ガイド紹介
Removing the display on the Late 2012 iMac requires cutting adhesive with a specialized iMac opening tool. After you've completed your repair, you'll need to follow our Adhesive Strip Guide to scrape off the old adhesive and replace it with new double-stick adhesive strips.
  1. Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
    Would a heat gun make this step easier? Or damage the iMac?
    Clark Green - 返信
    A heat gun wouldn’t help you here as you still need to cut though the adhesive. You also risk damaging the display with the excessive heat.
    Dan -
    Removing the original adhesive is easier than removing newly applied adhesive (e.g., if you have to reopen iMac).  If you should happen to need to reopen the iMac, please use extreme caution and highly consider my suggestions below.
    When using the pizza cutter tool, do the first few steps in reverse starting with step 8.  Starting on the left side is better since this is where the adhesive is narrowest.  The right side has two antennas and the top right has one, see the pictures for step 18-21, they are the brass colored metal rectangles near the edges.  The adhesive on these pieces are wider and therefore have more holding power.  The thickness of the pizza cutter tool is enough to crack the glass.
    Walter Hayden - 返信
    Continuing from my previous comment.  To remove the adhesive on the right side you’ll need to create a very slight gap to give the pizza cutter some more room.  Do this by cutting the adhesive on the left side up and around to the camera.  Before attempting to cut the right side. Carefully slide the plastic cards (I purchased two sets) to ensure the adhesive on the left top and side is completely free.  Now slowly move towards the right side.  After every inch or two of removing new adhesive, slide the card over to create this slight gap.  Be careful to not move the card too close to where the adhesive has not been cut.  You want to create a very slight gap without creating too much pressure.  Use extra caution with approaching the areas where the antenna are since the adhesive is stronger here and will need some additional cutting.  Follow this approach all the way around the right side.  Be careful to not create too much pressure at any one time.  Good Luck!.
    Walter Hayden - 返信
    I can confirm with Walter - trying to remove freshly applied adhesive is WAAAAY harder! My pizza cutter didn’t work correctly (the circle became a rectangle!) and I ended up with a small crack on the left of my screen. Dang it!
    Benon Koebsch -
    I would highly, highly, highly recommend AGAINST doing this at home. I followed these instructions to a T, and still somehow managed to have the screen not be able to turn on after the hard drive replacement. Then, once you’ve opened your Mac yourself, Apple will refuse to fix anything on the computer, and even other third party, Apple-authorized repair facility will refuse to repair it for you, and you will have to locate a non-authorized Apple repair facility. There, I am having to pay ~$600 to fix things that got screwed up, even though I followed the instructions here to a T, step by step, and did everything slowly and methodically.
    Beware, if you’ve never done this before, that be locked out of ever being able to use an Apple repair facility, or Apple-authorized repair facility, if you mess things up here now.
    Luke Gibson - 返信
    I performed this on a Late 2015 iMac and there weren’t any significant differences to these steps, but I did find the repair to be nerve-wracking. My model cost nearly $3,000 and about 10 steps into this guide (which I did fully read ahead of time) I was thinking, “what have I got myself into?” But I didn’t rush and happily I’m typing this on my repaired iMac! I found a video from OWC that was more useful than the photos in this guide for certain steps: https://vimeo.com/139364064
    Anthony Zimmerman - 返信
    First impressions so far: yes it can be a bit nerve wrecking if it is your first time doing this sort of thing and even with lots of experience with a 2011 model it’s still a bit unsettling haha (nervous laughter).
    What I recommend: use a guitar pick to start cutting the glue. You’ll need a bit of pressure so do just the tip.
    Once you’ve done the whole perimeter (minus bottom) do it again but now it should be easier to go deeper so go very slow and careful. Then get the old suction cups used to open older models and start lifting the display very carefully to see where it’s still glued and cut those as well.
