メインコンテンツにスキップ
iMac Intel 24" EMC 2267 Graphics Card Replacement
必要な工具と部品
  1. iMac Intel 24" EMC 2267 Graphics Card Replacement, Graphics Card: 手順 1、 2の画像 1 iMac Intel 24" EMC 2267 Graphics Card Replacement, Graphics Card: 手順 1、 2の画像 2
    • Begin by following the excellent existing guide on opening this model of iMac, thanks to Brittany, located here.
    • STOP at step 11 of her guide, "Lift and remove the display panel." You do not need to remove the HD to replace/upgrade the video card.
    • As Illustrated here, I chose a less-expensive alternative to the $15 suction cups to lift the glass. For less than $5 I got a pair of 3M "Command" adhesive coat hangars. They proved more than strong enough. The easy release feature came off cleanly with zero residue.
  2. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 2、 1の画像 1
    • Once you've removed the LCD display from the device you can see what you're in for.
    • The logic board is outlined here in red. We have to remove it completely since the video card is installed on the backside. Before we do that, we have to carefully separate 17 connectors.
    • You can see parts of the graphics card highlighted in orange. The GPU is on the right and the dedicated heat fins are on the left, located just "downwind" of the CPU heat fins.
    • AFTER we disconnect all the wires, you need to also remove the right speaker enclosure since it covers the corner of the logic board. It's retained with one obvious screw.
    Traducción al Español:
    Una vez que haya retirado la pantalla LCD del dispositivo, podrá ver en qué está.
    La placa lógica se describe aquí en rojo. Tenemos que eliminarlo completamente ya que la tarjeta de video está instalada en la parte posterior. Antes de hacer eso, tenemos que separar cuidadosamente 17 conectores.
    Puedes ver partes de la tarjeta gráfica resaltadas en naranja. La GPU está a la derecha y los disipadores de calor dedicadas están a la izquierda, ubicadas justo a "encima" del ventilador de la CPU.
    DESPUÉS DE QUE desconectemos todos los cables, también debe quitar la carcasa del altavoz derecho ya que cubre la esquina de la placa lógica. Este se retiene con un tornillo.
    Pakito Villaseñor - 返信
  3. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 3、 3の画像 1 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 3、 3の画像 2 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 3、 3の画像 3
    • This position on the logic board has three closely-spaced connectors for the power button, ambient temp sensor, and the CPU fan. Unplug them.
    • Disconnect these three connectors for the HD temp sensor, optical drive temp sensor, and hard drive fan.
    • Each one of these three connectors has a different number of pins so you can't mix them up when reconnecting. Thanks, Apple!
    I followed your indications with great success to revive my old iMac 24" (early 2008) by baking its burned-out Nvidia 8800GS !
    This is a great step-by-step guide. Thank you very much for publishing it ! I'd like to add some commentaries : the 3 connectors (red point) are rather hard to unplug. Don't loose patience ! You have to pull them slowly with your nails and tweezers to avoid damaging the tiny wires. Don't be afraid, just take your time, because as indicated perfectly by Jeff, each connector has a different size.
    Alexandre Lourdel - 返信
    Esta posición en la placa lógica tiene tres conectores muy próximos entre sí para el botón de encendido, el sensor de temperatura ambiente y el ventilador de la CPU. Desenchúfelos.
    Desconecte estos tres conectores para el sensor de temperatura HD, el sensor de temperatura de la unidad óptica y el ventilador del disco duro.
    Cada uno de estos tres conectores tiene una cantidad diferente de pines, por lo que no puede mezclarlos cuando se vuelva a conectar. Gracias, Apple!
  4. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 4、 3の画像 1 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 4、 3の画像 2 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 4、 3の画像 3
    • Disconnect the plug for the optical drive fan.
    • You have four plugs to disconnect at this location: SATA bus, microphone, and the left and right speaker cables.
    RED: On my iMac 24" (early 2008), the plug for the optical drive fan is located just on the right side of the SATA bus plug. I'd like to publish a picture of it but I don't know if it's possible here.
    ORANGE: On my iMac 24" (early 2008), the SATA plug is tighten by two little screws of the same size than those of the screen data plug. They are easy to remove. All the connectors are different so that it's impossible to mix them up. As said before, some of them could be a bit hard to remove but take your time, they will loosen.
    Desconecte el enchufe del ventilador de la unidad óptica.
