剤を切開することもできます。
    Be very careful not to get the spudger under the shield plate, but between the LCD and the shield. Also, not that on the LTE models, the antennas are at this end and there is a bit of adhesive holding this end of the LCD down.
    Tim Osborn - 返信
    This bit of adhesive is located beneath the foam, and runs the entire length of the antennas. You must lift the foam and detach the tape before you're able to get the top to come out the chassis
    James - 返信
    This is not present in this tutorial and is very frustrating. I fix it must look into this
    James - 返信
    I have seen countless comments about the LCD breaking when trying to remove it from the LCD shield with adhesive. I have found a simple solution. Once the 4 screws have been removed take a piece of fishing line (longer than the iPad) and simply run it beneath the top of the LCD from one side to the other. Once it's in place, gently pull it down applying equal pressure from both sides. The fishing line will break the adhesive in the process, freeing the LCD. It has worked for me every time.
    bababooey - 返信
    Thanks for the fishing line suggestion. It certainly worked for me (used 6lb test line). With using the fishing line, one is a lot less likely to break the LCD compared to using a spudger.
    rgstout -
    awesome tip thanks
    Pa Du -
    The tutorial procedure should be edited once and for all to instruct to detach the adhesive strip from the top of the LCD prior to attempting to lift it. Failure to do so will invariably result in a broken LCD!!!
    The simplest way to do that is to first gently remove the foam strip running around the top of the LCD with a pair of tweezers. Only then will the shiny metallic adhesive tape be visible and accessible.
    lorenzocangiano - 返信
    I found that if you take two flat plastic spurgers and run one down each side together it works fairly well. Just take your time.
    Abbot - 返信
    The LCD is extremely fragile, DO NOT allow it to bend or you will break it. The adhesive near the speakers that connect to the LCD are a danger spot and if you pull wrong you could break the LCD. Be careful.
    Timothy McEvoy - 返信
    Yeah, I broke my LCD because the guide did not specify the glue on the top portion if you have an LTE model. I didn’t even try hard at all. I tried to lift it with the plastic spudger and saw that it did not move. Came to check the comments and when I looked back the top corner was already broken.
    Thanks iFixit! Awesome guide
    Jorge Tamez - 返信
    Another LCD broken victim. Getting it loose from the adhesive was easy. However, it would not fold over like a book. Something had it bound at the bottom. Heard the dreaded crack. First iFixit fail for me.
    Vince Kowaleski - 返信
  34. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 34、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 34、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 34、 3の画像 3
    • LCDは軽く接着剤で固定されており、シールドプレートからLCDを跳ね上げる前に剥がしてください。
    • スパッジャーをLCDとLCDシールドプレートの間に差し込みiPadの端から端までスライドさせます。
    Hi. I noticed that the tutorial is for an LTE iPad mini 2. However, these pictures do not show and LTE device. I'm having issues removing the LCD from the iPad due to the antenna. Any suggestions? (How to remove antenna?)
    Kevin Rodriguez - 返信
    This step needs extra detail on how the LCD adhesive should be loosened. I've now got stress marks on the LCD which show up when solid backgrounds are displayed on screen as the LCD flexed when trying to pry it out.
    Cool_Breeze - 返信
    bababooey - 返信
    thanks you very much!
    ind w -
    Great tip about the fishing wire because you will most certainly crack the LCD just yanking it out. Thank you and hit em with the hein
    Curtis Jordan Lenox - 返信
    Abbot - 返信
    Timothy McEvoy - 返信
    "mild adhesive" is really an understatement.
    The LCD is firmly attached to the metal plate below it.
    Especially if you try to repair an older ipad, the adhesive gets hard.
    Do not attempt to lift the LCD with spudgers in an attempt to get it out.
    You will break it.
    Use fishing line or some other strong wire to cut loose this adhesive.
    Even a strong sewing wire will do (it will take 5~6 wires because sharp edges of the housing will cut the wire easily).
    Sjaak Spoiler - 返信
  35. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 35、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 35、 2の画像 2
    • 2本の幅の広いテープがLCDとスピーカーを繋いでいます。
    • LCDを片手でつかみ、もう片方でiPadのリアボディーを押さえます。
    • iPadからLCDを完全に外そうとしないで下さい。
    • デジタイザーケーブルを引かないように注意しながら、テープをはがすためLCDをスピーカーから徐々に引きます。
    this was a pain to remove but the two pieces of tape should be separated using your spudger so that you can remove the lcd.