    Then you should be done and now the real fun begins! :D
    Carlos Ferrari - 返信
    It’s ridiculous. Apple should pay for doing this. Like glue parts together to block a repair / make difficult. I smashed my iMac. FU Apple. Seriously, every product I owned had hardware issues. For example, bad solder joints. Never again Apple. I’m happy with Windows and in 2018 / 2019 there are many other manufacturers with high quality stuff. Apple is dying, if they do not change …
    Depple - 返信
    NOTE: I followed every step word for word, but the adhesive strips supplied are as bad as double sided tape. Within 48hours the screen had slipped off and cracked. Now I need to fork out for a new screen and try again.
    Not sure what to try next time with strips? Perhaps a bit of glue to help hold it??
    Dan Kelly - 返信
    Where do i get the “iMac Opening Tool?” its neither in the list of tools nor could i find it on the tool page.
    Patrick Cella - 返信
    Hi @snappadoodle! The opening tool is included in the adhesive kit included in the tool list, but you can purchase it separately here.
    Sam Goldheart -
  2. Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center. Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
    I found the 'pizza cutter' surprisingly smooth at cutting through four-year-old adhesive.
    Gerry - 返信
  3. Continue wheeling the tool up around the top left corner. Continue wheeling the tool up around the top left corner. Continue wheeling the tool up around the top left corner.
    • Continue wheeling the tool up around the top left corner.
  4. Cut the adhesive along the top left of the display. Cut the adhesive along the top left of the display.
    • Cut the adhesive along the top left of the display.
    The pizza cutter will sink in all the way to the tool handle when the adhesive is full cut, but don’t feel you have to do this in one motion. Some parts cut easier and some require a lot (like 20x) of gentle back and forth.
  5. Continue along the top of the display. You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  6. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display.
    • Push the tool around the top right corner of the display.
  7. Wheel the tool down along the right side of the display. Wheel the tool down along the right side of the display.
    • Wheel the tool down along the right side of the display.
  8. Finish pushing the opening tool to the bottom of the right side of the display. At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  9. Android 修理キット
    交換用スクリーンやバッテリーの修理キット
    ショップを見る
    Android 修理キット
    ショップを見る
  10. While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
    I actually DESTROYED my display (black vertical strips) by pushing the card in a bit TOO DEEP. So it is REALLY important to insert the card only a bit (1-2mm) more than the cutter wheel, in particular at the top side, where many flat cables connect the panel with the PCB. These can be damaged very easily!
    Peter Fischer - 返信
    Same thing with me…. Pushed cards to far…. new panel needed…€600…..
    i think ifixit needs to place a bigger caveat, as I have missed it the first time
    Edgar Broekema - 返信
    i successfully upgraded two imacs. one opened with ifixit pizza knife and another with a regular paper knife. however, when i had to open the first one once again i broke its screen glass. it seems ifixit adhesive strips are too strong. next time i’ll try to use heater to weaken glue tension.
    Eugene Kharkov - 返信
    I broke one too. And even if you think you did it correctly, you’ll not be able to see where you might have gone too far. You would think it’s very protected behind that metal plate, but no. Take special care with this offence to “right to repair” This should have been designed WAY better. I mean replacing a hardrive that is very likely to fail over the course of time, or even a simple desire to upgrade to an ssd!.
    Bummer
    Denis Sytmen - 返信
    HINT: If you turn the card and use the blue part of it, then you can avoid going to deep: no further then the blue part …
    Barthold - 返信
    I’m thinking I might just use vinyl tape to keep the screen in place for at least a little while after an upgrade. The extra strength of the replacement tape sounds scary.
    Art Hackett - 返信
  11. Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner. Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
    • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
    • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
    My children tend to collect cards like this from hotels, Disneyland, old IDs, iTunes cards, gift cards etc. They came in handy for this step. After wedging in the first card into the left corner, I wedged the left corner, then added cards along the bottom edge. Finally I continued to push in additional cards to existing cards and found that this created a smooth even pressure along the display top. At 2-3 card-thickness the last of the adhesive let go, gentle as a baby.
  12. Be sure to stop cutting before the iSight camera in this step, or you may damage it. Slide the card toward the center of the display, to cut any remaining adhesive. Slide the card toward the center of the display, to cut any remaining adhesive.
    • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
    • Slide the card toward the center of the display, to cut any remaining adhesive.
    was denn jetzt? Vor der Kamera aufhören, oder in Richtung Bildschirmmitte schieben, um DEN REST zu entfernen? Wenn ich vor der Kamera aufhöre, kann ich nicht alles an Kleber entfernen.
    Julia S. - 返信
  13. Put the card into the corner again and let it stay there to keep the adhesive from resettling. Put the card into the corner again and let it stay there to keep the adhesive from resettling.
    • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
  14. Insert a second card into the gap between the display and frame in the top left corner. Insert a second card into the gap between the display and frame in the top left corner. Insert a second card into the gap between the display and frame in the top left corner.
    • Insert a second card into the gap between the display and frame in the top left corner.
  15. Gently twist the card, slightly increasing the space between the display and frame. As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
    • Gently twist the card, slightly increasing the space between the display and frame.
    • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
  16. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera.
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. Insert the card back into the top left corner. Insert the card back into the top left corner.
    • Insert the card back into the top left corner.
  18. Only lift the display a few inches—it is still attached to the iMac by data and power cables. With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
    • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
    • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
    • Begin to lift the top of the display up from the frame.
    I would recommend using suction cups at this stage to lift the display.
    Marco De Palma - 返信
  19. While holding the display up with one hand, use the other to unplug the display power cable. Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
    • While holding the display up with one hand, use the other to unplug the display power cable.
    • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
    Mark all cable connectors with a spot of white correction fluid before removal. This will remove the risk, when reinserting them later, of getting them the wrong way round. Yes - I know they will only plug in one way round, but it does make life easier if you are not in perfect lighting!
    Alastair Lack - 返信
    At this step, if you mess up anything with these 2 cables, especially when plugging them back in, even if you think you’re following the instructions here to a T, then you’re screwed.
    Luke Gibson - 返信
    The display cable, the wider one, has a lock on it , usually a plastic tape lift tab to release it, once thats flipped it should come out fairly easily, if your experiencing resistance and the cable isn’t coming out then check for this lock/latch, the power cable just pulls out, just don’t rush it everything should go fine, fairly easy to do with the end result a working iMac
    Ed tabickman - 返信
    Is it possible to replace the power cable if its damaged? I can’t seem to find anything about this.
    Joseph Orr - 返信
  20. Flip up the metal retaining bracket on the display data cable. Disconnect the display data cable. This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
    • Flip up the metal retaining bracket on the display data cable.
    • Disconnect the display data cable.
    • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
    I replaced HDD to SSD and assembled parts again. When I boot up the iMac, I found black lines on display (looks partly not broken).
    I searched Internet, and some says graphic card problem, but I didn't touch anything but cable to lift up.
    Could the damaged display data cable cause this situation? I hope I could fix this by just replacing the cables..
    chansung park - 返信
    Sorry, Black lines is a damaged display assembly ;-{ In the process of removing it you either pushed the tool into deep or you torqued the glass severing the tiny wire traces.
    Dan -
    Same trouble here, is it cable trouble or connector trouble?
    redfoxydarrest - 返信
    Sorry damaged display
    Dan -
    I think whenever words like "...is a delicate connection that can be broken. Be sure to pull the [cable in a certain direction] ANYTIME.... It is worth either a closeup or 2, maybe one with annotations or insertion directions and maybe a motion direction arrow with the something like and 'X' char or a circle division slash over the wrong one.
    john - 返信
    Yes, John is absolutely correct on this one. I damaged the display cable trying to get it back in. A close up would have helped and now my computer might have actually been fixed.
    Marsha Giardina -
    [|There are 2 cables to disconnect on my Mac (?). Also, I don’t see a metal retaining bracket. I can take a picture, but cannot attach. I got the glass loose with no problem, but am worried about damaging the cables]
    Jim Kelly - 返信
    Hi Jim! You can go to our Answers Forum to post some better images of your situation!
