はじめに
Remove the glass panel to gain access to your iMac's internals.
  1. The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter. Stick two suction cups to opposing corners of the glass panel. Small suction cups used to stick things to windows or shower walls work.
    • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
    • Stick two suction cups to opposing corners of the glass panel. Small suction cups used to stick things to windows or shower walls work.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  3. Gently pull the glass panel straight up off the iMac.
    • Gently pull the glass panel straight up off the iMac.
    • The glass panel has several positioning pins around its perimeter. To avoid bending or shearing these pins off the glass panel, be sure to only pull straight up during removal.
    • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
まとめ
14 の人々がこのガイドを完成させました。
johann beda
メンバー登録日: 2010年09月13日
2,297 ポイント
4のガイドは作成済み
コメント1件
Correct again - thanks to ifixit contributors. Great team
geoff - 返信
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 43
今までの合計 25,691
