メインコンテンツにスキップ
iMac Intel 24" EMC 2111 IR Board Replacement
必要な工具と部品
  1. iMac Intel 24" EMC 2111 IR Board Replacement, Access Door: 手順 1、 2の画像 1 iMac Intel 24" EMC 2111 IR Board Replacement, Access Door: 手順 1、 2の画像 2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 IR Board Replacement, Front Bezel: 手順 2、 1の画像 1
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
  3. iMac Intel 24" EMC 2111 IR Board Replacement: 手順 3、 2の画像 1 iMac Intel 24" EMC 2111 IR Board Replacement: 手順 3、 2の画像 2
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  4. iMac Intel 24" EMC 2111 IR Board Replacement: 手順 4、 3の画像 1 iMac Intel 24" EMC 2111 IR Board Replacement: 手順 4、 3の画像 2 iMac Intel 24" EMC 2111 IR Board Replacement: 手順 4、 3の画像 3
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
    • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
    • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  5. iMac Intel 24" EMC 2111 IR Board Replacement: 手順 5、 1の画像 1
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  6. iMac Intel 24" EMC 2111 IR Board Replacement: 手順 6、 3の画像 1 iMac Intel 24" EMC 2111 IR Board Replacement: 手順 6、 3の画像 2 iMac Intel 24" EMC 2111 IR Board Replacement: 手順 6、 3の画像 3
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
  7. iMac Intel 24" EMC 2111 IR Board Replacement, IR Board: 手順 7、 1の画像 1
    • The IR board is located above the RAM modules socket, near the lower, center portion of the iMac.
    • Remove the single T6 Torx screw securing the small IR board.
  8. iMac Intel 24" EMC 2111 IR Board Replacement: 手順 8、 1の画像 1
    • Pull the small IR board slightly away from the iMac and disconnect its cable.
    • Set it aside.
  9. iMac Intel 24" EMC 2111 IR Board Replacement: 手順 9、 2の画像 1 iMac Intel 24" EMC 2111 IR Board Replacement: 手順 9、 2の画像 2
    • Remove the remaining T6 Torx screw securing the other IR board to the logic board.
    • De-route the IR cables from the metal shield behind the IR board and remove the shield from the iMac.
  10. iMac Intel 24" EMC 2111 IR Board Replacement: 手順 10、 1の画像 1
    • Disconnect the second IR board and remove it from the iMac.
終わりに
作成者
2人の作成者と共同で作成されました。
Andrew Bookholt
583,604 ポイント
619のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,708