    Sam Goldheart -
    Luke Gibson - 返信
    Can anybody upload an image of how the display can get damaged from removing it? I find it hard to believe (though I’m reading the horror stories here) that a whole display can get damaged. Especially when many of us were following to a T and being VERY CAREFUL.
    Thanks.
    Bryan - 返信
    First: During reassembly, I highly recommend you connect these cables and do a test boot BEFORE you remove the protective tape on the adhesive strips. That way you can fix any issues(like a damaged cable) if something is not right and you have not re-glued the screen back down which will cause a problem. If you have a second person and everything is working after test boot, you can just leave the cables connected, lift the bottom of the screen and have 2nd person pull the protective tape on the adhesive strips and you can set the screen in place. Second I damaged the video data cable during reassembly on my late 2015 iMac- I did not get the connector straight and I damaged the wires on the cable. I recommend you have someone else hold the screen while you attach the cables - they are fragile. Luckily, the data cable was easily replaced for only about $20. If you must do this by yourself, just be careful I highly recommend have 2 people at this step during reassembly.
    Chip T - 返信
  21. Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    • Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
    Thank you Stef, that's what i will do next time, i cracked the lower part of the screen went opening very slowly, that's probably why those "tabs are for !!
    dforgues - 返信
    Thanks Stef, this has saved me! Simple yet very effective.
    David Zemsky - 返信
    Yep, I cracked the lower corner of the display as well. I failed to work the adhesive enough to loosen it sufficiently. Be careful, I just had to buy my customer another screen!
    Peter Haigh - 返信
    There seems to be missing a step or two. As I was removing the old display, there are two wires that need to get transferred to the new replacement display. There is not note about these two wires located at the top of the display. The 1.128-inch ribbon cable and then this other 4-inch long, two-wire cable that goes to a very small circuit board that is 1/4 by 3/8 of an inch and seems to be adhered to the panel.I have not been able to get this cable off the old display. There is a port for it on the replacement display.
    Note: When ordering this screen, and plastic cards as noted tools, ifixit.com did not list the pizza cutter or the new replacement adhesive strips. So now I’m not sure how to get the new one on and secure.
    Todd Derek - 返信
    The adhesive strip along the bottom is designed with a pull tab on each outer end. Rather than lever and pull the screen simply carefully pull the tab which removes that half of the lower adhesive strip and frees up the screen.
    Andrew Stephens - 返信
  22. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red). Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    Would have been helpful to box the same red area when using the plastic card to separate the glue. Since the red blocked picture is inverted, if someone doesn't pay close attention it may not be obvious that the area of concern is at the right top of the graphic pictures in which the plastic card use is being demonstrated..
    Wizbang FL - 返信
    you don't need to cut the bottom part as the bottom tape is stuck on each side and you can easily pull it out
    Thomas Webb - 返信
    What is the twisted wire taped to the back of the display that can bee seen in the upper right of the first two pictures? I have an 27” iMac without a screen an my replacement does not have this wire. I think it is a temperature sensor but do not know where it connects to.
    Eric - 返信
    [|I opened up my iMac and there’s no HDD or SSD in that spot. its just empty.]
    John Warmann - 返信
    Please update the picture to include the RED BOXED IN AREA that you refer to on all three pictures in this step. I have had a few zaps from these supplies and it is not pleasant.
    Charlie Nancarrow - 返信
    J’ai réussi à intervenir dans l’iMac sans décoller l’ensemble de l’écran. Je l’ai ouvert en laissant la dernière partie collée (vers le logo Apple) et qui sert comme une charnière. Bien calé et assuré l’écran n’a pas bougé et j’ai pu changer mon disque dur facilement. Le grand avantage et d’avoir l’écran toute suite juste quand on le recolle par la suite.
    David Mariaux - 返信
    Well, I of course touched a soldering point in the red area as my hand slipped. I heard and felt a tiny “click” and after replacing the HDD with SSD etc I can not power the iMac up anymore. Not a sign of life :-( I suppose I broke the power supply. Can someone confirm? Or could something else have broken too?
