メインコンテンツにスキップ
iPad 2 CDMA Front Panel Adhesive Strips Replacement
必要な工具と部品
  1. iPad 2 CDMA Front Panel Adhesive Strips Replacement, Home Button: 手順 1、 3の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement, Home Button: 手順 1、 3の画像 2 iPad 2 CDMA Front Panel Adhesive Strips Replacement, Home Button: 手順 1、 3の画像 3
    この手順で使用する道具:
    • Carefully grasp the home button with a pair of tweezers.
    • Gently lower and place the home button into the round opening located at the bottom of the front panel.
    • The correct orientation of the home button is shown in the third picture. Make sure the back of the home button is face up and the flat portion of the inner home button circle is oriented to the top of the iPad.
  2. iPad 2 CDMA Front Panel Adhesive Strips Replacement, Front Panel Adhesive Strips: 手順 2、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement, Front Panel Adhesive Strips: 手順 2、 2の画像 2
    • The two small notched trapezoidal strips will be used to attach the home button bracket to the front panel.
    • Carefully peel off the first trapezoidal adhesive strip.
  3. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 3、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
    • Make sure to line up the profile of the strip with the edge of the mounting bracket.
    • Repeat the procedure for the second trapezoidal adhesive strip.
  4. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 4、 1の画像 1
    • Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
    • Lift and peel the brown backing up off the adhesive strip, revealing the clear adhesive strip.
    • Repeat the procedure for the secondary adhesive strip.
  5. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 5、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 5、 2の画像 2
    • Gently place the home button mounting bracket on top of the home button.
    • Make sure the home button mounting bracket is lined up with the bottom of the digitizer.
  6. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 6、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 6、 2の画像 2
    • In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
    • Do not peel the brown backing off the strips just yet.
    • Place the largest L-shaped adhesive strip on the top left corner of the front panel.
    • Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
  7. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 7、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 7、 2の画像 2
    • Place the thinnest L-shaped adhesive strip on the bottom left corner of the front panel.
  8. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 8、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 8、 2の画像 2
    • Place the remaining thin L-shaped adhesive strip on the top right corner of the front panel, near the camera mounting bracket.
  9. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 9、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 9、 2の画像 2
    • Place the straight adhesive strip on the right side of the front panel.
    • If you've already attached the digitizer cable, you'll have to work around/under it to attach this strip.
  10. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 10、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 10、 2の画像 2
    • Place the last L-shaped adhesive strip on the bottom right corner of the front panel.
  11. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 11、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 11、 2の画像 2
    • Lay the thin T-shaped adhesive strip between the bottom edge of the inner frame of the front panel and the camera mounting bracket. The longest edge should be flush with the inner frame.
  12. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 12、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 12、 2の画像 2
    • Place the small hook-shaped adhesive strip below the left side of the home button mounting bracket.
  13. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 13、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 13、 2の画像 2
    • Lay the final small rectangular adhesive strip to the left of the hook-shaped adhesive strip, immediately to the right of the thin L-shaped strip, and flush with the bottom of the front panel.
  14. iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 14、 2の画像 1 iPad 2 CDMA Front Panel Adhesive Strips Replacement: 手順 14、 2の画像 2
    • Make sure that each adhesive strip is placed in the correct location and orientation before peeling the backing.
    • Peel the brown backing up off each adhesive strip.
    • Some of the adhesive strips are quite small and may require some patience to peel the backing.
終わりに
25 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
509,888 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
119 メンバー
21,025のガイドは作成済み
1件のガイドコメント
grazie senza di voi non avrei saputo neanche da dove iniziare invece con voi o cambiato il pannello frontale crepato del ipad 2 model 1395 ancora grazie le vostre guide sono perfette
severino1963 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 7,271