    Tiene cuatro enchufes para desconectar en esta ubicación: bus SATA, micrófono y los cables de altavoz izquierdo y derecho.
    ROJO: en mi iMac 24 "(principios de 2008), el conector del ventilador de la unidad óptica se encuentra justo en el lado derecho del conector del bus SATA. Me gustaría publicar una imagen del mismo, pero no sé si es posible aquí
    NARANJA: en mi iMac 24 "(principios de 2008), el tapón SATA se aprieta con dos tornillos pequeños del mismo tamaño que los del tapón de datos de la pantalla. Se pueden quitar fácilmente. Todos los conectores son diferentes, por lo que es imposible mezclar Como se dijo antes, algunos de ellos podrían ser un poco difíciles de quitar, pero tómate tu tiempo, se relajarán.
  5. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 5、 1の画像 1
    • Take a note here how the cable for the left audio speaker (I'm pinching it) is routed loosely above the RAM slots. After you reinstall the logic board, you need to put this back in a similar style.
    On my iMac 24" (early 2008), this cable and the power supply one are covered by a plastic fin that you'll have to bend a little to extract the two cables underneath (left speaker and power supply).
    Tome nota aquí de cómo el cable para el altavoz de audio izquierdo (lo estoy pellizcando) se enruta de manera holgada por encima de las ranuras de RAM. Después de volver a instalar la placa lógica, debe volver a colocarlo en un estilo similar.
    En mi iMac 24 "(principios de 2008), este cable y la fuente de alimentación están cubiertos por una aleta de plástico que deberá doblar un poco para extraer los dos cables que se encuentran debajo (altavoz izquierdo y fuente de alimentación).
  6. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 6、 3の画像 1 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 6、 3の画像 2 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 6、 3の画像 3
    • Almost there! Time to really go wireless by disconnecting the three WiFi and bluetooth antennas. These are tiny snaps so pull gently upward. Also, sneaking in from underneath, you'll find the iSight camera cable. Unplug it. This is one to look out for when you reinstall the logic board.
    • At last you'll disconnect the main power cord and the Hard Drive SATA cable. I photographed the top one already disconnected; be sure to squeeze the edge tabs to release the clamp hooks. The HDD SATA connector has a convenient pull tab.
    ORANGE: On my iMac 24" (early 2008), the main power cord is marked «MLB» and is located in the wifi cables area. My iMac motherboard is a bit different than Jeff's one. But the differences are small. For instance, in my case, there is a small plastic fin above the memory slots that you'll have to bend a little to take out the power and left speaker cables. There is also a small cooler plate in the area above the memory slots.
    ¡Ya esta casi! Es hora de ir realmente a la red inalámbrica desconectando las tres antenas WiFi y Bluetooth. Estas son pequeñas broches, así que tira suavemente hacia arriba. Además, entrando sigilosamente desde abajo, encontrarás el cable de la cámara iSight. Desenchúfelo. Este es un aspecto que debe tener en cuenta al reinstalar la placa lógica.
    Por último, desconectará el cable de alimentación principal y el cable SATA del disco duro. Fotografié el superior ya desconectado; asegúrese de apretar las lengüetas del borde para liberar los ganchos de la abrazadera. El conector HDD SATA tiene una pestaña de extracción conveniente.
    NARANJA: En mi iMac 24 "(principios de 2008), el cable de alimentación principal está marcado como« MLB »y está ubicado en el área de cables wifi. Mi placa base iMac es un poco diferente a la de Jeff. Pero las diferencias son pequeñas. También hay una pequeña placa de refrigeración en el área sobre las ranuras de memoria.
  7. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 7、 2の画像 1 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 7、 2の画像 2
    • Wires done. Now to get unscrewed. There are ten T-10 torx screws holding the logic board to the case in three different sizes:
    • Long ones (2.5mm x 24mm)
    • Short ones (2.5mm x 7mm)
    • A short one with a fine thread (2.5mm x 7mm)
    RED: On my iMac 24" (early 2008), the motherboard has just one more long screw located in the middle of the motherboard, below the top one indicated by Jeff in his picture. All the other screws are like those indicated by Jeff.
