はじめに
Backlight not working? Use this guide to replace a broken LED driver board.
必要な工具と部品
この手順で使用する道具:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Remove the four T10 Torx screws securing the LED driver board to the outer case.
11 の人々がこのガイドを完成させました。
