はじめに
2020年も終わりに近づいてきました。Appleは今年最後に、iPad Proによく似た新iPad Airの贈り物を届けてくれました。この内側は?このビデオ分解で、一緒に新Airを点検しましょう。
最新の分解情報をお探しですか?TwitterやTwitter 日本語版もしくはFacebookをフォローしてください。 ニュースレター を購読いただくと、受信箱に直接お届けします。(英語配信)
必要な工具と部品
ビデオインストラクション
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
10 件のコメント
Will there be a full teardown for this device?
CChin - 返信
Hi Chunglin! This is the only teardown iFixit will create for this particular iPad. We’ll also post repair guides at some point, as always.
Jeff Suovanen -
well teardowns are not wat they have been before ifixit is become to lazy to write full teardowns like they used to do before.
Peter Ben Jumanne - 返信
Hi,
The Itouch Id sleep/wae button of my Ipad Air 4 has been damaged, I notice that there is a small crack and it “heats up” when the Ipad is on.
At the moment I am unable to find the Itouch ID button. Does anyone know where I can buy it?
Thank you
Cheers
Alberto MARUGAN - 返信
Well.. Note that there have been NO repairs available for Touch ID since iPhone 5s, because the sensor and the processor matched one-to-one. I’m not a professional so I don’t exactly know this thing for Air 4, but I’m sure that you can’t replace Touch ID by yourself. I recommend that you go to the Genius Bar.
Sizun Cho -
Can we get a top-down pic of the internals to use as a wallpaper?
ChunkyFox - 返信
Anyone know which specific magnets are the Hall Effect Sensors? Thanks!
Mari Mardre - 返信
Hi, my ipad air 2020 display LCD panel is broken because of pressure, I want to get it repaired (replaced with new display) how much it will cost approax. ???
Vinay Kumar - 返信
Hi only Ali express you can get the iPad Air screen pretty cheap
if you don’t feel comfortable repairing it yourself take it to a repair shop
nicholaswiding -
Привет всем, мы команда FixYourTech из России. К нам поступил такой же аппарат и с такой же проблемой. Решили просто. Отсекли сканер скальпелем и собрали в обратном порядке. Всё работает кроме Touch-ID. Ждём дальнейших решений вопроса. А пока техника должна работать. И кстати это совершенно бесплатно, разобрал, отрезал, собрал. Круто. Apple расстроили с качеством кнопки...
Кассир ПСТ - 返信
