メインコンテンツにスキップ
iMac Whiteboard
必要な工具と部品
  1. iMac Whiteboard, iMac Whiteboard: 手順 1、 1の画像 1
    • We start up with an empty case of an iMac.
    • For directions on removing all of the interior components from your iMac, check out the 24" iMac EMC 2111 device page.
    • This procedure should also work on an iMac G5 or early Intel iMac.
  2. iMac Whiteboard: 手順 2、 1の画像 1
    • Unscrew the case and take the 56x35 whiteboard, check that it fits nicely.
  3. iMac Whiteboard: 手順 3、 1の画像 1
    • Apply contact cement to the inside borders of the front case. Leave to dry for about 5 minutes.
  4. iMac Whiteboard: 手順 4、 1の画像 1
    • Place the whiteboard onto the front case and put weight on it.
    • Make sure that the whiteboard touches the lower side of the metal panel.
    • Leave to dry out for a day.
  5. iMac Whiteboard: 手順 5、 2の画像 1 iMac Whiteboard: 手順 5、 2の画像 2
    • Mark up 4 lines of 4cm each on the cardboard.
    • Cut up a rectangle and fold to make up a cylinder. Use scotch tape to hold them together.
    • Repeat to get 2 more cylinders.
  6. iMac Whiteboard: 手順 6、 1の画像 1
    • Glue the cylinders to the back case of the iMac.
    • This is to have some pressure against the whiteboard.
  7. iMac Whiteboard: 手順 7、 1の画像 1
    • After the contact cement has dried, take out the small contact cement remnants from the board with a box cutter and a plastic tool (as to not damage the whiteboard)
  8. iMac Whiteboard: 手順 8、 1の画像 1
    • Reassemble your iMac and write something on it.
終わりに
Very useful mobile whiteboard!
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Angela Penaherrera
メンバー登録日: 05/06/13
12,574 ポイント
5のガイドは作成済み
4 件のコメント
Great idea! How about adding an attachment to the bottom of the stand to hold a book open. Maybe use the speaker case cut to size. Affix it using the holes for the RAM access plate.
mayer - 返信
Thats a great idea too! If you add the stand post some pics ^_^
Angela Penaherrera -
Angela, I tried contacting you via twitter, would you click on my icon and email me. This is about my possible relocation to Ecuador .
mayer - 返信
Done! Check your inbox :)
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 25
今までの合計 8,130