    David Rosner - 返信
  23. Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners. Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface. It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
    • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
    You really should be using film handling or surgical type gloves to handle the screen to minimise finger grease on any of it. Even if it’s possible to clean most of it off, it can be corrosive over time.
    Art Hackett - 返信
  24. If you are replacing the display panel, you may need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
    • If you are replacing the display panel, you may need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
    • If there is a wire or cable underneath adhesive tape, always pull the tape off first.
    • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
    • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
    Be extremely careful removing the LCD Temp Sensor from the rear of the screen. If you pull the wire, you run the risk of severing the metal wire from the connector but not notice it because the surrounding plastic insulation may still be intact. Use a razor blade so “shave off” the sensor under the adhesive. I just had the screen replaced by a local shop and, upon boot, the fan was running full-speed and the Mac’s speed was miserable; Excel took 30 bounces in the Dock to launch rather than the expected 4-5. Novabench showed the Mac running at 4% of its expected speed (overall). The tech examined the sensor carefully, found the broken connection, soldered it back into place, and all was fine. Note that the (partially disconnected) sensor actually showed up when I ran Macs Fan Control in an attempt to work-around this. No problem controlling the fan speed then but the iMac’s running speed was awful until the disconnected sensor wire was fixed.
    barryjaylevine - 返信
    Hi barryjaylevine,
    I’ve had my LCD replaced on my iMac 27 / 2013 and there is no LCD Temp Sensor cable on the replacement screen.
    I’m experiencing the same performance issues.
    I’ve ordered a new sensor, do you have any pointers as to how to install it?
    Thanks,
    Simon
    UK
    simon kennedy -
    hey Simon, I used 2-sided tape….this is assuming the new sensor doesn’t already come with an adhesive surface already applied.
    a roll of kapton tape for your own peace of mind will make sure nothing detaches from thermally-induced adhesive crystallization
    make sure you position it in such a way that you can easily plug the lead back into the mobo….not a lot of length to that wire
    placebomessiah - 返信
    Howdy folks,
    Thanks for all the tips, LCD sensor fitted and iMac back in action.
    Never again!
    Simon
    simon kennedy - 返信
    Hello all. So I’m trying to pinpoint my backlight issue on my 2015 retina 5k - I noticed I’m missing my thermal sensor on the LCD. Would this help with the backlight? I’m sure it will keep my fans from going crazy. Any help would be appreciated! Note: I have LEDs except the 4th one. Thanks!
    Jordan Shababy - 返信
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
    Incomplete guidance . Does not say how to transfer cables such as thermal sensor .
    Yuan - 返信
    La traduction française est tronquée : “…plus faciles avec une cale de maintien pour iMac”
    (https://eustore.ifixit.com/fr/Outils/Org...)
    Pierre-Aurélien - 返信
終わりに
To reassemble your device, follow our Adhesive Strips Guide to reattach the display glass.
49 の人々がこのガイドを完成させました。
Andrew Optimus Goldheart
メンバー登録日: 2009年10月17日
427,914 Reputation
411のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
107 メンバー
9,416のガイドは作成済み
20 Comments
…thanks, but i have a crack on the screen as i was lifting it up. after reconnecting, there where lines on the display. what should i do.?
zeerowbadman - 返信
Something you may want to include for anyone replacing their damaged screen with a new one:
The replacement screens from LG more often DO NOT come with the thermal sensor attached, which means if you replace the screen without transferring the thermal sensor from the old LCD module, the computer will go absolutely insane, rendering it unusable.