    Chris Grayden - 返信
    absolutely. lift the screen 45 degrees before pulling it too
    Billinski -
    The screen was a tight fit in the recess. Whilst maneouvering it out, it flexed a little. Once reassembled, there are now feint stress marks visible when the screen displays a uniform background. With photos it's not noticeable, but on solid backgrounds, it is very noticeable. :-(
    Be careful when pulling the LCD out. Any hints for pulling it out safely should be added to this step.
    Cool_Breeze - 返信
    This step is bad advise. Once you get the LCD unglued top and sides, drop those plastic tools behind it to keep it up and apply heat to the front bottom of the LCD where the tape is applied on either side, use your spudger to push the tape away before you attempt to pull or flip the LCD over. It is very easy to break if you don't get the tape loose enough, so do yourself a favor and free the LCD from the tape before you attempt to maneuver it.
    brentschwartz - 返信
    bababooey - 返信
    As others have said this step is rather problematic and following the tuturial instructions will most definitely lead to damaging the LCD. One problem is that the two adhesive tapes are not indicated in the photo: they are large and black and they are partly covered by long strips of thicker material that looks like padding. To remove them it helps to heat a little with the opener and then one can slowly peel them away by alternating the sharp and flat tips of the spudger.
    This must be the most difficult part. I took the advice of using fishing line and it worked a treat. However, due to lack of knowledge - I managed to slice straight through the LCD ribbons (all of them). I figure it was glue so kept going! Please take not that fishing line is only good for the sides, not the top where the LCD is attached! New LCD on order for round 2.
    Mike - 返信
    Well. I cracked the LCD during this process, so another $100. But, it’s the journey that counts, right? There is adhesive keeping the LCD attached to the aluminum shield. As I was prying the LCD up (I didn't know about the adhesive), I did hear feint cracking. Also it is too tight to try to flip the LCD over as shown. I did heat the bottom strips, but still tried to do it as shown, more cracking. It seems best to heat it and push the adhesive strips back and separate them prior to lifting. As well as the sides of the LCD for lifting!!
    William Dailey - 返信
    I separated the small tape in the middle (5mm), and the large upper tape (20mm), but left the lower tape at the connector in place. That way, the LCD was much easier to pull away gently and to tilt over.
    peterhebbinckuys - 返信
    I used a needle nosed tweezers to remove the tape on the bottom left and right. I then used the plastic spudger and went between the LCD and the metal piece. I gently went down the left side about half way and then the right and slowly and gently worked both sides until they separated.
    Abbot - 返信
    This step is unclear and should be revised, but Abbot’s comment has the right idea.  The tape holding the LCD in place should be highlighted in the image. This tape wraps around the lower edge of the panel and extends onto the front face, then a piece of cushion is attached on top.  Heat that tape to soften the adhesive then peal it up.  The connector for the LCD is on the back side of the panel in the lower right hand corner, it is not near the tape you are pealing away from the panel. Once the tape is separated very little force is required to shift the panel toward the top of the device as depicted. If you attempt to ‘pull the LCD away from the speakers’ with two hands as shown, it will almost certainly be broken.  Also, all the youtube explanations (at least the ones I could find) of how to remove the LCD make it look like you lift up on the top which would only cause the LCD to break.  So youtube failed this step as well.  It’s not easy, be careful.
    P.S. as these steps are replicated between more than one device –– I’m working on an iPad mini 3 LTE, the tape may be in different places on other devices?
    ciradrak -
    Timothy McEvoy - 返信
    The three tapes is best removed with tweezers! Then the LCD is easily flipped over. Extremely odd it’s not explained in this way.
    trnilsson - 返信
    It is MANDATORY to loosen the 3 tapes as well (step 36), don’t even try to lift it without loosening them first!!!! After you did it you can turn the screen without any resistance! Should be added in this guide!!!!
    Ishino Akatawa - 返信
    I just broke my LCD during this step (35). Frrt! I was pulling it back as instructed, and the LCD flexed in my hands. Need a better process.
