はじめに
あなたのビートの半分が欠けていますか? 右スピーカーを交換して、ステレオサウンドを戻します。
iMacで作業を始める前に:コンピュータの電源プラグを抜き、電源ボタンを10秒間押し続けて、電源装置のコンデンサを放電してください。
コンデンサのリード線または電源の背面の露出したはんだ接合部に触れないように十分注意してください
  1. ディスプレイの左側、つまり電源ボタンに近い方から始めます。iMacオープニングツールをガラス面とケースの側面の間に差し込みます。
    • ディスプレイの左側、つまり電源ボタンに近い方から始めます。iMacオープニングツールをガラス面とケースの側面の間に差し込みます。
    • iMacオープニングツールのハブ(車輪の中心部)は、ホイールをあまりにも押しすぎないようにします。 別の工具を使用する場合は、ディスプレイに3/8インチ(9.5 mm)を超えて挿入しないでください。アンテナケーブルを切断して重大な損傷を引き起こす危険性があります。
    Would a heat gun make this step easier? Or damage the iMac?
    Clark Green - 返信
    A heat gun wouldn’t help you here as you still need to cut though the adhesive. You also risk damaging the display with the excessive heat.
    Dan -
    Removing the original adhesive is easier than removing newly applied adhesive (e.g., if you have to reopen iMac).  If you should happen to need to reopen the iMac, please use extreme caution and highly consider my suggestions below.
    When using the pizza cutter tool, do the first few steps in reverse starting with step 8.  Starting on the left side is better since this is where the adhesive is narrowest.  The right side has two antennas and the top right has one, see the pictures for step 18-21, they are the brass colored metal rectangles near the edges.  The adhesive on these pieces are wider and therefore have more holding power.  The thickness of the pizza cutter tool is enough to crack the glass.
    Walter Hayden - 返信
    Continuing from my previous comment.  To remove the adhesive on the right side you’ll need to create a very slight gap to give the pizza cutter some more room.  Do this by cutting the adhesive on the left side up and around to the camera.  Before attempting to cut the right side. Carefully slide the plastic cards (I purchased two sets) to ensure the adhesive on the left top and side is completely free.  Now slowly move towards the right side.  After every inch or two of removing new adhesive, slide the card over to create this slight gap.  Be careful to not move the card too close to where the adhesive has not been cut.  You want to create a very slight gap without creating too much pressure.  Use extra caution with approaching the areas where the antenna are since the adhesive is stronger here and will need some additional cutting.  Follow this approach all the way around the right side.  Be careful to not create too much pressure at any one time.  Good Luck!.
    Walter Hayden - 返信
    I would highly, highly, highly recommend AGAINST doing this at home. I followed these instructions to a T, and still somehow managed to have the screen not be able to turn on after the hard drive replacement. Then, once you’ve opened your Mac yourself, Apple will refuse to fix anything on the computer, and even other third party, Apple-authorized repair facility will refuse to repair it for you, and you will have to locate a non-authorized Apple repair facility. There, I am having to pay ~$600 to fix things that got screwed up, even though I followed the instructions here to a T, step by step, and did everything slowly and methodically.
    Beware, if you’ve never done this before, that be locked out of ever being able to use an Apple repair facility, or Apple-authorized repair facility, if you mess things up here now.
    Luke Gibson - 返信
    I performed this on a Late 2015 iMac and there weren’t any significant differences to these steps, but I did find the repair to be nerve-wracking. My model cost nearly $3,000 and about 10 steps into this guide (which I did fully read ahead of time) I was thinking, “what have I got myself into?” But I didn’t rush and happily I’m typing this on my repaired iMac! I found a video from OWC that was more useful than the photos in this guide for certain steps: https://vimeo.com/139364064
    Anthony Zimmerman - 返信
  2. ツールをピザカッターを使うように隙間の上を滑らせます。この方法で真ん中に付けられた泡状の接着剤を切り込みます。
    • ツールをピザカッターを使うように隙間の上を滑らせます。この方法で真ん中に付けられた泡状の接着剤を切り込みます。
    • 車輪部で接着剤を切り込む際は、必ずハンドルを押しながら作業を進めてください。もし引いた場合、車輪部とハンドルが外れる可能性があります。
    • 左側全ての上にツールを滑らせます。
    I found the 'pizza cutter' surprisingly smooth at cutting through four-year-old adhesive.
    Gerry - 返信
    • 続けて左上部コーナーまでツールを転がします。
    コメントを追加する
    • ディスプレイの左側上部を沿って接着剤を切り込みます。
    The pizza cutter will sink in all the way to the tool handle when the adhesive is full cut, but don’t feel you have to do this in one motion. Some parts cut easier and some require a lot (like 20x) of gentle back and forth.