    Cables desconectados.. Ahora para desenroscarlo. Hay diez tornillos Torx T-10 que sujetan la placa lógica a la caja en tres tamaños diferentes:
    Rojos: Los largos (2.5mm x 24mm)
    Naranjas: Las cortas (2.5mm x 7mm)
    Amarillos: uno corto con un hilo fino (2.5mm x 7mm)
    ROJO: En mi iMac 24 "(principios de 2008), la placa base solo tiene un tornillo más largo ubicado en el centro de la placa base, debajo de la parte superior indicada por Jeff en su foto. Todos los otros tornillos son como los indicados por Jeff.
    There may be another long screw in the middle of the board, between wifi card and metal grid.
    Mark - 返信
  8. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 8、 2の画像 1 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 8、 2の画像 2
    • If you haven't done so already, remove the speaker assembly on the right by loosening a single T-10 (2.5mm x 14mm) screw.
    • Remove the two T-9 (2mm x 7mm) screws from the bottom right and left corners of the RAM slots that secure the black plastic bracket to the frame.
    • Now simply lift out the logic board while keeping a careful eye on all those wires you just disconnected. The heatsink fins are attached to the logic board and lift out with it.
    • Note: There is a bit of foil tape on the far right (by the audio ports) that will need to be pulled up from the case as well while you lift out the motherboard.
    Si aún no lo ha hecho, retire el ensamblaje del altavoz a la derecha aflojando un solo tornillo T-10 (2,5 mm x 14 mm).
    Retire los dos tornillos T-9 (2 mm x 7 mm) de las esquinas inferior derecha e izquierda de las ranuras de RAM que fijan el soporte de plástico negro al marco.
    Ahora simplemente levante la placa lógica mientras observa atentamente todos los cables que acaba de desconectar. Las aletas del disipador de calor están unidas a la placa lógica y se levantan con ella.
    Nota: Hay un poco de cinta de aluminio en el extremo derecho (por los puertos de audio) que también tendrá que sacar del estuche mientras levanta la placa base.
  9. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 9、 3の画像 1 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 9、 3の画像 2 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 9、 3の画像 3
    • The logic board is moved to my padded work surface.
    • Flipping the board over you'll find all the back-panel connectors and some nifty copper heat piping for the CPU and GPU.
    • Those heat pipes flow to fins above the main blower. This is what 4 years of dust accumulation looks like. Is this the reason my VRAM died?
    Traducción a Español:
    La placa lógica se mueve a mi superficie de trabajo acolchada.
    Al voltear el tablero, encontrará todos los conectores del panel posterior y algunas tuberías de calor de cobre ingeniosas para la CPU y la GPU.
    Esos tubos de calor fluyen a las aletas por encima del soplador principal. Así es como se ve 4 años de acumulación de polvo. ¿Es esta la razón por la que mi VRAM murió?
    I’m thinking of replacing my iMac Graphics cards and RAM! My computer is getting extremely slow and I’m extremely surprised the computer has lasted this long; 10 years and going strong!
    XD
    Austin Millar - 返信
    Baked my graphics card (6+ years ago), solved my video issue, my 2008 iMac 8,1 {with OWC SSD Merc Extreme Pro 6g) is going strong. Bootup time 15-20 sec... Seriously solid 15 yr. old MAChine! Note: of course high speed internet helps ;-)
    J Towne - 返信
  10. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 10、 3の画像 1 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 10、 3の画像 2 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 10、 3の画像 3
    • The graphics card is retained by two T-9 (2mm x 5mm) torx screws on the GPU board...
    • a third T-9 (2mm x 4mm) screw on the end of the heat sink...
    • and the ever-present thermal sensor connector.
    • Remove/disconnect them all.
    On my iMac 24" (early 2008) equipped with a Nvidia 8800GS, there are 3 screws too, located at the exact same places than Jeff 's indications. Great job, Jeff ! Thanks again for your help !
    La tarjeta gráfica está retenida por dos tornillos torx T-9 (2 mm x 5 mm) en la placa GPU ...
    un tercer tornillo T-9 (2 mm x 4 mm) en el extremo del disipador de calor ...
    y el conector del sensor térmico siempre presente.
    Eliminar / desconectarlos todos.
  11. iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 11、 3の画像 1 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 11、 3の画像 2 iMac Intel 24" EMC 2267 Graphics Card Replacement: 手順 11、 3の画像 3
    • You've done it! The graphics card simply tilts up 45 degrees and slides up out of the MXM connector, heat sink and all. I'm glad I could see just how well engineered this piece of Apple hardware is.
