はじめに
This is a guide on how to upgrade your Mid 2011 iMac's Ram, HDD, CPU, and GPU. This guide also shows you how to clean out the fans of your iMac.
必要な工具と部品
First Start by unplugging all cables from your iMac and setting up a workstation.
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
ある他の人がこのガイドを完成しました。
4 件のコメント
Where is the rest of this guide?
Obviously not following this guide, I opened my iMac that had full graphics failure, uninstalled the GPU-card, cleaned it, baked it in the oven to soften the solder and let the chip reattach itself, added new conductive paste, reinstalled it and it worked again.
I can't remember the temperatures, but there are tutorials to be found.
Non è una guida. Manca tutto!
This guide only covers removal of the outer glass and LCD display. Where are the rest of the steps?