    • ディスプレイ上面も同様に続けます。
    • ツールで前後に動かしたり既に切った部分をもう一度切ることで接着剤の切開をより確実にすることができます。
    コメントを追加する
    • ディスプレイの右上面周囲の角もツールで押して切開します。
    コメントを追加する
    • ディスプレイの右端にツールの車輪を押し下げます。
    コメントを追加する
    • ディスプレイの右下角までツールを押しながら切開して作業は終了します。
    • このとき、ディスプレイ全体にもう一度ツールを通して、接着剤が切断されているか確実に点検することもできます。
    コメントを追加する
    • 開口ツールで作業の大部分は対応できますが、ディスプレイは(完全にはがれておらず)ケースに若干繋がっています。この残りの接着剤を剥がすにはプラスチックカードが必要です。
    • iMacの画面側を上に向けます。
    • iMacの右上隅から、ディスプレイとフレームの間にプラスチックカードを挿入します。
      • 3/8 インチ(9.5 mm)以上挿入しないでください。内部の部品が損傷する可能性があります。
    I actually DESTROYED my display (black vertical strips) by pushing the card in a bit TOO DEEP. So it is REALLY important to insert the card only a bit (1-2mm) more than the cutter wheel, in particular at the top side, where many flat cables connect the panel with the PCB. These can be damaged very easily!
    Peter Fischer - 返信
    Same thing with me…. Pushed cards to far…. new panel needed…€600…..
    i think ifixit needs to place a bigger caveat, as I have missed it the first time
    Edgar Broekema - 返信
    i successfully upgraded two imacs. one opened with ifixit pizza knife and another with a regular paper knife. however, when i had to open the first one once again i broke its screen glass. it seems ifixit adhesive strips are too strong. next time i’ll try to use heater to weaken glue tension.
    Eugene Kharkov - 返信
    • プラスチックカードをゆっくりとねじって、ディスプレイとフレームの間のスペースを開きます。
    • ゆっくりと移動し、ディスプレイガラスに過度のストレスがかからないように注意してください。約1/4インチ(6mm)の隙間を開けてください。
    My children tend to collect cards like this from hotels, Disneyland, old IDs, iTunes cards, gift cards etc. They came in handy for this step. After wedging in the first card into the left corner, I wedged the left corner, then added cards along the bottom edge. Finally I continued to push in additional cards to existing cards and found that this created a smooth even pressure along the display top. At 2-3 card-thickness the last of the adhesive let go, gentle as a baby.
  3. Fixmasのスピリットを広めましょう
    クーポンコードFIXMAS12を使えば、50ドル以上のお買い上げで12ドル割引となります。
    Fixmasのスピリットを広めましょう
    • この手順では、iSightカメラの前でスライドを止めてください。破損する恐れがあります。
    • カードをディスプレイの中央に向かってスライドさせ、残っている接着剤を切断します。
    was denn jetzt? Vor der Kamera aufhören, oder in Richtung Bildschirmmitte schieben, um DEN REST zu entfernen? Wenn ich vor der Kamera aufhöre, kann ich nicht alles an Kleber entfernen.
    Julia S. - 返信
    • カードをもう一度コーナーに戻して、接着剤が再付着するのを防ぐためにカードをそこに残しておきます。
    コメントを追加する
    • 左上隅のディスプレイとフレームの間に2枚目のカードを挿入します。
    コメントを追加する
    • 軽くカードをねじって、ディスプレイとフレームの間のスペースを少し広げます。
    • 反対側と同様に、接着剤が剥がれるようにゆっくりと移動させ、ディスプレイガラスに過度の負担がかからないように注意してください。
    コメントを追加する
    • プラスチックカードを中央に向かってスライドさせ、もう一度iSightカメラの直前で止めます。
    コメントを追加する
    • カードを左上隅の上部に差し込みます。
    コメントを追加する
    • ディスプレイを5cm程度持ち上げてください。ーまだデータケーブルと電源ケーブルがiMacに接続されたままの状態です。
    • カードがコーナー付近に挿入された状態で、カードをゆっくりとねじってディスプレイとケースの間の隙間を広げます。
    • 固着されたまま剥がれない部分がある場合は、作業を中断してまだ付着している接着剤を切断するためにもう一枚カードを使用してください。
    • ディスプレイの上部をフレームから持ち上げます。
    I would recommend using suction cups at this stage to lift the display.
    Marco De Palma - 返信
    • ディスプレイを片方の手で持ちながら、もう片方でディスプレイの電源コードの接続を抜きます。
      • 接続部に簡単にアクセスできるようにディスプレイを(少し)持ち上げてください。ただし、ケーブルを引っ張ったり、接続部を圧迫しないようご注意ください。(約20cm程度)
    Mark all cable connectors with a spot of white correction fluid before removal. This will remove the risk, when reinserting them later, of getting them the wrong way round. Yes - I know they will only plug in one way round, but it does make life easier if you are not in perfect lighting!