    • In the second photo you can see the replacement graphics card (Apple part #661-5135) I got from Impact Computers in Florida. It's a drop-in replacement. Even the adhesive foam and thermal sensor are already in place. In fact, you better not turn your back or you may forget which is which!
    • You World of Warcraft players out there might agree my son and I thought the old video card makes a pretty authentic-looking Gnomish 1H axe. Glory to the Alliance! :-)
    On my iMac 24" (early 2008, Nvidia 8800GS), I had to unscrew 4 screws to release the graphic card from the cooler plate (don't be afraid, it's easy). Then I had to clean all the thermal paste from the upside of the graphic processor using small amount of 90º alcohol (holding the graphic card upside down so that alcohol doesn't pour inside the chips), unglue all the small stickers, then bake the graphic card during 7 min at 200ºC (graphic chip, up), then, after cooling down and reaching ambient temperature, apply small amount of thermal paste (a 2 mm nut) on the graphic chip, then reassemble everything. Voilà ! It's alive ! Infinite thanks to Jeff for his invaluable help !
    ¡Lo has hecho! La tarjeta gráfica simplemente se inclina 45 grados y se desliza hacia afuera del conector MXM, disipador de calor y todo. Me alegra poder ver cuán bien diseñada está esta pieza de hardware de Apple.
    En la segunda foto, puede ver la tarjeta gráfica de reemplazo (parte de Apple # 661-5135) que obtuve de Impact Computers en Florida. Es un reemplazo directo. Incluso la espuma adhesiva y el sensor térmico ya están en su lugar. De hecho, es mejor que no le des la espalda o puede que olvides cuál es cuál.
    Ustedes, jugadores de World of Warcraft, podrían estar de acuerdo con mi hijo y pensé que la vieja tarjeta de video es un hacha Gnomish 1H de aspecto bastante auténtico. ¡Gloria a la Alianza! :-)
    On my EMC2267 (A1225), the layout is completely different. There is no heat upper heat sink for the MXM card and where that should be there is a blanking plate! There is none of the metal structure on the front of the motherboard supporting heatpipes. It is as if the MXM card and the subsystems supporting it are missing. I will remove motherboard tonight to see what is going on behind it!
    rockjapan - 返信
    It seem as if you have got the early 2009 base model with the 2.66 GHz CPU. This model has no dedicated GPU, but integrated graphics instead. If the iMac shows faulty graphics you’ve got to replace the entire logic board.
    Reinhard Kaune -
終わりに
To reassemble your device, follow these instructions in reverse order. This is a good time to vacuum out all that accumulated dust too!
73 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jeff Dickson
メンバー登録日: 02/24/13
2,189 ポイント
1ガイドが承認済み
36 件のコメント
Any tips for selecting a replacement gfx card? How can I be sure my purchase will work?
aaaidan - 返信
Aha! The "Apple part number" from step 11 is a great clue! Searching for these cards by this part number yields many online sellers.
There were three cards that could go in this model:
* NVIDIA GT120 (256Mb): part #661-4991
* NVIDIA GT130 (512Mb): part #661-4990
* ATI Radeon HD 4850 (512Mb): part #661-5135
The ATI card is generally marginally cheaper than the equivalent NVIDIA.
aaaidan - 返信
When I bought my iMac new, I remember the ATI card being the top-of-the-line option.
Jeff Dickson - 返信
Hey Jeff
Do you think I can replace the GPU with a unit from a 2011 iMac?
Rob - 返信
If you're going to try and substitute parts, I would start with the website I bought my video card from (http://www.impactcomputers.com/apple-ima...) and see if the video card(s) for that particular 2011 iMac match any of the part numbers aaaidan shows above.
I picked out one of the 2011 iMacs at random on the website and while the actual card looks the same (size and MXM connector) the heat sink is completely different. But you could try and dismantle the heat sink from the old and new cards and swap them. I would love to know if that works. An AMD Radeon HD6750M upgrade would be sweet :)
Jeff Dickson - 返信
Hmm ok, I exchanged the cards today, but as I already feared = screen stays black...
Guess i'll have to buy a GT130
Rob - 返信
Strangely the mac is working, but screen stays black. I can hear Windows boot... maybe theres a trick with EFI flash i.e.