    Sean Koch - 返信
    Like other commenters I found this step inadequately treated. The LCD didn't want to fold over like it ought to and It took me a while to decide how to proceed. I would suggest that one first identify the plastic hinge strips. Zoom in on the pics: there's a lot going on at that edge, it's all black, and you don't want to mess with any of the cable strips, etc. I used a hair dryer to loosen the hinges (I suspect one could heat up a small piece of metal bar and place it on the hinges to loosen) and gradually stretched it. I also think that using gloves instead of holding the LCD with bare fingers would help avoid smudging (I spent a bunch of time getting rid of finger marks.)
    cskilton - 返信
  36. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 36、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 36、 2の画像 2
    • LCDを完全に取り外さないでください。ホームボタン側でLCDはまだ数本のケーブルによってiPadに接続されています。フロントカメラ側のみ持ち上げてください。
    • iPadのLCDを本のページのようにめくり、カメラ付近を持ちあげリアケースのホームボタン側に裏返します。
    • LCDケーブルに注意しながら徐々にディスプレイを裏返してください。
    • ディスプレイケーブルにアクセスできるようにLCDを前面パネルガラスの上に置きます。
  37. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 37、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 37、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 37、 3の画像 3
    • ディスプレイを分離するためスパッジャーの先端をLCDと接着タブの間に差し込んでスライドさせます。
    • 2つの接着タブの間を軽く押します。付近のケーブルを損傷しないように注意してください。
    This was harder than it looks. The adhesive tape covers a lot of area and has stuck to it tiny wires that go to the speaker. I had to use the tweezers to very carefully separate the wire from the adhesive, and to then pull the adhesive off the circuit board area in one spot before it would finally come away.
    Ray Everett - 返信
    Be careful that it does not pull up all the foam strips, that was my issue.
    Shane - 返信
  38. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 38、 1の画像 1
    • 7つの1.8 mm #00プラスネジ をLCDシールドプレートから取り外します。
    My LCD shield plate had many more screws than this. You have to remove them all.
    David Rowthorn - 返信
    My plate had 8 on the upper line, 6 + 2 at bottom. 16 total.
    There are strong magnets on the sides and they keep catching the screws as you take them out. Tweezers are helpful to fish them.
    Gina Romo -
    At the assembly stage I found it is easier to use Philips PH000 screw driver bit than PH00. It helped me to get these minuscule screws in place, catch the head holes and drive them into their tight position. While using PH00 the driver would not catch the holes in their head and I was risking scratching the display since the screws refused to settle in the openings.
    mxmbulat - 返信
  39. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 39、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 39、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 39、 3の画像 3
    • スパッジャーの平坦側を使って、LCDシールドプレートをiPadから持ち上げます。
    • LCDシールドプレートを取り出します。
    You can also just slide it back to expose the cable bracket.
    Will - 返信
  40. iPad Mini 3 Wi-Fi フロントパネルの交換, 液晶ディスプレイ: 手順 40、 1の画像 1
    • ディスプレイケーブルブラケットから#00プラスネジを取り外します。
    • 2.8 mmネジ ×1
    • 1.4 mmネジ ×3
  41. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 41、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 41、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 41、 3の画像 3
    • iPadからディスプレイケーブルブラケットを取り外します。
  42. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 42、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 42、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 42、 3の画像 3
    • スパッジャーの先端を使用して、ロジックボード上のソケットからホームボタンのケーブルを持ち上げます。
    • ホームボタンのリボンケーブルを作業の邪魔にならない位置に折り曲げます。
    maybe disconnect the battery before touch the home button cable
    cli168 - 返信
    On a iPad mini 3 you MUST remove the home button cable connector, before you have access to the battery connector
    phigsmith - 返信
    The wider end allows better leverage and no slippage
    Billinski - 返信
  43. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 43、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 43、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 43、 3の画像 3
    • スパッジャーの先端を使用して、バッテリーコネクターをロジックボード上のソケットから静かに持ち上げてください。
    • バッテリコネクタだけを持ち上げ、ソケット自体を持ち上げないように注意してください。ロジックボードのソケットを持ち上げてしまうと、コネクタが完全に破損する可能性があります。
    Billinski - 返信
  44. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 44、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 44、 2の画像 2
    • スパッジャーの先端を使用して、LCDコネクターをロジックボード上のソケットから持ち上げて接続を外します。
    • コネクタの横にある大きなICを押え付けないでください。破損することがあります。図のようにコネクタの側面から丁寧に持ち上げてください。
    Billinski - 返信
  45. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 45、 1の画像 1
    • LCDを持ち上げて取り外します。
  46. iPad Mini 3 Wi-Fi フロントパネルの交換, フロントパネルアセンブリ: 手順 46、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換, フロントパネルアセンブリ: 手順 46、 2の画像 2
    • スパッジャーの先端を使用して、デジタイザケーブルコネクタをソケットからまっすぐ持ち上げます。
    Billinski - 返信
  47. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 47、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 47、 2の画像 2
    • デジタイザボードをリアケースから取り外します。 バッテリ側から、スパッジャーの平らな端をスライドさせて外して下さい。
  48. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 48、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 48、 2の画像 2
    • デジタイザーボードを持ち上げて、残っている接着剤を剥がします。
    It’s quite stiff, the board is secured by adhesive, so don’t worry about using gentle force.
