はじめに
Use this guide to replace the front glass and digitizer assembly on an iPad 5 LTE.
Note that since the Touch ID sensor in the home button is paired to the logic board, this guide includes instructions for removing the home button. In order to retain Touch ID functionality, you need to transfer the original home button to the new front panel assembly.
Parts of this guide were shot with a Wi-Fi model and as such the internals may look slightly different from the LTE model. The procedure is the same for both models except where noted.
必要な工具と部品
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
この手順で使用する道具:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out just a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
この手順で使用する道具:Polyimide Tape$9.99
Remove the front panel assembly.
If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
Gently begin peeling the home button cable off the back of the front panel.
Continue peeling until you reach the metal shield on the cable.
35 の人々がこのガイドを完成させました。
6 件のコメント
I was able to complete this repair although the screen on the iPad that I was trying to repair was completely shattered and I ended up having to just take it out in chunks. A little more detail about best practices in that situation would be good. I also am having some issues with the home button not being quiet right after the repair and now that I am seeing that I would have purchased a replacement for the adhesive holder piece when I got the screen. It is working fine for now and I plan to just be careful with it so I don’t have to pull the display again and risk messing up the screen adhesive and having to order another set of that again too.
It didn´t work for me. I did this repair 2 times.
At the first try, the front glass was not totaly fixed, so I I used 10 strong clamps to get a better connection, but the glass was not really fixed and broke again with a new one.
So I tried twice. I cleaned everything very well, waited half an hour before I put the glass on the ipad. I put it on a flat surface on top with some haevy gear for 24 hours. After only some days the glass lost connection at the right down side where the cables are. So the display got a crack again.
I asked ifixit to fix this.
They told me: This is my fault.
Most likely you did not route the display cables down into between the housing and the lcd this is tricky if done right and the chassie is not bent and no debre is left the screen should adhear no problem. I have done many of these with no issues.
I like the instructions for how to get the new panel on "do this all in reverse, completely useless. I want to know how to glue the home button back onto the new panel, where to run each wire now that the tape is all removed, how to get the new screen on, seems half done. Can we just update it to have reassembly instructions. also the kit no longer comes with that tool and it says "skip ahead to alternative" and there is none, and the suction cup is 100% useless, it does not suck at all, no matter how perfect the glass is under it or how hard you press it on, you can just blow on it and it will move, no force at all required and it immediately comes off. Just forget the toolkit, but the screen and watch some youtube videos, this guide and toolkit are useless.