Rob -
Hi. I did it, but separatet the cooler from the grafic-card. Removed als that "cooling-gum" on the RAM's and cleaned the CPU with tissue-paper. Heated my kitchen oven to 200°C, waited untill temp ist reached. Then put my grafic-card inside for exact 5 Minutes. After this, open the oven, DONT TOUCH THE CARD. Switch oven to off. Wait until the card has slowly reached room-temperature. Reassemble (using the cooling-goo on the rams, and some "Wärmeleitpaste (German-word; i am lazy)" on the CPU. Press the coolerplate firmly to the card (all the goo has to be flatened, to gain contact between the cooling plate and the cpu) - Reassembled, WORKS!
For a broken-card... at least worth a try. Dont blame me if it dosent work. There are thousand of threads out there about this topic - inform yourself.
BTW: Card is a NVIDIA GeForce 8800 GS 512 MB
Heiko - 返信
Hello Heiko seems that this would only work on a 8800 (German: glaube nicht dass dies bei einer GT 130m funktioniert). But I shall give it a try
Rob -
Hi, for me the new graphic-card was to expensive. i take the card and put it in my oven for 20 min by 220 degrees. and... it works now. How long? i don't know...
Stefan - 返信
IT WORKED! I baked my card at 200°C (about 400F) for 20 minutes yesterday. Mac is runnung smoothly so far...
Rob -
While it will work for a while, best bet is to find a repair place that replaces the NVIDIA chip when repairing the card.
Carl Schultz -
I had the exact problem as described in the article. Bought a graphics board online. I could not locate any new ones, however, for a mid 2008 iMac. Followed this procedure and the referenced one for opening the iMac. Both very excellent guides. Thank you so much for posting them. I would only reiterate the part about being very careful when pulling up the outer glass. The alignment pins break off very easily. I broke 2 or 3. The good thing is that they don't seem to be essential to the screen as it is held in place very well with the magnets. Thanks again for the excellent guides!
johnnya - 返信
Hey guys, i replace the card with a Dell G92-751-B1 M17X/M15X Nvidia GTX 260M 1GB MXM 3.0 and it works fine but gamma is too high (it is like take a look to the sun without sunglasses). I tried to low it with same programs but I cannot lower to to an acceptable level (fn f1 and fn f2 keys dont work). I install windows 7 on bootcamp and cannot install any nvidia drivers, always computer tell me that cannot install the specific driver. In mac the System Information card model correctly listed (gtx 260m). Any idea?
havell - 返信
Hi. I have a imac 24 a1225 model. Nvidia Geforce 7600 GT is compatible ?, and geforce GT210 is compatible ?. I expect an answer. Thank you
Adroid Prueba - 返信
Hi, in step 6 on the 3rd picture there is black rounded rectangle little black dot on center. Right of the little orange square. What is it? is this infrared or something else? I broke this part today. is this important or can I live with it?
Murat Ozgul - 返信
Yes, this is the Apple Infrared receiver for the Apple Remote. If you don't have or never used the Apple Remote, you won't be missing anything. I personally use the Apple Remote with Kodi (media player) to stream media, so I would miss it dearly. If you don't have an Apple Remote, you should be able to pick one up for less than $20. Fixing the infrared receiver might be more expensive though...
Miles Raymond -
Great instructions! I replaced my card today with a used one found on Amazon. I took pictures along the way but still maybe something is not hooked up proper. The fan(s) are running at high speed and are audible. Ideas anyone?
ncgater - 返信
Maybe you forgot to plug back some temperature sensor plug. Or maybe you damaged one of its little cables.
Alexandre Lourdel -
I have a iMac 24inch Early 2009 EMC 2267 Model A1225. It was working and now does not display anything and no sound when the power comes on. Could replacing the video card fix the issue? Any suggestions would help. Thank you.
lgalvan - 返信
Great instructions ! I completed your step by step with some instructions about the same process regarding an early 2008 24" iMac with a Nvidia 8800GS (iMac8,1 - A1225 - 2211). I baked the videocard and everything is working fine now ! I'd like to add that, as I took my time to avoid damaging anything, this operation took me more than 5 hours.
Hello,
Did replace My motherboard (Great instructions by the way), got the same symptoms as before.
LED 1 and 2 ON, LED 3 just blink on startup, no Sound. I have tried different RAM modules, same thing.
Any idea ? I have an AMD video card, could it be dead ?
