メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Use this guide to replace the battery.
  1. We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
    • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
    • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
  5. There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness. Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack. It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
    • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
    • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
    • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
  6. Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
    • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
  7. Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool. Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
    • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
  8. Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches. Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
    • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
  9. While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
    • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
  10. While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad. Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go. The adhesive is very strong, and some serious force may be required. Work carefully.
    • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
    • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
    • The adhesive is very strong, and some serious force may be required. Work carefully.
    • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
  11. It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it. If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive. If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  12. Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering. Re-heat the iOpener, and move it to the top  edge of the iPad.
    • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
    • Re-heat the iOpener, and move it to the top edge of the iPad.
  13. The next few steps require extreme caution.
    • The next few steps require extreme caution.
    • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
    • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
  14. Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there. Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
    • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
    • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
  15. This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly. Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
    • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
  16. Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth. Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
    • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
  17. Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button. If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working. Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
    • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
    • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
    • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
  18. Continue releasing the adhesive all the way along the bottom edge of the iPad. On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Leave the opening pick wedged underneath the front glass near the home button.
  19. Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
    • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
  20. Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket. The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad. If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled  too much, reheat it.
    • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
    • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
    • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
    • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
  21. Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner. If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
    • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
    • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
  22. Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer. The digitizer cable is located approximately  2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad. The digitizer cable is located approximately  2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
    • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
    • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
  23. Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner. The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
    • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
    • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
  24. Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers. Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
    • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
    • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
  25. Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad. Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
    • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
  26. Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame. The bottom left screw is obscured by the home button ribbon cable connector. Carefully move the home button ribbon cable aside to remove the bottom left screw.
    • Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
    • The bottom left screw is obscured by the home button ribbon cable connector. Carefully move the home button ribbon cable aside to remove the bottom left screw.
  27. Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad. Rotate the LCD along its left edge and lay it down on top of the front glass panel. Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
    • Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad.
    • Rotate the LCD along its left edge and lay it down on top of the front glass panel.
    • Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
  28. Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
    • Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
  29. Flip up the retaining flap on the LCD ribbon cable ZIF connector. Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board. Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board.
    • Flip up the retaining flap on the LCD ribbon cable ZIF connector.
    • Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board.
  30. Without touching the front of the LCD, lift the LCD off the front panel.
    • Without touching the front of the LCD, lift the LCD off the front panel.
  31. If present, remove the piece of electrical tape covering the Wi-Fi antenna, speaker cable, and home button ribbon cable. If present, remove the piece of electrical tape covering the Wi-Fi antenna, speaker cable, and home button ribbon cable.
    • If present, remove the piece of electrical tape covering the Wi-Fi antenna, speaker cable, and home button ribbon cable.
  32. Flip up the retaining flap on the home button ribbon cable ZIF connector. Flip up the retaining flap on the home button ribbon cable ZIF connector.
    • Flip up the retaining flap on the home button ribbon cable ZIF connector.
  33. Use a pair of tweezers to pull the home button ribbon cable straight out of its socket on the logic board. Use a pair of tweezers to pull the home button ribbon cable straight out of its socket on the logic board.
    • Use a pair of tweezers to pull the home button ribbon cable straight out of its socket on the logic board.
  34. De-route the home button ribbon cable from its recess in the rear case.
    • De-route the home button ribbon cable from its recess in the rear case.
  35. Use a pair of tweezers to peel back the piece of tape that secures the digitizer ribbon cable to the logic board.
    • Use a pair of tweezers to peel back the piece of tape that secures the digitizer ribbon cable to the logic board.
  36. Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors. Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors. Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors.
    • Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors.
  37. Use the flat end of a spudger to loosen the adhesive underneath the digitizer ribbon cable. Pull the digitizer ribbon cable straight out of its sockets on the logic board.
    • Use the flat end of a spudger to loosen the adhesive underneath the digitizer ribbon cable.
    • Pull the digitizer ribbon cable straight out of its sockets on the logic board.
  38. Peel back the digitizer ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case. Peel back the digitizer ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case.
    • Peel back the digitizer ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case.
  39. Using your fingers, pull the digitizer ribbon cable out of its recess in the aluminum frame.
    • Using your fingers, pull the digitizer ribbon cable out of its recess in the aluminum frame.
    • Remove the front panel from the iPad.
  40. Use tweezers to peel back and remove the piece of electrical tape covering the headphone jack assembly cable connector. Using the tip of a spudger, flip up the retaining flap on both of the ZIF connectors securing the headphone jack cable to the logic board. Using the tip of a spudger, flip up the retaining flap on both of the ZIF connectors securing the headphone jack cable to the logic board.
    • Use tweezers to peel back and remove the piece of electrical tape covering the headphone jack assembly cable connector.
    • Using the tip of a spudger, flip up the retaining flap on both of the ZIF connectors securing the headphone jack cable to the logic board.
  41. Slide the flat end of a spudger underneath the headphone jack assembly cable, releasing the adhesive securing it to the rear aluminum frame. Pull the headphone jack assembly cable straight out of its socket on the logic board.
    • Slide the flat end of a spudger underneath the headphone jack assembly cable, releasing the adhesive securing it to the rear aluminum frame.
    • Pull the headphone jack assembly cable straight out of its socket on the logic board.
  42. Disconnect the following connectors from their respective sockets on the logic board:
    • Disconnect the following connectors from their respective sockets on the logic board:
    • Wi-Fi antenna cable
    • Speaker connector cable.
