メインコンテンツにスキップ
iMac Intel 24" EMC 2134 and 2211 RAM Replacement
必要な工具と部品
  1. iMac Intel 24" EMC 2134 and 2211 RAM Replacement, Access Door: 手順 1、 1の画像 1
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2134 and 2211 RAM Replacement, RAM: 手順 2、 2の画像 1 iMac Intel 24" EMC 2134 and 2211 RAM Replacement, RAM: 手順 2、 2の画像 2
    • Use the tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
    • Pull the black plastic RAM tab away from your iMac to eject the RAM module.
  3. iMac Intel 24" EMC 2134 and 2211 RAM Replacement: 手順 3、 1の画像 1
    • Grab the RAM module by its edges and pull it straight out of its slot.
    • If two RAM modules are installed, repeat this process for the other chip.
終わりに
53 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
89,128 ポイント
131のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,077のガイドは作成済み
5 件のコメント
I believe the EMC2211 model requires PC2-6400 RAM chips instead of the PC2-5300 proposed here.
Edouard Gilbert - 返信
EMC2134 requires PC2-5300 as specified here. PH1 worked ok. Need to give RAM tabs a pretty firm pull to initially unseat, then it is easy to slide RAM back.
lcgillies - 返信
I don't see any 4 GB RAM chips? I currently have a 2 GB and 4 GB. Was thinking about changing out the 2 GB for a 4 GB. Would it support two 4 GB RAM chips? Do you not sell them?
ericgossick - 返信
Ericgossick: according to Apple the most ram you can have is 4 GB. I have heard you can install 2 GB & 4 GB ram chips & the computer will operate normally. If you install 2 (two) 4 GB ram chips the computer will only use 6 GB; it will never use 8 GB. That's just what I've heard. Hope this helps.
davidfoster11 - 返信
Does anyone know if one bank is better than the other for the 4G stick if one is maxxing out their RAM?
Alistair Prewett - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 78
今までの合計 38,768
