メインコンテンツにスキップ
iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement, Display Panel: 手順 1、 2の画像 1 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement, Display Panel: 手順 1、 2の画像 2
    • Disconnect the LCD temperature sensor by pulling the connector straight out of its socket on the logic board.
    • If necessary, de-route the LCD temperature sensor cable from behind the logic board.
  2. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 手順 2、 1の画像 1
    • Remove the two 5.3 mm T6 Torx screws securing the display data cable to the logic board.
  3. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 手順 3、 1の画像 1
    • Disconnect the display data cable connector from its socket on the logic board by pulling the attached plastic tab towards you and away from the iMac.
  4. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 手順 4、 2の画像 1 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 手順 4、 2の画像 2
    • Lay the iMac down on a table before you remove the LCD so that it doesn't fall.
    • Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
    • Lift the right side of the display panel a few inches up from the iMac.
    • Do not lift the LCD all the way up; there are still connectors attaching the LCD to the internals.
  5. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 手順 5、 2の画像 1 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 手順 5、 2の画像 2
    • With the LCD lifted, disconnect the LCD cable by pulling down.
    • The LCD cable is attached to the underside of the power supply; be careful where you put your fingers so you don't get zapped by a capacitor.
    • On reassembly, you may find it helpful to remove the power supply, reconnect the LCD power cable, and then reinstall the power supply.
    • Alternatively, the LCD power cable can be disconnected from the LCD, rather than the power supply.
  6. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 手順 6、 2の画像 1 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 手順 6、 2の画像 2
    • Continue to lift the LCD from the right side.
    • Remove the LCD.
終わりに
4 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
89,014 ポイント
131のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,816のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,928
