Cracked near home button its important to not break home button flex cable
Apply heat to the screen! Do NOT SKIP THIS STEP
Make sure to turn it off if you can to prevent breaking the backlight filter
Set screen up a little bit to get to power connection
Power connection has PH000 screw holding it together
Slide a card under connection
Its very important to disconnect battery try turning it on make sure it is off to avoid further damage to ipad
Lift display back up to get to the display cables
Unscrew 2 PH000 Screws from display cable bracket
Use the flat end of plastic spudger to lift off connections
There is 4 flex cables that need disconnecting
Whoohoo we got it off now clean the edges for any broken glass
Keep track of rubbers covering proximity light sensor on the top
Light covers place on top of proxmity sensors
APPLY HEAT TO HOME BUTTON 15-20 Seconds should do the trick
If heat is not applied you might break the home button along with the touch ID. If you replace the home button touch ID will not work anymore
Take of home button flex cover
Use flat end of spudger to pry up home button flex connector
Reapply heat if you spent to much time getting flex unhooked
Pry with splicer under the home button bracket car
Clean glass around gasket
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