    Continue to pry off the flexicables, also secured with adhesive.
    Billinski - 返信
  49. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 49、 1の画像 1
    • フロントパネルアセンブリを持ち上げて取り外します。
  50. iPad Mini 3 Wi-Fi フロントパネルの交換, ホームボタンアセンブリ: 手順 50、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換, ホームボタンアセンブリ: 手順 50、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換, ホームボタンアセンブリ: 手順 50、 3の画像 3
    • 開口ピックを使用して、ホームボタンリボンケーブルをデジタイザケーブルに固定している接着剤を剥がします。
  51. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 51、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 51、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 51、 3の画像 3
    • ホームボタンリボンケーブルとデジタイザの間に開口ピックを挿入します。
    • フロントパネルに沿って、ホームボタンの方向にピックをスライドさせます。続けて、フロントパネルからホームボタンのリボンケーブルを外します。
  52. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 52、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 52、 2の画像 2
    • ホームボタンコントロールハードウェアをフロントパネルの背面から持ち上げます。
  53. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 53、 2の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 53、 2の画像 2
    • ケーブルとデジタイザの間に開口ピックを挿入して、ホームボタンリボンケーブルを固定しているテープの最後の部分をはがします。
    • ケーブルの下にあるピックを、フロントパネルから完全に離れるまで引っぱり粘着シールを剥がし切ります
    • ホームボタンを、この時点では外さないでください。まだ強く粘着されているブラケットとガスケットによって固定されています。
  54. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 54、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 54、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 54、 3の画像 3
    • プラスチック製の開口用ツールを使って、ホームボタンブラケットをデジタイザの背面から持ち上げてください。
    • ホームボタンのブラケットを取り外します。
    • ホームボタンブラケットを元に戻すときは、十分な接着力を確保するために接着剤または強力な両面テープを使用してください。
  55. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 55、 3の画像 1 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 55、 3の画像 2 iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 55、 3の画像 3
    • iOpenerを準備し、デジタイザの下端に置いて、ホームボタンのガスケットを保持している接着剤を緩めます。
    • 接着剤が柔らかくなるまで約2分間待ってから次の作業に進みます。
    • デジタイザーパネルを裏返して、ホームボタンを前面パネルのスロットから静かに押し上げます。
    • ガスケットゆっくりと丁寧に押して、ガラスから外します。強く押しすぎるとガスケットが裂けてしまいます。
  56. iPad Mini 3 Wi-Fi フロントパネルの交換: 手順 56、 1の画像 1
    • ホームボタンアセンブリを取り外します。
    When replacing the fingerprint/home button:
    1. place the home button in the new front panel, slip it under the plastic insulation at the “top” of the button
    2. heat the iOpener gel pack, lay it gel side up on your workspace, place the bottom (home button) end of the front panel FACE DOWN on top of the iOpener, let it heat the adhesive on the home for 2minutes
    3. Use the “pencil” spudger tool to gently seat the home button from the backside of the new front panel - you’ll see a uniform “recess” to the outer ring when it’s seated properly
    phigsmith - 返信
  57. iPad Mini 3 Wi-Fi フロントパネルの交換, フロントパネル: 手順 57、 1の画像 1
    • フロントパネルのみが残ります。
終わりに
デバイスを再構成するには、以下の手順を逆の順序で実行してください。
103 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
Zumeさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,744 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,810のガイドは作成済み
18 件のコメント
Why do you skip the part about moving the old home button to the new digitizer?
aturnaround - 返信
Kind of an important step. Is it easy?
Eric Thomas -
Agreed. Regluing the home button to the new digitizer is tedious.
Tristan Punter -
I'm pretty sure the digitizer and the LCD are glued together with OCA on the 3rd generation iPad mini... separating/replacing them requires the equipment that is used for iPhones. You can't use LOCA glue in place of OCA because apple didn't think it was a good idea to seal the backlight to the LCD. The iPad mini and the iPad air 2nd Gen are repaired the same way, which is different than the previous versions of ipads. Please correct me if I'm wrong
Vinny Buffone - 返信
You are incorrect. They are indeed separate.