    • Dock/Lightning connector cable.
    • There may be a piece of black tape covering this connector. Remove it with tweezers.
    • Make sure to pry underneath the connector and not the socket itself. Prying on the socket itself may cause severe damage.
  43. Remove the following four screws securing the logic board to the rear aluminum panel.
    • Remove the following four screws securing the logic board to the rear aluminum panel.
    • Three 2.1mm Phillips #00
    • One 2.5mm Phillips #00
  44. Holding the logic board by the side opposite the Lightning connector, carefully pull the logic board away from the iPad. Holding the logic board by the side opposite the Lightning connector, carefully pull the logic board away from the iPad.
    • Holding the logic board by the side opposite the Lightning connector, carefully pull the logic board away from the iPad.
  45. The battery is very firmly glued to the aluminum frame using copious amounts of strong adhesive.
    • The battery is very firmly glued to the aluminum frame using copious amounts of strong adhesive.
    • In the following steps, you will be removing the adhesive from underneath the battery 2 inches at a time. This will prevent too much stress being put on the battery.
    • Be very careful to not puncture or damage the battery as you remove it from the iPad. Batteries contain toxic chemicals that can be harmful if ingested or inhaled.
  46. Insert the flat end of a metal spudger underneath the battery near the bottom of the iPad. Slide the metal spudger approximately 1.5" underneath the battery, releasing the adhesive.
    • Insert the flat end of a metal spudger underneath the battery near the bottom of the iPad.
    • Slide the metal spudger approximately 1.5" underneath the battery, releasing the adhesive.
    • The adhesive is very strong. Loosening the adhesive requires considerable force. Work slowly and carefully, making sure that the metal spudger does not slip.
  47. In the same manner as described above, slide the spudger ~2" underneath the other adhesive strips. In the same manner as described above, slide the spudger ~2" underneath the other adhesive strips.
    • In the same manner as described above, slide the spudger ~2" underneath the other adhesive strips.
  48. Carefully slide the metal spudger underneath the battery connector, releasing the adhesive securing it in place. Carefully slide the metal spudger underneath the battery connector, releasing the adhesive securing it in place. Carefully slide the metal spudger underneath the battery connector, releasing the adhesive securing it in place.
    • Carefully slide the metal spudger underneath the battery connector, releasing the adhesive securing it in place.
  49. Continue releasing the adhesive near the top of the battery. Continue releasing the adhesive near the top of the battery.
    • Continue releasing the adhesive near the top of the battery.
  50. Starting where the last pass left off, insert the metal spudger another two inches underneath the battery. As you push the spudger further underneath the battery, keep it as flat against the rear case as possible to avoid bending the battery. Repeat this process for the remaining adhesive strips.
    • Starting where the last pass left off, insert the metal spudger another two inches underneath the battery.
    • As you push the spudger further underneath the battery, keep it as flat against the rear case as possible to avoid bending the battery.
    • Repeat this process for the remaining adhesive strips.
  51. In the same manner as previously described, continue loosening the adhesive on all the strips to a depth of ~4". In the same manner as previously described, continue loosening the adhesive on all the strips to a depth of ~4". In the same manner as previously described, continue loosening the adhesive on all the strips to a depth of ~4".
    • In the same manner as previously described, continue loosening the adhesive on all the strips to a depth of ~4".
  52. For the last pass, push the metal spudger all the way to the right edge of the iPad. Continue to do this for all of the adhesive strips. Continue to do this for all of the adhesive strips.
    • For the last pass, push the metal spudger all the way to the right edge of the iPad.
    • Continue to do this for all of the adhesive strips.
  53. Make sure that all the adhesive glue has been loosed from the battery. Gently lift the left side of the battery up, rotating it toward the right side of the iPad.
    • Make sure that all the adhesive glue has been loosed from the battery.
    • Gently lift the left side of the battery up, rotating it toward the right side of the iPad.
    • Use the metal spudger to loosen any adhesive that may still be holding the battery in place
    • Remove the battery from the iPad.
終わりに
To reassemble your device, follow these directions in reverse and use our iPad 4 Wi-Fi Front Panel Adhesive strips guide to reattach the front panel.
43 の人々がこのガイドを完成させました。
Walter Galan
615,833 ポイント
1,203のガイドは作成済み
6 件のコメント
I have just done this replacement, but have some problems now with the charging.
The iPad indicates charging (lightning symbol next to battery icon), but the charge does not "fill up", instead it resides at 0 percent.
When i disconnect the charger after a few hours, it shows 100%, but only lasts a short time before it plummets to 0% again.
Is there something that needs to be done in the settings etc after replacing the battery? Do i need to reset the iPad, or "tell it" that it has a new battery..?
oyvindrosmer - 返信
Could Be a Charging IC Usually the second culprit of a dying battery.
stephenthormodson -
Thanks for a very precise tutorial! Just completed it and all seems perfect.
Lara Snuffer - 返信
I experienced major confusion during reassembly when attempting to insert the ribbon cable into the ZIF connector slot. An illustration of this would have saved some heart-ache. Otherwise an excellent guide!
Stephen Svoboda - 返信
What adhesive is best to attach the new battery?
Tina Ward - 返信
コメントを追加
統計データを表示:
過去 24時間: 29
過去 7 日: 146
過去 30 日: 668
今までの合計 43,996
