メインコンテンツにスキップ
iON SnapCam 1046 Lite Capture Button Replacement
必要な工具と部品
  1. iON SnapCam 1046 Lite Capture Button Replacement, Camera Lens and Cover: 手順 1、 2の画像 1 iON SnapCam 1046 Lite Capture Button Replacement, Camera Lens and Cover: 手順 1、 2の画像 2
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. iON SnapCam 1046 Lite Capture Button Replacement: 手順 2、 1の画像 1
    • Firmly pull on the back clip in order to remove.
  3. iON SnapCam 1046 Lite Capture Button Replacement: 手順 3、 1の画像 1
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  4. iON SnapCam 1046 Lite Capture Button Replacement: 手順 4、 3の画像 1 iON SnapCam 1046 Lite Capture Button Replacement: 手順 4、 3の画像 2 iON SnapCam 1046 Lite Capture Button Replacement: 手順 4、 3の画像 3
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
  5. iON SnapCam 1046 Lite Capture Button Replacement, Capture Button: 手順 5、 2の画像 1 iON SnapCam 1046 Lite Capture Button Replacement, Capture Button: 手順 5、 2の画像 2
    • Remove the motherboard by pulling it from the edges as circled.
  6. iON SnapCam 1046 Lite Capture Button Replacement: 手順 6、 1の画像 1
    • Replace capture button with advanced soldering and circuitry (circled in red).
終わりに
Once the capture button has been replaced, reassemble the iON SnapCam Lite by following these steps in reverse order.
作成者
5人の作成者と共同で作成されました。
Ahmad Syamil Ali
メンバー登録日: 11/20/17
101 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S22-G4, Bayer Fall 2017 IUPUI, Team S22-G4, Bayer Fall 2017人のメンバー
IUPUI-BAYER-F17S22G4
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 160
