はじめに
Remove your front bezel to gain access to your iMac's internals.
パーツ
パーツは指定されていません。
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx screws
Four 25 mm T8 Torx screws
30 の人々がこのガイドを完成させました。