This means re-opening the iMac and destroying the brand new adhesive strips. Because I had no idea this sensor existed, much panic ensued before I was forced to rip everything apart again and ultimately securing it closed with packing tape while I waited for the new adhesive strips to arrive in the mail....Not to mention the computer belongs to a client who lives 3 hours outside of the city.
placebomessiah - 返信
Sorry, could you help me? What thermal sensor?! Could you explain?
cristiano -
See the thin twisted black wire on the back of the display in this photo? The one that ends in a small piece of black tape:
https://d3nevzfk7ii3be.cloudfront.net/ig...
that piece of tape covers the tiny thermal sensor at the end of that wire. It is not included as part of the new display, and must be transferred from the old display or your computer will turn into a nightmare.
placebomessiah - 返信
But this is for model emc2546 too? And how you can transfer thermal sensor? Thank You!!!!
cristiano -
Where can I order the screen? There's a local shop nearby that offer to do the repairs for 550€ (!) and they claim it's because it's not just the glass but also the LCD that needs to be replaced. Is this true?
Robin Groenevelt - 返信
I got mine from a distributer in china
it's actually an LG screen. it's tricky to do business with them, because their english is very limited, but with patience, everything works out
placebomessiah - 返信
Hey placebomessiah, could you let me know where you bought it. I am in the same position and need the front display cause I cracked it while trying to open it to replace my hard drive .
Riki -
can you tell me where you bought it or how it is called?
Marc Klingelfuss -
Based on the pictures for the Late 2012 27" and Late 2014" 27" Retina screen replacements, the screens and connectors look identical. Has anyone tried to install a 5K Retina Display on a Late 2012 or Late 2013 27" iMac?
spencer - 返信
Seems like no one has tried it before but I am very curious to know as well. Since my Applecare has lapsed, I am considering getting my Late 2012 27" imac's screen to 5K Retina display too.
potzkie15 -
not possible. apple parts are proprietary. Just like you cant put a iPhone 6s screen on an iPhone 6, you can’t put a 5k screen on a 2012 non 5k model.
Hunter Berry -
Hi there, do you know where I can buy the Retina display 5K at reasonable price? The Apple asked me 900 euro to repair it!!
Dee - 返信
Hi, where can I buy the display?
yoisel1979 - 返信
be very careful when you cut the tape. I really advise you to buy the pizza cutter-style tool. With the plastic card I broke my screen :(
alex - 返信
Looks like I accidentally went too far in and have damaged the LCD, put it all back together and have lines.
** wish I had that mini pizza cutter **
Otherwise advice perfect!
Jon Regler - 返信
I have now ordered my second LCD screen from vendors on Amazon and both of these have arrived with the wrong connectors. My iMac is a (late 2013) model A1419 and even though the LCD replacements I ordered claim they were for an A1419, the internal plug-ins are different sizes than my iMac requires. My iMac requires a 6 wire connection on the right hand side flat cable connector, NOT the 12 wire connector that came on my LCD replacement screen and the connector in the middle of the screen is about 1/4" shorter than the connector on the LCD replacement screen. Can this be so hard??? Can anyone tell me how to make sure I order a replacement LCD screen with the right connectors for my iMac (late 2013) model. Thank you, Dave J.
Dave Jensen - 返信
I'm looking to add an SSD in my 27" iMac (Late 2012), but I have a problem. I bought this very cheaply secondhand as it has a small chip and crack in the glass on the top left corner. It doesn't affect the display whatsoever, so has never bothered me. However, I'm really worried what might happen if I have to remove it to put in the SSD. I can't work out from the pictures the depth of the glass that is attached to the screen. Am I going to cause terrible damage by going ahead with this? Here's a picture of the crack.
https://s27.postimg.org/ov9s69hlf/IMG_06...
markbart - 返信
Unfortunately, I had to reopen my iMac because of my stupid perfectionism! I had clued it not perfectly. So I had to cut the new tapes, what was more difficult than the original ones. After I had replaced the tapes I assembled everything back together and there it was, a very thin yellow line. I could have cried!
Now I’m wondering if there is a solution to repair it instead of replacing it.
Appreciate every hint. Thank you!
Marc Klingelfuss - 返信
Because the new tapes were much stronger than the original ones, I broke the opening tool. I continued with the cards and probably broke the screen because of that.
So don’t use the cards to open your screen!
Marc Klingelfuss -
Past 24 Hours: 22
Past 7 Days: 234
Past 30 Days: 969
All Time: 100,679