Thanks,
Olivier - 返信
FYI - as the graphics card’s heat vents are above the CPU’s and there is only 1 fan to cool them, We recommend that the computer be “serviced” to clean out the fan, also clean out the vents. This is especially true in a household that is high dust levels and had pets that shed fur. Side note: having the “hot” power supply above the vents further impedes the airflow.
Carl Schultz - 返信
i used this guide to remove gpu card from A1225 (EMC2211) 2008 3.06 iMac . found 1 additional screw holding the logic board and positions of some of the connectors were slightly different. rest of it same. Lucky for me I got a used 2008 really cheap and replacing the working GPU card to my iMac which lost its Nvidia GeForce 8800 GS (661-4664). I hope it works. Thanks to the original author for the instructions.
rajsayshai - 返信
Hello
Im currently digging into this guide as well as other ones on iFixit.
I have this iMac, stored and I am looking for a solution so I can give it to my daughter for school purposes.
(iMac 24”, 2.66, early 2009)
https://everymac.com/systems/apple/imac/...
Mine has, obviously, a damaged GPU. I sent it to a repair shop a few years ago and it worked for a while then it stopped.
Would like to give it a try with a friend of mine who knows his ways into an iMac.
I believe that, with the help of this guide and we will make it work somehow.
my question for you all…In case the GPU is badly damaged and out of repair, which GPU can I alternatively look for to put back on this iMac?
Thank you for your help.
Ricardo
- from Portugal
Ricardo - 返信
seems like this particular model has a onboard gpu
Matthias -
Hi everyone,
I have two iMacs 2008 :
• One is a 20 inch, works well
• The other is 24, but the GPU is dead.
I’d like to use the video card from the first, to put in the second.
ATI references are the same, but after opening the two iMacs, I saw that there are 3 connectors on the 24”, and only 2 on the 20 inch GPU.
It should work to just leave it without the third connector, right ?
Does anybody know what the connector on the right does (see photo) ?
Could it break the iMacs ?
Thanks a lot for your help. :)
Photo here : VIDEO CARD > From 20 inches to 24 / (Aussi en français))
Josselin - 返信
so I actually have the broken GPU (the ATI one) I pulled from my iMac when I wrote this guide. I looked at the edge connector and curiously it doesn’t look like either one of your pictures. My card has a single notch in the center of the connector and both ends go all the way to the edge of the card. If you look closely at the first of the last 3 photos in the guide you can see it.
The wrong card shouldn’t damage the Mac. It just won’t work.
Jeff Dickson -
Alright Jeff thanks for your quick answer ! ;) Not gonna risk it. The 24 will stay dead ! Aha.
Josselin - 返信
Great guide. I ended up taking my graphics card off the heat sink and baking it in the oven. 395degrees for 9 minutes. Put new thermal paste and reassembled. Now it works!
obrently - 返信
hello From France.
Many thanks for this tutorial.
I’ve used it to change successfully the ATI Radeon 2600 Pro of an iMac 24” earlier 2008 (A2111)
There’s a few differences, but the tutorial helped a lot.
Best regards, Joan.
Joan Giral - 返信
I have tried to install a quadro k1000m into the iMac 9.1 24inch early 2009 with the plastic backside and the smallest processor and I found out it has no graphics card to switch, it must be an onboard model. It seems like only the model with the 2,6 ghz processor has an onboard gpu.
Matthias - 返信
I have the same model and there is no MXM GPU (or even a slot) on the motherboard for an MXM. The GPU chip is soldered to the motherboard, so no replacing with a K1100M, etc.
I removed the large square aluminum heatsink on the GPU chip and heat-gunned it for 8 minutes at 200°C and I am about to reassemble (after 30 minutes to cool) and see it that has made a temporary fix. If not, it’s going to be parted-out for pennies.
I have pictures of the alternative motherboard layout without the MXM GPU if anybody wants them.
rockjapan - 返信
Hallo,
ich habe hier einen iMac Intel 24" EMC 2267 2.66 mit einer NVIDIA GeForce 9400M ist in diesem Geräte eine Grafikkarte vorhanden oder ist die Grafikkarte am Logic Board angelötet?
marcfuss - 返信
why is nt 2267 have a different video card setup?
jujoe1 - 返信
コメントを追加
統計データ:
過去 24時間: 15
過去 7 日: 59
過去 30 日: 299
今までの合計 152,529
