メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
  1. It is iPad7th generation A2197 It is 10.2 inches. Mostly screen replacement procedure as same as earlier generations iPad 1,2,3,4, Air etc.
    • It is iPad7th generation A2197
    • It is 10.2 inches.
    • Mostly screen replacement procedure as same as earlier generations iPad 1,2,3,4, Air etc.
    • Its digitiser and LCD both are separate so it is cost effective for customers.
  2. Apply tape to the screen to help avoid any smaller pieces of glass from separating from digitizer during removal. Apply tape to the screen to help avoid any smaller pieces of glass from separating from digitizer during removal.
    • Apply tape to the screen to help avoid any smaller pieces of glass from separating from digitizer during removal.
  3. Different expert use different methods to remove glass. Here, I prefer to LCD temperature controller device Heat the iPad unto 75 degree till 2 minutes for 2-3 times. Do not heat too much as it can damage iPad internally.
    • Different expert use different methods to remove glass. Here, I prefer to LCD temperature controller device
    • Heat the iPad unto 75 degree till 2 minutes for 2-3 times.
    • Do not heat too much as it can damage iPad internally.
  4. Use Prying tools such as sharp blade to separate glass from the frame with other plastic supporting parts. Use heat gun wherever necessary to heat the part to separate. Since, it is big iPad compatibly , therefore it takes time
    • Use Prying tools such as sharp blade to separate glass from the frame with other plastic supporting parts.
    • Use heat gun wherever necessary to heat the part to separate.
    • Since, it is big iPad compatibly , therefore it takes time
    • Exercise high degree of patience to pry
    • Extremely careful for bottom part as it has digital home button cable that can cut easily if you are in hurry and home button will never work.
  5. Remove four Cornor screws from the LCD careful to remove as it might crack LCD easily as it can little stick with frame to lift Use Philip screw driver to remove screws
    • Remove four Cornor screws from the LCD
    • careful to remove as it might crack LCD easily as it can little stick with frame to lift
    • Use Philip screw driver to remove screws
  6. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  7. Use Philip screw driver to remove screws on the metal shield that has under digitiser cables and home button cable and also LCD cables. Be very careful to removing home button cable
    • Use Philip screw driver to remove screws on the metal shield that has under digitiser cables and home button cable and also LCD cables.
    • Be very careful to removing home button cable
  8. detach ditisier both connectors from the logic board. detach ditisier both connectors from the logic board.
    • detach ditisier both connectors from the logic board.
  9. Remove the original digital home button from broken screen. Use high class of skill to remove it as it has very strong adhesive all the way Use IPA alcohol to peel off and remove adhesive to detach the home button
    • Remove the original digital home button from broken screen.
    • Use high class of skill to remove it as it has very strong adhesive all the way
    • Use IPA alcohol to peel off and remove adhesive to detach the home button
    • one it broken mistakenly , never come again.
  10. Now remove broken screen from the Frame remove all broken glasses and debris use alcoholic material as much to remove old adhesive
    • Now remove broken screen from the Frame
    • remove all broken glasses and debris
    • use alcoholic material as much to remove old adhesive
    • use share flat blade to remove adhesive
  11. Connect LCD back, metal shield back and also home button. Connect LCD back, metal shield back and also home button. Connect LCD back, metal shield back and also home button.
    • Connect LCD back, metal shield back and also home button.
  12. Put the screw of the battery back put all big screws into LCD back put all big screws into LCD back
    • Put the screw of the battery back
    • put all big screws into LCD back
  13. Transfer the home button to new digitiser is a great skill use test tape to attach home button brackets.
    • Transfer the home button to new digitiser is a great skill
    • use test tape to attach home button brackets.
  14. wow new iPad screen is ready
    • wow new iPad screen is ready
    • In this picture, white digitiser is replaced instead of black so black home button is visible in the image.
終わりに
2 の人々がこのガイドを完成させました。
iRepairMan
メンバー登録日: 2017年04月29日
105 ポイント
3のガイドは作成済み
チーム
iRepairMan Limited (UK) iRepairMan Limited (UK)人のメンバー
Business
1 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 19
過去 30 日: 105
今までの合計 339