Tristan Punter -
You're talking about the iPad mini 4
Mattis -
As a tech with 5 years experience, I can tell you that if you are not familiar with fixing apple products don't try to do an ipad mini just to save some money. IMO the mini is the most difficult to work on due to its compact assembly. A "first-timer" would be lucky to get the LCD out without damaging it. If you do decide to do this on your own MAKE SURE you have the proper tools and dont use metal tools when unhooking the digitizer and lcd cables. Thanks for yet another great walk through ifixit!
domlombardodesign - 返信
With heavily cracked screen the job of removing the pieces is almost impossible.
anthony - 返信
In reference to a shattered screen, it is possible to fix it just takes a lot of time. I used tape to keep most of it together. Instead of the suction pull thingie I used the opening tool to gently pry the larger pieces up or at least push them in a bit to slip the opening pick in. You then fold over the screen thats taped together and begin picking the shards out of the glue around the rim. If the glue is cooled it is actually easier to pull it up with the shards attached.
Derek Nobriga - 返信
I also wanted to add that showing the steps of re-assembly would be very helpful for this guide. There are enough subtle differences to make that valuable. One thing that would be helpful is showing how to have the individual bits stick back down. Also a simple but easily missed part is that the replacement screen actually has a thin plastic film covering the glue. If you neglect to remove that film sticking the new screen down would appear to not work well.
Derek Nobriga - 返信
The Home button destroyed my effort :(. The instruction to put it back is required.
hassan alzahrani - 返信
It could be a different iteration, but the iPad mini 3 (model A1600) that I just worked on had a slightly different front facing camera housing (step 30). There also need to be clearer warnings - I destroyed the home button cable despite following all the instructions & reading+planning ahead.
In step 50, it does not mention that the cable actually has 2 sublayers; and "Sliding the pick along the front panel, towards the home button" actually tore the 2 sublayers into half, exposing some copper pins & shearing the cable in the process. I'm not sure how this wasn't picked up earlier.
Also, the instructions in part 34-35 are very poor - a note is provided regarding "Two wide strips of tape connect the LCD to the speakers". For someone disassembling this device for the first time, it would be greatly helpful to indicate What exactly, and where these strips are so that we can watch out for these. Current images are not helpful.
tcsedmund - 返信
Do I need to have a home button gasket to do this repair? I can't believe that it was not included with the full kit with tools to replace the front panel if it is needed. Is there anything else I need or need to know before I proceed?
BTW, shouldn't the first step be to power down the ipad? That seems to be missing here...
Joseph Albert Hindman - 返信
After doing this repair, the iPad mini 3 would not rotate the display when turned. After many many hours of searching for a fix and none of the solutions working I put it aside to come back to it fresh another time. I had forgotten it for several months, when I pulled it back out the other day. And because I’m the type of person who hates when I know something isn’t right after a repair, it was time to figure it out. Now, after going through two digitizer panels and a home button from iFixit, all of which they were happy help me try to solve the issue, I decided to just find a panel with the home button already attached thinking there must be something not right with the reattached home button from before. After the easiest reassembly of the 3-4 times I had it apart it was back to working perfectly. Of course Touch ID won’t work due to the home button not being the original. But that was something I knew wouldn’t be the same, so in my mind, I’m satisfied. Now the iPad mini 3 functions at 99%.
Patrick Gorman - 返信
What is the best way to adhere the home button to the new assembly? Even with my best adhesive I find it’s either spongy or ends up falling in from someone pushing it harder than needed.
Christopher Vandagriff Jr - 返信
I think I have previously made this comment with an earlier generation iPad mini Repair Guide I think once again the 2 magnets have not been mentioned
John Smith - 返信
An explanation for how to apply the adhesive strips would have been helpful.
Troy Shafer - 返信
Sam,
thanks a lot fot this great how_to - I have successfully repaired a broken front panel on an A1599 with the Fix-Kit (SKU: EU277001-12).
The only thing I noticed was as per step 55 after removing the home button - that also that ring probably needs to be removed and re-used as it was not existing on the new front panel (at least the one I bought here!) - with that it fits perfectly.
And maybe a general comment/critics/recommendation - I do not like in some cases at the end of those great instructions just saying:
Because sometimes a few hints and tips how to re-glue parts or what are best practices to clean up and prepare parts before reassembling would be really great! That would certainly ensure not to screw it up or break any parts AND prevent buying spare parts twice!
thanks,
tba
Taskin Bayram - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 38
過去 30 日: 170
今までの合計 101,327