    Alastair Lack - 返信
    At this step, if you mess up anything with these 2 cables, especially when plugging them back in, even if you think you’re following the instructions here to a T, then you’re screwed.
    Luke Gibson - 返信
    The display cable, the wider one, has a lock on it , usually a plastic tape lift tab to release it, once thats flipped it should come out fairly easily, if your experiencing resistance and the cable isn’t coming out then check for this lock/latch, the power cable just pulls out, just don’t rush it everything should go fine, fairly easy to do with the end result a working iMac
    Ed tabickman - 返信
    • ディスプレイのデータケーブル上の金属製の留め金具を取り出します。
    • ディスプレイデータケーブルを外します。
      • これは簡単に壊れる可能性のある繊細な接続です。 ディスプレイデータケーブルコネクタをソケットからiMacの上部に向けてまっすぐ引き出します。
    I replaced HDD to SSD and assembled parts again. When I boot up the iMac, I found black lines on display (looks partly not broken).
    I searched Internet, and some says graphic card problem, but I didn't touch anything but cable to lift up.
    Could the damaged display data cable cause this situation? I hope I could fix this by just replacing the cables..
    chansung park - 返信
    Sorry, Black lines is a damaged display assembly ;-{ In the process of removing it you either pushed the tool into deep or you torqued the glass severing the tiny wire traces.
    Dan -
    Same trouble here, is it cable trouble or connector trouble?
    redfoxydarrest - 返信
    Sorry damaged display
    Dan -
    I think whenever words like "...is a delicate connection that can be broken. Be sure to pull the [cable in a certain direction] ANYTIME.... It is worth either a closeup or 2, maybe one with annotations or insertion directions and maybe a motion direction arrow with the something like and 'X' char or a circle division slash over the wrong one.
    john - 返信
    [|There are 2 cables to disconnect on my Mac (?). Also, I don’t see a metal retaining bracket. I can take a picture, but cannot attach. I got the glass loose with no problem, but am worried about damaging the cables]
    Jim Kelly - 返信
    Hi Jim! You can go to our Answers Forum to post some better images of your situation!
    Sam Lionheart -
    Luke Gibson - 返信
    Can anybody upload an image of how the display can get damaged from removing it? I find it hard to believe (though I’m reading the horror stories here) that a whole display can get damaged. Especially when many of us were following to a T and being VERY CAREFUL.
    Thanks.
    Bryan - 返信
    • ディスプレイを垂直に近い位置まで持ち上げます。
    • この時点で、ディスプレイの底部に接着剤がまだ残っています(ディスプレイをフレームに固定するための蝶番のような細長い接着剤)。 ディスプレイを上下に数回動かすと、この接着剤を緩めることができます。
    • できるだけ多量の接着剤を外縁部から手で剥がしてください。それから接着剤を中央側に向かって引っ張ったり、揺らしてください。
    Thank you Stef, that's what i will do next time, i cracked the lower part of the screen went opening very slowly, that's probably why those "tabs are for !!
    dforgues - 返信
    Thanks Stef, this has saved me! Simple yet very effective.
    David Zemsky - 返信
    Yep, I cracked the lower corner of the display as well. I failed to work the adhesive enough to loosen it sufficiently. Be careful, I just had to buy my customer another screen!
    Peter Haigh - 返信
    There seems to be missing a step or two. As I was removing the old display, there are two wires that need to get transferred to the new replacement display. There is not note about these two wires located at the top of the display. The 1.128-inch ribbon cable and then this other 4-inch long, two-wire cable that goes to a very small circuit board that is 1/4 by 3/8 of an inch and seems to be adhered to the panel.I have not been able to get this cable off the old display. There is a port for it on the replacement display.
    Note: When ordering this screen, and plastic cards as noted tools, ifixit.com did not list the pizza cutter or the new replacement adhesive strips. So now I’m not sure how to get the new one on and secure.
    Todd Derek - 返信
    The adhesive strip along the bottom is designed with a pull tab on each outer end. Rather than lever and pull the screen simply carefully pull the tab which removes that half of the lower adhesive strip and frees up the screen.
    Andrew Stephens - 返信
    • 必要であれば、プラスチックカードを使用して、底部に残っている細長い接着剤を切断することができます。
    • コンデンサのリード線または電源の背面の露出したはんだ接合部に触れないように十分注意してください(赤色の枠内)。
    Would have been helpful to box the same red area when using the plastic card to separate the glue. Since the red blocked picture is inverted, if someone doesn't pay close attention it may not be obvious that the area of concern is at the right top of the graphic pictures in which the plastic card use is being demonstrated..
    Wizbang FL - 返信
    you don't need to cut the bottom part as the bottom tape is stuck on each side and you can easily pull it out
    Thomas Webb - 返信
    What is the twisted wire taped to the back of the display that can bee seen in the upper right of the first two pictures? I have an 27” iMac without a screen an my replacement does not have this wire. I think it is a temperature sensor but do not know where it connects to.
    Eric - 返信
    [|I opened up my iMac and there’s no HDD or SSD in that spot. its just empty.]
    John Warmann - 返信
    Please update the picture to include the RED BOXED IN AREA that you refer to on all three pictures in this step. I have had a few zaps from these supplies and it is not pleasant.
    Charlie Nancarrow - 返信
    • ディスプレイの取り扱いには非常に注意してください。大きくて重いガラス製です。 ディスプレイには壊れやすいエッジがあります。 エッジでディスプレイを持ち上げないでください。
    • ディスプレイをフレームから持ち上げ、iMacから取り外します。 ディスプレイの表面を平らで柔らかい表面上に置きます。
    • あるいは片側ずつゆっくり持ち上げて、残りの接着剤を剥がさなければならない場合があります。
    コメントを追加する
    • ディスプレイパネルを交換する場合は、古いパネルから新しいパネルに追加でコンポーネントを移す必要があります。 古いディスプレイと交換用ディスプレイの背面を見比べてください。 新しいディスプレイには搭載されていない全てのケーブル、センサーとケーブル、フォーム製緩衝材の有無に注意してください。
      • 接着テープの下にワイヤーやケーブルがある場合は、必ずテープを先に外します。
      • ケーブルがシャーシに接着されている場合は、加熱されたiOpenerまたはヘアドライヤーを使用して接着剤を最初に柔らかくします。 ケーブルの下にある開口ピックをスライドさせて緩めます。 繊細なコネクタを直接引っ張らないでください。
      • フォーム製クッションピースの下にある開口部のピックをスライドさせてディスプレイから分離し、ゆっくりと引き出します。 新しいディスプレイに再度取り付けるには、両面テープが必要な場合があります。
    Be extremely careful removing the LCD Temp Sensor from the rear of the screen. If you pull the wire, you run the risk of severing the metal wire from the connector but not notice it because the surrounding plastic insulation may still be intact. Use a razor blade so “shave off” the sensor under the adhesive. I just had the screen replaced by a local shop and, upon boot, the fan was running full-speed and the Mac’s speed was miserable; Excel took 30 bounces in the Dock to launch rather than the expected 4-5. Novabench showed the Mac running at 4% of its expected speed (overall). The tech examined the sensor carefully, found the broken connection, soldered it back into place, and all was fine. Note that the (partially disconnected) sensor actually showed up when I ran Macs Fan Control in an attempt to work-around this. No problem controlling the fan speed then but the iMac’s running speed was awful until the disconnected sensor wire was fixed.
    barryjaylevine - 返信
    Hi barryjaylevine,
    I’ve had my LCD replaced on my iMac 27 / 2013 and there is no LCD Temp Sensor cable on the replacement screen.
    I’m experiencing the same performance issues.
    I’ve ordered a new sensor, do you have any pointers as to how to install it?
    Thanks,
    Simon
    UK
    simon kennedy -
    hey Simon, I used 2-sided tape….this is assuming the new sensor doesn’t already come with an adhesive surface already applied.
    a roll of kapton tape for your own peace of mind will make sure nothing detaches from thermally-induced adhesive crystallization
    make sure you position it in such a way that you can easily plug the lead back into the mobo….not a lot of length to that wire
    placebomessiah - 返信
    Howdy folks,
    Thanks for all the tips, LCD sensor fitted and iMac back in action.
    Never again!
    Simon
    simon kennedy - 返信
    • ヒンジを自由に動かすと、iMacはバランスを失い、作業が難しくなります。 修理はiMacを設置して完了することができますが、iMacサービスのウェッジを使用すれば、より迅速かつ簡単に修理できます。
    コメントを追加する
    • 10.0 mmのT10ネジを2本取り外します。
    コメントを追加する
    • 右スピーカーを軽く右に軽く揺り動かし、ロジックボード上のケーブル接続にアクセスします。
    コメントを追加する
    • スパッジャーを使用して、ロジックボード上のソケットから右のスピーカーケーブルのコネクタを緩めます。
    • コネクタを右に引っ張ってソケットから外します。
    コメントを追加する
    • スピーカーをまっすぐ持ち上げ、iMacから取り外します。
    コメントを追加する
まとめ
お使いのデバイスを再構成するには、上記の手順を逆の手順で行い、接着剤ストリップの交換ガイドを使用してディスプレイガラスを再び取り付けます。
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 貢献してみませんか?
翻訳を始める ›
Andrew Optimus Goldberg
メンバー登録日: 2009年10月17日
394,745 ポイント
412のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
113 メンバー
7,343のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 18
今までの合計 1,168
